Plugin crash on Verisure error message (version 2.0.7)
Thu Jan 09, 2020 11:56 am
CrazyFin offline
Alright, version 2.0.7 of this excellent plugin has been stable since its release! Wonderful!
However, last 2 days the plugin has crashed two times due to the following error message from Verisure:
2020-01-08 00:18:58.943   Verisure v2 Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 334, in runConcurrentThread
  File "plugin.py", line 177, in refreshData
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/session.py", line 188, in get_overview
RequestError: HTTPSConnectionPool(host='e-api02.verisure.com', port=443): Max retries exceeded with url: /xbn/2/installation/<removed my installation number from here>/overview (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x113841e90>: Failed to establish a new connection: [Errno 60] Operation timed out',))
2020-01-08 00:18:58.944   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2020-01-08 00:19:08.947   Verisure v2 Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 329, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'login'
2020-01-08 00:19:08.948   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
When this happens the plugin never recovers and it just keeps on repeating the error message:
2020-01-08 00:19:38.962   Verisure v2 Error   Error in plugin execution runConcurrentThread:
2020-01-08 00:19:38.963   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Only solution is to reload the plugin and it starts to work normally again.
Seems to have been caused by Verisure responding "Max retries exceeded with url:" so I decided to decrease the polling interval from 5 seconds to 15 seconds.
Let's see if this error happens again with the lower polling interval.
Fri Jan 10, 2020 11:23 am
CrazyFin offline
Re: Plugin crash on Verisure error message (version 2.0.7)
Unfortunately the plugin crashed the same way today:
2020-01-10 10:23:56.678   Verisure v2 Error   Error in plugin execution runConcurrentThread:
RequestError: HTTPSConnectionPool(host='e-api02.verisure.com', port=443): Max retries exceeded with url: /xbn/2/installation/<removed for security>/overview (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x101dcc710>: Failed to establish a new connection: [Errno 51] Network is unreachable',))
2020-01-10 10:23:56.678   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sat Jan 18, 2020 3:40 pm
Hi CrazyFin
I just noticed I didn't reply to this.
However, have you tried 2.0.8 which I released on Christmas Eve and has a fix for a login-related issue so may well resolve this as well.
Peter
Sat Jan 18, 2020 4:54 pm
CrazyFin offline
@howartp;
I did try the version 2.0.8 of the plugin a few weeks ago before I encountered the errors I reported in this thread.
The version 2.0.8 had its own problems causing me to have to roll back to 2.0.7. See my error report at viewtopic.php?f=321&t=23383
