Trane Nexia Nexia Trane Thermostat: Starting NexiaThermostat Device 80724978
Trane Nexia Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 115, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_devices.py", line 71, in update
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_thermostat.py", line 721, in get_current_compressor_speed
Exception: ('This system does not have a variable speed compressor.', 50430)
Trane Nexia Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
File "plugin.py", line 106, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_thermostat.py", line 436, in update
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_thermostat.py", line 273, in _get_thermostat_json
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_thermostat.py", line 231, in _get_url
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/Trane Nexia.indigoPlugin/Contents/Server Plugin/nexia_thermostat.py", line 391, in login
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 489, in get
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 477, in request
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 417, in send
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/packages/urllib3/connectionpool.py", line 590, in urlopen
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/packages/urllib3/response.py", line 373, in from_httplib
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/packages/urllib3/_collections.py", line 324, in from_httplib
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/packages/urllib3/_collections.py", line 137, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/collections.py", line 57, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/abc.py", line 151, in __subclasscheck__
RuntimeError: maximum recursion depth exceeded
roquej wrote:The default 15 min. I will increase by 5 min to see if I can find the sweet spot. Will report back.
roquej wrote:I did as you suggested, turned the plugin off for 24 hours. Well. the error is the same as above.
Suggestions?
