Version 2.0.8 errors/ bugs
Wed Dec 25, 2019 7:57 am
CrazyFin offline
I tested version 2.0.8 and it seems to have more errors causing it to be unusable (I'll roll back to 2.0.7):
Following error when installation of 2.0.8 is finished and plugin is reloaded:
2019-12-25 14:49:42.708   Application   Loading plugin "Verisure v2 2.0.8"
2019-12-25 14:49:42.715   Application   Starting plugin "Verisure v2 2.0.8" (pid 95888)
2019-12-25 14:49:44.350   Application   Started plugin "Verisure v2 2.0.8"
2019-12-25 14:49:48.874   Verisure v2 Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 331, in runConcurrentThread
  File "plugin.py", line 255, in refreshData
KeyError: 'key currentLockState not found in dict'
2019-12-25 14:49:48.877   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
and
2019-12-25 14:49:58.875   Verisure v2 Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 326, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'login'
2019-12-25 14:49:58.875   Verisure v2 Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Following error when closing configuration panel:
   Verisure v2 Error               Error in plugin execution UiClosed1:
  File "plugin.py", line 76, in closedPrefsConfigUi
  File "plugin.py", line 152, in doLogin
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/session.py", line 101, in login
OSError: (2, 'No such file or directory', '/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/.verisure-cookie')
Sun Jan 19, 2020 3:49 pm
Re: Version 2.0.8 errors/ bugs
Try https://github.com/howartp84/Verisure/r ... /tag/2.0.9
It fixes the "currentLockState" and "Plugin object has no attribute 'login'"issues
I think the cookie error was fixed in 2.0.8 but didn't work because of the login issue above.
Peter
Sun Jan 19, 2020 5:17 pm
CrazyFin offline
Cool!
I am now running version 2.0.9 with 5 sec update interval.
I'll report back in few days (earlier if I see an error).
Mon Jan 20, 2020 3:22 pm
tazswe offline
Tried the 2.09 today and got the following error, tried to reload it and got the same error every time except the second time.
Error attempt 1,3,4,5
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/VerisureV2-2.indigoPlugin/Contents/Server Plugin/verisure/session.py", line 96, in login
IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/.verisure-cookie'
Got this error on the second attempt.
Version 2.07 was running good for me but I only locks.
Skickat från min iPad med Tapatalk
Tue Jan 21, 2020 1:53 am
I’m confused because if that’s the same line I looked at, it says:
If(cookie exists) then delete it.
Then it promptly fails to delete it as it doesn’t exist.
I’ll have another look.
Wed Jan 22, 2020 5:17 pm
Aha....!
Your indigo plugin filename is wrong, and therefore it can't write the cookie when logging in.
Can you rename the plugin file and restart Indigo?
Peter.
Thu Jan 23, 2020 1:50 am
tazswe offline
Hi Peter,
Did as you suggested. Got the following bug.
23 Jan 2020 at 08:13:39
Error plugin "VerisureV2-2.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/VerisureV2-2.indigoPlugin/Contents/Info.plist
After that I downgraded it to 2.0.8 to see if it would install the missing file, and it did.
Have now upgrade to 2.0.9 and it seems to work . :)
