Shelly1 Relay Sensor Input
Tue Jul 27, 2021 9:43 am
mpleeds offline
I'm interested in knowing if anyone has had success getting the Shelly1 "SW" terminal to act as a sensor input with this plugin. My objective is to use the device to control my garage door by having an action group close the relay for around 1 second (based on my garage opener's open/close method) and concurrently using the "SW" input to monitor garage door state via reed switch @ 24v (powering Shelly1 and supplied by garage door opener).
Tue Jul 27, 2021 1:47 pm
tazswe offline
Re: Shelly1 Relay Sensor Input
I use Shelly Uni for my garage doors, two inputs and two outputs.
Sent from my iPad with Tapatalk
Tue Jul 27, 2021 3:42 pm
mpleeds offline
Are you using the Uni with Karl's Shelly plugin?
Tue Jul 27, 2021 4:46 pm
tazswe offline
Sorry, My misstake, I use it in Shellymqtt.
Sat Jul 31, 2021 9:00 pm
Yes it should work.
Set the trigger on dev state “input” changed
