MQTT Broker plugin survey
Fri Mar 29, 2024 3:45 pm
I'd like to get some input from users of the MQTT Broker plugin, especially those having problems with the Broker hanging or stopping or otherwise not processing messages.
Please provide:
MacOS Version
Indigo Version
Plugin Version
# of MQTT messages handled by the plugin per minute (approximately)
Frequency of issues with the plugin (as above)
Fri Mar 29, 2024 3:47 pm
Re: MQTT Broker plugin survey
For instance, my production server is:
MacOS Ventura 13.6.4
Indigo 2023.2.0
Plugin 2023.2.1
Less than 100 messages per minute (only one device, a ratgdo controller)
Never fails
Fri Mar 29, 2024 7:26 pm
Korey offline
Mac OS Ventura 13.6.6 (22G630)
Indigo 2023.2.0
Plugin 2023.2.1
Same a you RATGDO, never fails.
Korey
Sat Mar 30, 2024 4:11 pm
SMUSEBY offline
MacOS Version 13.5
Indigo Version 2023.2
Plugin Version 2023.2.1
# of MQTT messages handled by the plugin per minute (approximately) n/a
I just returned to my vacation home to find that none of the MQTT controls are responding to Indigo commands. I cannot recall any event that may have caused this with the possible exception of installing the 2023.2.1 version of the plug-in. That was in January, and I do not recall the specifics, e.g., whether I tested it.
Prior to January when Indigo/Shelly was working, with many fewer devices installed (17) compared to my home, very rough guess, the broker required reloading about 10% of the time. FWIW, today, the controls do respond to the Shelly app.
Sat Mar 30, 2024 4:28 pm
SMUSEBY offline
MacOS Version 13.1
Indigo Version 2022.2
Plugin Version 2022.1.0
# of MQTT messages handled by the plugin per minute (approximately) Recently (again, I can't attribute a cause), the event log has been spewing the message " Trigger g NGMQTT Connector Event" - guessing 100/minute. This can't be good, but regardless, the broker is working with a work-around:. a plug-in broker reload followed by a 1 second delay, and then the control command. Before the work-arounds, I'm guessing the broker failed 33% of the time. In this home, I've installed 33 Shelly devices and there are many more instances in which they are controlled than in my vacation home.
My other work-around attempt has been to install the HomeBrew Broker and the Docker Broker per your suggestions; thus far, I have been unable to detect the broker with MQTT Explorer (note - these broker install attempts are not on the servers running Indigo). At this point, the other brokers are not finding the mosquito.conf file - still working at it. But if you were to make the plug=in broker function reliably, that would be great.
I'm happy to do beta testing if that would be useful.
