@crazyfin I use Mojave 10.14.6 on my minimac late 2012 and don’t have the issues that you describe.
Skickat från min iPad med Tapatalk
2020-08-20 00:05:21.673 Verisure v2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 331, in runConcurrentThread
File "plugin.py", line 177, in refreshData
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/session.py", line 191, in get_overview
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/VerisureV2.indigoPlugin/Contents/Server Plugin/verisure/session.py", line 18, in _validate_response
ResponseError: Invalid response, status code: 429 - Data: {"errorGroup":"TOO_MANY_REQUESTS","errorCode":"AUT_00021","errorMessage":"Request limit has been reached"}
2020-08-20 00:05:21.676 Verisure v2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2020-08-20 00:05:43.680 Verisure v2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 180, in refreshData
2020-08-20 00:05:43.680 Verisure v2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2020-10-07 06:03:03.001 Verisure v2 Error Error in plugin execution runConcurrentThread:
ResponseError: Invalid response, status code: 503 - Data: {"errorGroup":"SERVICE_UNAVAILABLE","errorCode":"SYS_00004","errorMessage":"XBN Database is not activated"}
2020-10-07 06:27:18.925 Verisure v2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 326, in runConcurrentThread
File "plugin.py", line 162, in doLogin
File "plugin.py", line 210, in refreshData
KeyError: 'userTracking'
2020-10-07 06:27:18.926 Verisure v2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
userTracking = self.overview['userTracking']
vsure <username> <pwd> installations
usage: vsure [-h] [-i INSTALLATION] [-c COOKIE]
username password
{installations,overview,armstate,set,climate,eventlog,capture,imageseries,getimage,vacationmode,door_window,test_ethernet}
Up until recentely when I called the get_overview() command I got a "userTracing" tab in the json reply but now its missing. Anybody knows if Verisure hidden it or if the information is avalible somewhere else?
"accountPermissions": {
"accountPermissionsHash": "xxxxxxxxxxxxxxxxxxxxx"
"armState": {
"statusType": "DISARMED",
"date": "2020-10-15T14:04:12.000Z",
"name": "xxxxxx",
"changedVia": "CODE"
"smartPlugs": [
"icon": "LIGHT",
"isHazardous": false,
"deviceLabel": "xxxxxxxx",
"area": "xxxxxx",
"currentState": "OFF",
"pendingState": "NONE"
"doorLockStatusList": [
"area": "xxxxxx",
"method": "AUTO",
"lockedState": "LOCKED",
"currentLockState": "LOCKED",
"pendingLockState": "NONE",
"eventTime": "2020-10-15T15:53:12.000Z",
"secureModeActive": false,
"motorJam": false,
"paired": true
"climateValues": [
"deviceLabel": "xxxxxxxxx",
"deviceArea": "xxxxxxxxx",
"deviceType": "xxxxxxxx",
"temperature": 21.3,
"time": "2020-10-15T15:56:51.000Z"
"installationErrorList": [],
"ethernetModeActive": true,
"ethernetConnectedNow": true,
"heatPumps": [],
"latestEthernetStatus": {
"latestEthernetTestResult": true,
"testDate": "2020-10-15T15:45:20.000Z",
"protectedArea": "xxxxxxxxxxxx",
"deviceLabel": "xxxxxxx"
"customerImageCameras": [
"motionDetectorMode": "xxxxxxxxx",
"area": "xxxxxxxxx",
"numberOfNotViewedImageSeries": 0,
"imageResolution": "HIGHER",
"accelerometerMode": "xxxxxxxxx",
"capability": "xxxxxxxxxxxxxx"
"eventCounts": [],
"doorWindow": {
"reportState": true,
"doorWindowDevice": [
"area": "xxxxxxxxxx",
"state": "CLOSE",
"wired": false,
"reportTime": "2020-10-15T15:53:13.000Z"
2020-11-10 23:10:41.555 Verisure v2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 333, in runConcurrentThread
2020-11-10 23:10:41.556 Verisure v2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
CrazyFin wrote:Agree.
@howartp: Could you allow polling times 5,6,7,8,9,10,11,12,13,14,15 and then 30, 45, 1 min, 2 min, 3 min, 4 min, 5 min and then end with 10 min?
Or even better, let the user decide the polling time by entering it in number of seconds?
