error on state_location_payload_key in version 0.5.2
Fri Apr 30, 2021 12:05 pm
Ramias offline
Hi FlyingDiver
This was not an issue in v 0.4.0.
Getting this:
   MQTT Shims Error                Ring Alarm Basestation Info: error on state_location_payload_key, aborting
   MQTT Shims Error                Ring Alarm Keypad Entryway: error on state_location_payload_key, aborting
   MQTT Shims Error                Ring Alarm Keypad Bedroom: error on state_location_payload_key, aborting
   MQTT Shims Error                Ring Alarm Keypad Basement: error on state_location_payload_key, aborting
   MQTT Shims Error                Ring Alarm ZWave Extender: error on state_location_payload_key, aborting
   MQTT Shims Error                Ring Alarm ZWave Extender Basement: error on state_location_payload_key, aborting
These (in fact all of mine - 20+) are aggregate devices. But only these 6 throw the error. These six are all MQTT Generic Json devices (of which I have 7 total).
The one of the seven that does not show here is the panel, I don't track battery level and it's multi-state key is:
topics.alarm.topics.state
The multi-states key for the six that error is this:
topics.info.topics.state.payload
and Battery Payload Key is this:
topics.info.topics.state.payload.batteryLevel
My On/Off Sensors is the same multi-states key and battery key but are not throwing the error.
Ideas? Rolling back to v 0.4.0 resolves this.
Fri Apr 30, 2021 12:24 pm
Re: error on state_location_payload_key in version 0.5.2
Please use the menu command to create a template for one of the devices that is misbehaving, and post it here. I also need a typical topic and payload for the device, which is generally easiest to get by using debug logging in the Connector plugin.
Screen Shot 2021-04-30 at 2.23.07 PM.png (178.71 KiB) Viewed 3184 times
Fri Apr 30, 2021 1:40 pm
Ramias offline
   MQTT Shims
message_type: '##RingAlarm##'
props:
    SupportsBatteryLevel: true
    battery_payload_key: topics.info.topics.state.payload.batteryLevel
    state_dict_payload_key: topics.info.topics.state.payload
    state_location: payload
    state_location_payload_type: json
    uid_location: topic
    uid_location_topic_field: '3'
trigger:
    match_list: '["Match: ring", "Match:ACCOUNT_GUID, "Match: alarm", "Any: ", "End: "]'
    queueMessage: true
type: shimGeneric
and
   MQTT Connector Debug            Ring MQTT Broker: Message topic: ring/ACCOUNT_GUID/alarm/DEVICE_GUID/info/state, payload = {"acStatus":"error","batteryLevel":85,"batteryStatus":"ok","brightness":1,"chirps":"enabled","commStatus":"ok","firmwareStatus":"up-to-date","lastCommTime":"2021-04-30T19:01:09Z","lastUpdate":"2021-04-30T19:01:09Z","linkQuality":"ok","powerSave":"off","serialNumber":"SER_NUM","tamperStatus":"ok","volume":0.7}
   MQTT Connector Debug            Ring MQTT Broker: processReceivedMessage: ring/ACCOUNT_GUID/alarm/DEVICE_GUID/info/state, payload: {"acStatus":"error","batteryLevel":85,"batteryStatus":"ok","brightness":1,"chirps":"enabled","commStatus":"ok","firmwareStatus":"up-to-date","lastCommTime":"2021-04-30T19:01:09Z","lastUpdate":"2021-04-30T19:01:09Z","linkQuality":"ok","powerSave":"off","serialNumber":"SER_NUM","tamperStatus":"ok","volume":0.7}
   MQTT Connector Debug            Ring MQTT Broker: agg_dict: {u'topics': {u'info': {'topics': {u'state': {u'payload': {u'batteryStatus': u'ok', u'lastUpdate': u'2021-04-30T19:01:09Z', u'serialNumber': u'SER_NUM', u'brightness': 1, u'chirps': u'enabled', u'firmwareStatus': u'up-to-date', u'acStatus': u'error', u'lastCommTime': u'2021-04-30T19:01:09Z', u'volume': 0.7, u'tamperStatus': u'ok', u'linkQuality': u'ok', u'batteryLevel': 85, u'commStatus': u'ok', u'powerSave': u'off'}}}}}}
   MQTT Connector Debug            Ring MQTT Broker: Saved states, topic: ring/ACCOUNT_GUID/alarm/DEVICE_GUID, payload: {"topics": {"info": {"topics": {"state": {"payload": {"batteryStatus": "ok", "lastUpdate": "2021-04-30T19:01:09Z", "brightness": 1, "chirps": "enabled", "serialNumber": "SER_NUM", "firmwareStatus": "up-to-date", "acStatus": "error", "lastCommTime": "2021-04-30T19:01:09Z", "volume": 0.7, "tamperStatus": "ok", "linkQuality": "ok", "batteryLevel": 85, "commStatus": "ok", "powerSave": "off"}}}}, "status": {"payload": "online"}}}
Fri Apr 30, 2021 1:43 pm
Ah, I also need the aggregator info from the Connector plugin. There's a menu command to write it to the log.
Fri Apr 30, 2021 1:54 pm
Ramias offline
   MQTT Connector                  1416305691:ring/ACCOUNT_GUID/alarm/DEVICE_GUIDring/ACCOUNT_GUID//alarm/DEVICE_GUID{
    "topics": {
        "info": {
            "topics": {
                "state": {
                    "payload": {
                        "batteryLevel": 85,
                        "brightness": 1,
                        "commStatus": "ok",
                        "powerSave": "off",
                        "volume": 0.7
        "status": {
            "payload": "online"
Fri Apr 30, 2021 1:57 pm
The first line lost it's formatting. And does it really have double slashes in there?
Fri Apr 30, 2021 1:59 pm
I think I have enough. I'll try to look into this over the weekend.
https://github.com/FlyingDiver/Indigo-Shims/issues/21
Sat May 01, 2021 10:36 pm
dssinger offline
In case it helps you find the bug, I have the same problem - I reverted to 0.4.4 and it's working again. Fails in 0.5.1 and above.
Sun May 02, 2021 6:13 am
Turns out I missed something in the code refactor in 0.5.0. Try this version.
https://github.com/FlyingDiver/Indigo-S ... /tag/0.5.3
Sun May 02, 2021 11:53 am
Ramias offline
Updated and now getting this:
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 115, in runConcurrentThread
  File "plugin.py", line 139, in processMessages
  File "plugin.py", line 302, in update
UnboundLocalError: local variable 'state_data' referenced before assignment
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sun May 02, 2021 12:00 pm
Grrr. More complicated than I thought. That's what I get for trying to streamline the code. Give me a few minutes.
Sun May 02, 2021 12:42 pm
Sun May 02, 2021 1:07 pm
Ramias offline
Now back to a variation of the first error message:
   Stopped plugin MQTT Shims
   Upgrading plugin MQTT Shims to newer version 0.5.4 (previous version moved to trash)
   Loading plugin "MQTT Shims 0.5.4"
   Starting plugin "MQTT Shims 0.5.4" (pid 61195)
   Started plugin "MQTT Shims 0.5.4"
   MQTT Shims                      Starting MQTT Shims
May 2, 2021 at 2:46:57 PM
May 2, 2021 at 2:52:00 PM
Sun May 02, 2021 1:19 pm
Darn it all. These are all generic shims, right?
Sun May 02, 2021 1:22 pm
Ramias offline
Yes. Generic json
