MQTT Connector
Fri Jun 03, 2022 5:38 pm
roquej offline
MQTT Connector
I used the MQTT Connector to publish variables and devices without issue since it was released. It worked perfectly until I upgraded to Indigo v2022.1 and v2022.0.0. Now nothing gets published.
Tried reinstalling the plugin, restarting Indigo, and restarting Mosquitto. Nothing works.
Suggestions?
JP
Fri Jun 03, 2022 6:08 pm
Re: MQTT Connector
Post debug log.
Fri Jun 03, 2022 6:58 pm
roquej offline
Re: MQTT Connector
Done, but although I see all the debug activity for the topics for which I am listening like homeassistant, nothing for Indigo. Is like all the Indigo variables and devices that I had published before are not doing anything now.
Fri Jun 03, 2022 7:52 pm
Re: MQTT Connector
Posted where?
Fri Jun 03, 2022 9:08 pm
Re: MQTT Connector
Nevermind. Looks like I can see the same thing. I'll look at it tomorrow.
Sat Jun 04, 2022 7:14 am
Re: MQTT Connector
Fixed in 2022.0.1 in store now
Sat Jun 04, 2022 7:50 am
roquej offline
Re: MQTT Connector
Installed the update, but no luck. I do get Indigo debug statements, but nothing related to variables or device changes. Variable is changing, just not being published.
Jun 4, 2022 at 9:42:29 AM
   MQTT Connector Debug            pluginsList = ['Cynical Behaviors.indigoPlugin', 'Twilio.indigoPlugin', 'Masquerade.indigoPlugin', 'fantasticWeather.indigoPlugin', 'Tesla Control.indigoPlugin', '.Z-Wave.indigoPlugin', 'MQTT Connector.indigoPlugin', '.DS_Store', 'PiHoleStatus.indigoPlugin', 'GhostXML.indigoPlugin', 'Pushover.indigoPlugin', 'Online Sensor.indigoPlugin', 'ShellyMQTT.indigoPlugin', 'Indigo-VirtualEnergyMeter.indigoplugin', 'Multitool.indigoPlugin', 'TED5000.indigoPlugin', 'Virtual Devices.indigoPlugin', '.Web Server.indigoPlugin', 'iRobot-Roomba.indigoPlugin', 'ad2usb.indigoPlugin', 'TeslaBattery.indigoPlugin', 'Email+.indigoPlugin', 'ZwaveLockManager.indigoPlugin', 'WeatherLink Live.indigoPlugin', 'EnphaseEnvoy.indigoPlugin', 'MyPeople.indigoPlugin', 'Announcements.indigoPlugin', 'Cynical SecuritySpy.indigoPlugin', 'Indigo Backup.indigoPlugin', 'MQTT Shims.indigoPlugin', 'Timers and Pesters.indigoPlugin', 'Cynical Weather.indigoPlugin', 'Alexa.indigoPlugin', 'RFXCOM.indigoPlugin', 'nodeMatrix.indigoPlugin', 'Group Change Listener.indigoPlugin', 'Solcast.indigoPlugin', 'Lock Group.indigoPlugin', '.Action Collection.indigoPlugin', 'Occupatum.indigoPlugin', 'Rachio Sprinkler.indigoPlugin', 'HomeKitLink-Siri.indigoPlugin', 'Realistic Random.indigoPlugin', 'Grafana Home Dashboard.indigoPlugin', 'Mac Apps.indigoPlugin', 'Trane Home.indigoPlugin', 'Unistat.indigoPlugin', 'TankUtility.indigoPlugin']
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical Behaviors.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Twilio.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Masquerade.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/fantasticWeather.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Tesla Control.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/MQTT Connector.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/PiHoleStatus.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/GhostXML.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Pushover.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Online Sensor.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/ShellyMQTT.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Multitool.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/TED5000.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Virtual Devices.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/iRobot-Roomba.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/ad2usb.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/TeslaBattery.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Email+.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/ZwaveLockManager.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/WeatherLink Live.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/MyPeople.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Announcements.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Indigo Backup.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/MQTT Shims.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Timers and Pesters.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical Weather.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Alexa.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/RFXCOM.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/nodeMatrix.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Group Change Listener.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Solcast.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Lock Group.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Occupatum.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Rachio Sprinkler.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Realistic Random.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Mac Apps.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Trane Home.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Unistat.indigoPlugin/Contents/Info.plist
   MQTT Connector Debug            path = /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/TankUtility.indigoPlugin/Contents/Info.plist
Sat Jun 04, 2022 8:03 am
Re: MQTT Connector
Sigh. I shouldn't fix bugs this early.
2022.0.2 is available.
Sat Jun 04, 2022 9:04 am
roquej offline
Re: MQTT Connector
Now it's working!! Thank you!
JP
Sat Jun 25, 2022 7:28 am
roquej offline
Re: MQTT Connector
What I am doing wrong?
MQTT Connector Warning Queue for message type '##haSwitch##' has 373 messages pending
I am obiously not removing the messages once they are processed. Just not sure how to fix.
JP
Sat Jun 25, 2022 7:35 am
Re: MQTT Connector
You have a trigger queuing messages of type "##haSwitch##". What is consuming those messages? It would usually be Shim devices of some kind, but it could also be a Python script or another plugin (like ShellyMQTT).
Sat Jun 25, 2022 9:28 am
roquej offline
Re: MQTT Connector
Thank you. Had a trigger that was not being used.
How can empty that queue?
JP
Sat Jun 25, 2022 9:34 am
Re: MQTT Connector
JP
Restart the plugin.
