Hive Thermostat Plugin - Instructions and User Information
Wed Sep 18, 2019 9:10 am
racarter offline
To use the plugin you will need to enter your Hive account user name and password via the Config menu. It is assumed that you have already set up your system in the Hive app, including naming zones and thermostats. The plugin will then retrieve your Hive data from the servers and create the appropriate Indigo devices. It is not necessary to create any devices manually.
Functionality:
For thermostat:
Display room temperature
Display/change set point
Display/change operating mode (Off/Manual/Schedule/Boost)
Display current firing status
Display battery level
Hot water:
Display/change operating mode (Off/Schedule/Boost)
Display on/off status
