MQTT Shims Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 115, in runConcurrentThread
File "plugin.py", line 139, in processMessages
File "plugin.py", line 656, in update
UnicodeDecodeError: 'ascii' codec can't decode byte 0xb0 in position 35: ordinal not in range(128)
MQTT Shims Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any ideas?
I also get this in my log every time MQTT updates (every min), is there a way to stop this as well?
16 Apr 2021 at 20:26:03
Trigger MQTT Inverter
Thanks in advance,
Martin
