Page 1 of 2
Help with MQTT
Posted:
Wed Dec 14, 2022 4:04 am
by MarcoGT
Hi all,
I have bought a couple of ESP32 board to be used as presence monitor (using BLE).
This is basically thought to work with MQTT, but I am confused on how to do it.
What do I need on the Indigo side?
MQTT Shims to create a device? What kind of device?
Marco
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 5:08 am
by MarcoGT
I am trying to playing a little bit, but without success, so far I have:
- Code: Select all
14. Dec 2022 at 12:07:23
MQTT Shims Debug message_handler: MQTT message ##espresense## from Local MQTT
MQTT Shims Debug Bagno_OG: processMessages: '##espresense##' espresense/rooms/bagno_og/telemetry -> {"ip":"192.168.2.118","uptime":2971,"firm":"esp32","rssi":-79,"ver":"v3.1.1","adverts":30411,"seen":30154,"freeHeap":92584,"maxAllocHeap":77812,"memFrag":15.95524065,"scanHighWater":1036,"reportHighWater":808}
MQTT Shims Error Bagno_OG: error getting uid value from payload, aborting
Why is trying to get "status" key from "telemetry"?
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 6:55 am
by cuhouse
Marco,
From the MQTT Explorer information you provided, status is not JSON. Payload Type: Raw from what I see.
Jody
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 7:06 am
by FlyingDiver
Also the UID ('bagno_og ') is not in the payload, it's part of the topic. Third part, which makes it field 2 (zero based).
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 10:50 am
by MarcoGT
Thanks a lot for the inputs, but I think I am still missing something
- Code: Select all
MQTT Shims Debug Bagno_OG: processMessages: '##espresense##' espresense/rooms/bagno_og/telemetry -> {"ip":"192.168.2.118","uptime":2175,"firm":"esp32","rssi":-84,"ver":"v3.1.1","adverts":4484,"seen":4437,"freeHeap":93292,"maxAllocHeap":79860,"memFrag":14.39780474,"scanHighWater":1044,"reportHighWater":808}
MQTT Shims Debug Bagno_OG: Raw payload = {"ip":"192.168.2.118","uptime":2175,"firm":"esp32","rssi":-84,"ver":"v3.1.1","adverts":4484,"seen":4437,"freeHeap":93292,"maxAllocHeap":79860,"memFrag":14.39780474,"scanHighWater":1044,"reportHighWater":808}
MQTT Shims Debug Bagno_OG: states_key=
MQTT Shims Debug Bagno_OG: Updating state to False
Hubitat Bridge received "Movimento Cucina" motion sensor "active" event
MQTT Shims Debug Bagno_OG: processMessages: '##espresense##' espresense/rooms/bagno_og/telemetry -> {"ip":"192.168.2.118","uptime":2190,"firm":"esp32","rssi":-81,"ver":"v3.1.1","adverts":4637,"seen":4590,"freeHeap":93292,"maxAllocHeap":79860,"memFrag":14.39780474,"scanHighWater":1044,"reportHighWater":808}
MQTT Shims Debug Bagno_OG: Raw payload = {"ip":"192.168.2.118","uptime":2190,"firm":"esp32","rssi":-81,"ver":"v3.1.1","adverts":4637,"seen":4590,"freeHeap":93292,"maxAllocHeap":79860,"memFrag":14.39780474,"scanHighWater":1044,"reportHighWater":808}
Hubitat Bridge received "Movimento Bagno-EG" motion sensor "active" event
MQTT Shims Debug validateDeviceConfigUi, devId=178623972, typeId=shimOnOffSensor, valuesDict = UiValuesDict : (dict)
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 11:52 am
by FlyingDiver
You didn't fix either of the issues pointed out to you already.
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 1:50 pm
by MarcoGT
Sorry, you are right, uploaded wrong screenshot
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 2:24 pm
by FlyingDiver
Looks to me like your trigger is matching on any of the messages from the device, not just the status topic. I don't see any status topic messages in the log excerpt you posted.
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 2:31 pm
by MarcoGT
This is my trigger
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 2:35 pm
by FlyingDiver
Yeah, that's not going to work. You need to trigger on the specific message topic for the value you're looking for, which is "espresense/rooms/bagno_og/status". So you need:
- Code: Select all
Match: espresense
Match: rooms
Any:
Match: status
End:
The any is there because if you if have multiple devices, you want the trigger to work for all of them, identified by the uniqueID (bagno_og)
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 2:41 pm
by MarcoGT
It worked!
Thanks a lot!
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 3:01 pm
by MarcoGT
Now I am doing something different, because I would like not only to get the status value, but also other data in it.
My idea was to create a trigger for every /rooms/<device>, is this approach correct?
Therefore I would have as follows, but something seems wrong as it does not work
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 3:26 pm
by FlyingDiver
MarcoGT wrote:Now I am doing something different, because I would like not only to get the status value, but also other data in it.
No. You can create a trigger for each message type you want to use, but they're re-used for multiple devices.
The Shim device represents a specific value (or possibly set of values) for a specific MQTT topic message. So you can use a trigger for all devices for THAT message type. Each message type represents a different topic. Each topic/uniqueID combo maps to a different Shim device.
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 3:33 pm
by MarcoGT
Yes, in the meantime I modified and used that approach; now I am trying to create a device representing the IP, but what type of sensor shall I use? If I use generic, I get error "unable to convert to float".
Re: Help with MQTT
Posted:
Wed Dec 14, 2022 3:39 pm
by FlyingDiver
You need to use "Generic JSON Device".
