Getting value from JSON into device
Mon Oct 18, 2021 7:53 am
roquej offline
Mr. MQTT Jedi, while you have a chance to work on the Nexia plugin, I am trying to get a few details from my Nexia thermostat using MQTT and Home Assistant. Got the temperature and humidity without any issues. However, having a problem understanding how to get the "system status", a string, configured.
The topic looks like this:
Screen Shot 2021-10-18 at 9.30.08 AM.png (50.45 KiB) Viewed 1765 times
So, trying to configure the device as such:
Device type: Generic JSON
What am I doing wrong?
Thank you!!
JP
Screen Shot 2021-10-18 at 9.36.23 AM.png (163.38 KiB) Viewed 1765 times
Mon Oct 18, 2021 9:34 am
Re: Getting value from JSON into device
It doesn't look like you're showing the complete topic string there. It easier to see what's going on if you configure the MQTT Connector plugin to subscribe to the topics you want, then put it in debug level logging so it logs the topics and payloads.
Mon Oct 18, 2021 12:31 pm
roquej offline
This is from the debug mgs and exactly the info I would like to collect via a Shims device:
processMessages: '##haSensors##' homeassistant/sensor/house_system_status/state -> System Idle
is this enough to point me in the right direction?
JP
Mon Oct 18, 2021 12:52 pm
From that, it looks like the payload for that topic is NOT a JSON string, but a plain text string. I'm not sure the Shims plugin can deal with that the way you want. Is there any way to get HA to send actual JSON?
Mon Oct 18, 2021 1:52 pm
roquej offline
Not sure, but I will check. Will let you know
Thank you!
Mon Oct 18, 2021 1:56 pm
If not, you can modify this script to get the payload and put it in a variable. Edit as needed and run as an external script.
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import json
import time
import indigo
mqttPlugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.mqtt")
if mqttPlugin.isEnabled():
    props = {
        'message_type':"#Test#"
    while True:
        message_data = mqttPlugin.executeAction("fetchQueuedMessage", deviceId=1867973662, props=props, waitUntilDone=True)
        if message_data != None:
            indigo.server.log("Queue Fetch, version = {}, message_type = {}, topic_parts = {}".format(message_data["version"], message_data["message_type"], message_data["topic_parts"]))
            payload = json.loads(message_data["payload"])
            indigo.server.log("Queue Fetch, payload = {}".format(payload))
            time.sleep(1.0)
The deviceid in the call to mqttPlugin.executeAction() is the MQTT Connector device.
Mon Oct 18, 2021 3:12 pm
roquej offline
as always, you rock!! thank you!
JP
