- Posted on
Fri Dec 22, 2023 5:21 pm
mpleeds
offline
Hi Karl, Thanks for the suggestion. I eliminated some Shelly device duplicates which were created during a recent migration to Shelly Direct from Shelly MQQT and that solved the error. New issue - I upgraded to 7.20.57 per your recommendation and now getting the following message. I attempted to downgrade back to 7.20.55 just in case there's a bug in 7.20.57, but now get the same message. I also stopped the server, deleted plugin and prefs, restarted and downloaded plugin and still getting error. Please advise.
Error (client) timeout waiting for plugin response from com.karlwachs.shellyDirect for request UiGetValues1
Error (client) timeout waiting for plugin response from com.karlwachs.shellyDirect for request CallPluginFunc
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
shellyDirect Error ---------------------------------------------------------------------------------------------------------------
shellyDirect Error The pluginname is not correct, please reinstall or rename
shellyDirect Error It should be /Libray/....../Plugins/shellyDirect.indigPlugin
shellyDirect Error It is: /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/shellyDirect 2.indigoPlugin
shellyDirect Error please check your download folder, delete old *.indigoPlugin files or this will happen again during next update
shellyDirect Error ------- the plugin has stopped, waiting for you to change the name and restart it ---------------------------
