- Code: Select all
2021-05-05 10:50:56 received "shelly_192.168.1.106" onOffState to "True"
2021-05-05 10:51:02 received "shelly_192.168.1.106" brightnessLevel to "0-ui:0%"
2021-05-05 10:51:08 received "shelly_192.168.1.106" onOffState to "True"
2021-05-05 10:51:09 send "shelly_192.168.1.104" light/0?turn=off
2021-05-05 10:51:14 received "shelly_192.168.1.106" brightnessLevel to "0-ui:0%"
2021-05-05 10:51:14 received "shelly_192.168.1.106" WiFi_rssi to "-71"
2021-05-05 10:51:17 received "shelly_192.168.1.104" onOffState to "True"
2021-05-05 10:51:17 send "shelly_192.168.1.104" light/0?turn=on
2021-05-05 10:51:17 send "shelly_192.168.1.106" light/0?turn=off
2021-05-05 10:51:17 received "shelly_192.168.1.104" brightnessLevel to "79-ui:79%"
2021-05-05 10:51:17 received "shelly_192.168.1.104" whiteLevel to "79-ui:79%"
2021-05-05 10:51:18 received "shelly_192.168.1.106" brightnessLevel to "79-ui:79%"
2021-05-05 10:51:18 received "shelly_192.168.1.106" onOffState to "True"
2021-05-05 10:51:18 received "shelly_192.168.1.106" whiteLevel to "79-ui:79%"
2021-05-05 10:51:18 send "shelly_192.168.1.106" light/0?turn=on&brightness=79
2021-05-05 10:51:18 received "shelly_192.168.1.106" brightnessLevel to "0-ui:0%"
2021-05-05 10:51:18 received "shelly_192.168.1.106" onOffState to "False"
2021-05-05 10:51:18 received "shelly_192.168.1.106" whiteLevel to "0-ui:0%"
2021-05-05 10:51:18 received "shelly_192.168.1.104" power to "5.6-ui:5.6[W]"
2021-05-05 10:51:19 received "shelly_192.168.1.106" WiFi_rssi to "-72"
2021-05-05 10:51:44 received "shelly_192.168.1.106" WiFi_rssi to "-71"
2021-05-05 10:51:56 received "shelly_192.168.1.106" WiFi_rssi to "-70"
this is what I have now (next version) is that enough?
Actions (click on on/off or menu/action ) will add to indigo log
send dev.name command send to shelly device
any CHANGE in dev states will add in indigo log:
received "dev.name" state to " value - ui value"
or
received "dev.name" state to " value"
if no ui value defined
There can be a lot of entries, depending on frequency settings, ie for wifi values they tend to change by +-1 every time the shelly device is queried
