https://github.com/FlyingDiver/Indigo-T ... g/2022.1.0
For this release, you MUST do the following:
Update the Nexia library: pip install aiohttp nexia --upgrade
This version of the plugin only supports one Trane Home/Nexia account. To set up your account credentials, do the following:
- Disable all plugin devices (uncheck the "Comm Enabled" checkbox in the Indigo UI)
- Install the new plugin
- Enter your account credentials in the plugin config dialog
- Restart the plugin
- Enable the plugin devices (check the "Comm Enabled" checkbox)
- Edit each thermostat and zone device. Just open the dialog, make sure the correct device is selected, then Save.
On the other hand, you'll also need to downgrade the nexia library if you want to go back to the old version.
