Tasmota UK Mains Plug settings
Thu Mar 25, 2021 7:57 am
CliveS offline
I have finally found a reliable UK 240v Tasmota based mains plug and via MQTTConnector and Shims installed it.
I can turn it on and off but have run out of ideas how to get the Indigo UI state to change from Off to On as I just cannot get my head around what is needed.
Also Energy, Power key settings and 'Send Status Request' have defeated me.
STATE = {“Time":"2021-03-25T14:19:57","Uptime":"0T02:45:10","UptimeSec":9910,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Highsteads_AC","BSSId":"F0:9F:C2:2A:07:83","Channel":1,"RSSI":100,"Signal":-33,"LinkCount":1,"Downtime":"0T00:00:03"}}
SENSOR =
{"Time":"2021-03-25T14:19:57","ENERGY"{"TotalStartTime":"2021-03-24T14:28:10","Total":0.374,"Yesterday":0.227,"Today":0.147,"Period":3,"Power":33,"ApparentPower":44,"ReactivePower":30,"Factor":0.74,"Voltage":247,"Current":0.180}
CliveS
Thu Mar 25, 2021 8:42 am
Re: Tasmota UK Mains Plug settings
Your payload type is JSON, not Raw. Once you fix that, then you can set the payload key to "POWER". Then you need to make sure you have the trigger set up properly for the topic. That should fix getting the plugin device to sync with the actual device.
Thu Mar 25, 2021 8:51 am
Getting the energy readings out will require a separate Shim device, since the data is sent using a different topic. Use a Value Sensor device and set the multi-states key to ENERGY.
Thu Mar 25, 2021 8:55 am
It's a lot easier to decipher this stuff if you use the complete topic and format the payload for readability:
Tasmota/Test-Room/tele/STATE =>
    "UptimeSec":9910,
    "Heap":25,
    "Sleep":50,
    "LoadAvg":19,
    "MqttCount":1,
    "POWER":"ON",
    "Wifi":
        "AP":1,
        "Channel":1,
        "RSSI":100,
        "Signal":-33,
        "LinkCount":1,
Tasmota/Test-Room/tele/SENSOR =>
    "ENERGY":
        "Total":0.374,
        "Yesterday":0.227,
        "Today":0.147,
        "Period":3,
        "Power":33,
        "ApparentPower":44,
        "ReactivePower":30,
        "Factor":0.74,
        "Voltage":247,
        "Current":0.180
I'm hoping that you did a bad copy and paste on that SENSOR payload, because what you posted is missing a ":" after "ENERGY" and a final "}". If the payload is actually missing those characters you've got real problems with that payload.
Thu Mar 25, 2021 10:00 am
CliveS offline
I did try JSON but got the same problem and yes it was a bad copy and paste on the SENSOR payload.
I have included a log of me just clicking Turn On and Turn Off, with a few seconds delay between each click.
   MQTT Shims Debug                Tasmota-Plug-1: publish_topic: Tasmota/Test-Room/cmnd/POWER -> off
   Trigger                         Tasmota Trigger
   MQTT Shims Debug                received notification of MQTT message type ##tasmota## from Indigo MQTT Server
   MQTT Shims Debug                Tasmota-Plug-1: processMessages: '##tasmota##' Tasmota/Test-Room/stat/RESULT -> {"POWER":"OFF"}
   MQTT Shims Debug                Tasmota-Plug-1: update topic message_address = Test-Room
   MQTT Shims Debug                Tasmota-Plug-1: update state_location_payload, key = POWER
   MQTT Shims Debug                recurseDict key_string = POWER, data_dict= {u'POWER': u'OFF'}
   MQTT Shims Debug                Tasmota-Plug-1: shimRelay, state_key = POWER, state_data = {u'POWER': u'OFF'}, value = OFF
   MQTT Shims Debug                Tasmota-Plug-1: Updating state to False
   MQTT Shims Debug                Tasmota-Plug-1: publish_topic: Tasmota/Test-Room/cmnd/POWER -> on
   MQTT Shims Debug                Tasmota-Plug-1: processMessages: '##tasmota##' Tasmota/Test-Room/cmnd/POWER -> on
   MQTT Shims Debug                Tasmota-Plug-1: JSON decode error for state_location = payload, aborting
25 Mar 2021 at 15:44:50
   MQTT Shims
message_type: '##tasmota##'
props:
    SupportsOnState: true
    action_template: Tasmota/Test-Room/cmnd/POWER
    off_action_payload: 'off'
    on_action_payload: 'on'
    shimSensorSubtype: Power
    state_location: payload
    state_location_payload_key: POWER
    state_location_payload_type: json
    state_location_topic_field: '0'
    state_on_value: 'on'
    toggle_action_payload: toggle
    uid_location: topic
    uid_location_topic_field: '1'
trigger:
    match_list: '["Match: Tasmota", "Any: "]'
    queueMessage: true
type: shimRelay
CliveS
Thu Mar 25, 2021 10:14 am
Your trigger is wrong. You're matching on any message from the Tasmota, but you need a trigger (and message type) specifically for the two topics that have data you want, which are:
You're getting errors because the trigger is matching on the on/off command you're sending TO the device (which the broker is echoing back to Indigo).
You can see in the log that when you sent the OFF command, the plugin did update the state to off (False).
Thu Mar 25, 2021 10:16 am
It also usually helps to turn on debug logging for the Connector plugin, so that you can see what messages it's processing and queueing.
Fri Mar 26, 2021 10:30 am
CliveS offline
I think I have sorted all that and now find after further digging
I have two triggers set for when the plug turns on or off
Trigger 1 on Tasmota/Test-Room/stat/Any
"If device" "Tasmota-Plug-1" "On/Off State" "is on"
Then
Write to Log
###### ON ###### ON ###### ON ###### ON ###### ON #######
and
Trigger 2 on Tasmota/Test-Room/stat/Any
"If device" "Tasmota-Plug-1" "On/Off State" "is off"
Then
Write to Log
###### OFF ###### OFF ###### OFF ###### OFF ###### OFF #######
I can never get the On to trigger.
I added a couple of indigo.server.log lines in the shims code and found that pressing either on or off always triggered OFF and many of the Trigger/Actions clicks did not get MQTT Shims response.
When it did turn On eventually the updateStateImageOnServer was still False.
The ‘custom states Power=‘ mostly mimicked the real state but not always, but clicking on or off did turn the plug on and off 100% of the time.
Trigger Tasmota/Test-Room/stat off
Action Collection ###### OFF ###### OFF ###### OFF ###### OFF ###### OFF #######
MQTT Shims value = self.recurseDict(state_key, state_data) = OFF
MQTT Shims updateStateImageOnServer = False
MQTT Shims value = self.recurseDict(state_key, state_data) = ON
26 Mar 2021 at 16:27:14
MQTT Shims
message_type: '##tasmota-stat##'
props:
brightness_scale: '100'
dimmer_action_payload: '{''turn'': ''on'', ''brightness'': {{brightness}} }'
shimSensorPrecision: '2'
state_dict_payload_key: .
state_on_value: '1'
uid_location: topic
trigger:
match_list: '["Match: Tasmota", "Match: Test-Room", "Match: stat", "Any: "]'
queueMessage: true
type: shimRelay
CliveS
Fri Mar 26, 2021 10:38 am
Please turn on debug logging for both the Connector and Shims plugins and post that. I need to see the actual topics and payloads as the plugin sees them.
I suspect that the problem is this:
state_on_value: '1'
You have it configured to turn on the Shim device when it receives a value "1" in the payload. I suspect you're never actually getting that value.
Fri Mar 26, 2021 10:48 am
CliveS offline
state_on_value: '1'
I have no idea where state_on_value is set. I will turn on both debugs (I could be a long time as it just scrolls constantly)
CliveS
Fri Mar 26, 2021 10:51 am
Screen Shot 2021-03-26 at 12.49.50 PM.png (89.16 KiB) Viewed 2922 times
Fri Mar 26, 2021 10:58 am
Scrolls constantly? With MQTT messages? Or other stuff? I would recommend turning off as much stuff as you can while you're trying to get this working. Maybe even remove some of your topic subscriptions which aren't needed for the specific devices you're working on.
Fri Mar 26, 2021 11:21 am
CliveS offline
Joe,
I removed the '1', (trying 1,true,on and forgot to remove it!) and it is now all working, thank you and my apologies for waisting you time.
As for the scrolling, that was with Verbose debug on, I take it you only really need normal debug. (but not now required)
CliveS
Fri Mar 26, 2021 11:31 am
Correct, the "detailed debugging" is really only there for plugin development. I almost never tell someone to turn that one, but people do anyway. ;)
Sat Mar 27, 2021 3:38 am
Colly offline
Hi Clive,
Would you mind sharing a link to the plug you’re using?
