zigbee2mqtt topic issues
Thu Jul 09, 2020 9:41 am
siclark offline
Re: Shims templates
I have called it Hue Bulb, but it probably doesnt need to be. It looks like zigbee2mqtt handles the bulbs the same and has the same commands for them all, so it could just be bulb.
Or maybe RGBbulb and ColourTempBulb or Color :lol:
Thu Jul 09, 2020 9:43 am
siclark offline
Re: Shims templates
For all these zigbee devices I am following naming convention of zigbee2mqtt/{deviceType}/{uniqueName}
Thu Jan 14, 2021 10:34 am
CliveS offline
I assume that can be done in Node-Red but I just get an error if I try zigbee2mqtt/plug/Salus_SP600/, it has to be zigbee2mqtt/Salus_SP600/
Jan 14 16:10:44 raspberrypi npm[688]: Zigbee2MQTT:info  2021-01-14 16:10:44: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"plug/Salus_SP600"},"type":"entity_not_found"}'
Jan 14 16:10:44 raspberrypi npm[688]: Zigbee2MQTT:error 2021-01-14 16:10:44: Entity 'plug/Salus_SP600' is unknown
Jan 14 16:10:44 raspberrypi npm[688]: Zigbee2MQTT:error 2021-01-14 16:10:44: Invalid JSON '', skipping...
CliveS
Thu Jan 14, 2021 1:22 pm
siclark offline
Re: Shims templates
You mean in the node-red UI for z2mqtt. Yes. That’s where I do it.
Maybe try without the under score?
Thu Jan 14, 2021 5:05 pm
CliveS offline
Re: Shims templates
Tried it without the underscore and same error in the logs and 2 devices in MQTT Explorer.
Screenshot 2021-01-14 at 22.47.29.png (53.81 KiB) Viewed 2090 times
CliveS
Thu Jan 14, 2021 5:10 pm
Re: zigbee2mqtt topic issues
Salus_SP600 IS the device type that he was referring to. It's not the unique name. I think.
Thu Jan 14, 2021 5:21 pm
siclark offline
Re: Shims templates
Thats strange. Was the top one from before you changed the name? What if you restart explorer? Although I guess if you get errors it wont publish. Was the 2nd entry from Indigo?
Out of interest where do you see the error log?
Fri Jan 15, 2021 6:03 am
CliveS offline
Ok, I have changed the friendly name in configuration.yaml from
'0x001e5e09021621b7':
friendly_name: SalusSP600
to
friendly_name: plug/SalusSP600
and now get
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/update-state', payload 'idle'
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/update_available', payload 'false'
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/state', payload 'OFF'
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/power', payload '0'
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/energy', payload '12.33'
Jan 15 11:35:38 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:38: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/linkquality', payload '78'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600', payload '{"energy":12.33,"linkquality":76,"power":0,"state":"ON","update":{"state":"idle"},"update_available":false}'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/update-state', payload 'idle'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/update_available', payload 'false'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/state', payload 'ON'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/power', payload '0'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/energy', payload '12.33'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600/linkquality', payload '76'
Jan 15 11:35:41 raspberrypi npm[1586]: Zigbee2MQTT:info  2021-01-15 11:35:41: MQTT publish: topic 'zigbee2mqtt/plug/SalusSP600', payload '{"energy":12.33,"linkquality":73,"power":0,"state":"ON","update":{"state":"idle"},"update_available":false}'
but in reality it is no different to '0x001e5e09021621b7':
friendly_name: plug-SalusSP600 or plug*SalusSP600
What was you reason for adding the /plug/ in the name?
The error log is from a Terminal window in Pi running the Z2M
pi@raspberrypi:~ $ sudo journalctl -u zigbee2mqtt.service -f
CliveS
Fri Jan 15, 2021 6:19 am
siclark offline
Ok, that looks good now.
The advantage to this method is you only need one trigger for plug, and then use it for all your plugs, ie plug/SalusSP600 and plug/bedroom, plug/living room etc... Otherwise you would need to create triggers for all.
Fri Jan 15, 2021 6:26 am
siclark offline
and thanks, but I run z2m on my mac and journalctl doesnt work on Macs.
