I feel embarrassed to ask but cannot see how to do it
Up to now I have implemented several devices but none with a variable like a dimmer.
Attached is the setup for Study Lamp.
From the main panel selecting turn on of off switches the lamp but the dimmer slider does nothing.
If on the device I set the dimmer action payload to a number between 1 and 100 this correctly sets when the lamp is switched so how do I get the slider to input the value to the device.
I am sure once explained once it will be obvious.
Sending commands directly to the broker works fine
Thanks in advance for your help
BTW the dimmer is a sonoff D1 flashed with Tasmota 9.2
