UniFi Protect G4 Doorbell press detection
Sat Feb 13, 2021 1:27 pm
Flenser offline
I'd like to have my Sonos play a doorbell chime when my doorbell is pressed.
I tried using Home Assistant in a Docker container, with some plugins, but it would work for a little bit, then throw some errors. Then I realized that Indigo should be able to do this kind of thing, since it's been running the rest of the house for the past decade. :)
I set up Homebridge and Mosquitto on my Mac, and can get Indigo to find out when a message arrives from the doorbell. I haven't been able to figure out how to key off of only the doorbell-press message though. I'm using the UniFi Protect plugin for Homebridge. The doorbell-related MQTT docs are at https://github.com/hjdhjd/homebridge-un ... cs/MQTT.md
Hmm, it looks like the screenshots went in bottom-to-top. Sorry.
I've also tried subscribing to unifi/protect/E063D*******/doorbell but I either get two notifications in Indigo, or none. I'm very confused and would appreciate any help.
Screen Shot 2021-02-13 at 2.04.22 PM.png (115.91 KiB) Viewed 1760 times
Screen Shot 2021-02-13 at 2.03.58 PM.png (100.92 KiB) Viewed 1760 times
Screen Shot 2021-02-13 at 2.01.58 PM.png (27.26 KiB) Viewed 1760 times
Sat Feb 13, 2021 2:58 pm
Re: UniFi Protect G4 Doorbell press detection
Change your topic subscription to just "unifi"/#".
Change your trigger to:
Match: unifi
Match: protect
Any:
Match: doorbell
End:
Then un-check the Queue Message box unless you're setting up a Shim device for this.
Mon Feb 15, 2021 10:26 am
Flenser offline
That did the trick, thanks.
Now to get the Sonos part working…
Mon Feb 15, 2021 1:25 pm
Aw beautiful I’d been meaning to look into doing this.. and suddenly the answer is right in front of me… serendipitous!
