Aqara Rocker Switch settings changed?
Mon Dec 28, 2020 5:59 am
Something has changed and I am no longer picking up switch presses on my Aqara Double Rocker.
It was previously working, prior to installing the latest Shims update (V0.4.x) and reflashing my CC2531.
The switch presses are detected by Zigbee2MQTT, e.g.:
Zigbee2MQTT:info 2020-12-28 11:43:24: MQTT publish: topic 'zigbee2mqtt/Aqara_double_rocker_1', payload '{"action":"single_left","battery":100,"click":"left","last_seen":"2020-12-28T11:43:24+00:00","linkquality":52,"voltage":3005}'
Zigbee2MQTT:info 2020-12-28 11:49:34: MQTT publish: topic 'zigbee2mqtt/Aqara_double_rocker_1', payload '{"action":"hold_right","battery":100,"click":"right_long","last_seen":"2020-12-28T11:49:34+00:00","linkquality":92,"voltage":3005}'
The Shims definition is as follows:
message_type: '##aqara_double_rocker_1##'
props:
SupportsBatteryLevel: true
battery_payload_key: battery
configDone: true
reports_battery_status: true
state_dict_payload_key: .
state_location: payload
state_location_payload_type: json
uid_location: topic
uid_location_topic_field: '1'
trigger:
match_list: '["Match: zigbee2mqtt", "Match: Aqara_double_rocker_1"]'
queueMessage: true
type: shimGeneric
Here is what the device looks like:
Screenshot 2020-12-28 at 11.53.05.png (61.5 KiB) Viewed 2317 times
The last_seen and linkquality seem out of kilter?
The triggers I had set-up to detect events on this device seem to have reverted to checking against the battery.
I have no doubt it is something I have done but can't immediately see what it is. :?
Mon Dec 28, 2020 7:08 am
Re: Aqara Rocker Switch settings changed?
Why do you use QUOTE tags instead of CODE tags? You loose the indentations, which actually matter for the Shim definitions.
The format of those values matches what's in the message payload, so I don't see anything wrong with them. What's concerning is that the 'action' and 'click' components of the payload aren't showing up in the custom states. Those are the ones that you need for this to be useful as an input device. That topic/payload logging is from the bridge, not from one of the Indigo plugins, right? Does the logging from the plugins match that payload content?
I'd need to see a matching set of logs excerpts from the bridge, the connector, and the shim. I'm wondering if this device is now sending status payloads without the action and click entries when it's otherwise idle. Like a battery update or timeout after the buttons are released.
You say you reflashed the CC2531? Did that cause the bridge MQTT output to change?
Mon Dec 28, 2020 7:22 am
props:
    configDone: true
    uid_location: topic
trigger:
    queueMessage: true
type: shimGeneric
Now in a code block :)
I will capture the rest of what you asked for and post back shortly. :)
Mon Dec 28, 2020 7:28 am
Turned on Shims debugging and got this:
MQTT Shims Debug Aqara Double Rocker 1: processMessages: '##aqara_double_rocker_1##' zigbee2mqtt/Aqara_double_rocker_1 -> {"action":"single_left","battery":100,"click":"left","last_seen":"2020-12-28T13:23:32+00:00","linkquality":99,"voltage":3005}
MQTT Shims Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 115, in runConcurrentThread
File "plugin.py", line 139, in processMessages
File "plugin.py", line 829, in update
UnboundLocalError: local variable 'newProps' referenced before assignment
MQTT Shims Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Doing it without debug it is also now occurring; obviously I didn't notice it earlier :oops:
Mon Dec 28, 2020 7:39 am
Mon Dec 28, 2020 7:46 am
That's fixed it -thanks. :)
Screenshot 2020-12-28 at 13.44.55.png (69.48 KiB) Viewed 2276 times
Mon Dec 28, 2020 8:16 am
Next related issue is that I couldn't get the triggers to work.
It seems that the text field states are being output enclosed in quotation marks (") - see image above.
Ideally, this wouldn't be the case as they are Indigo text states.
Is this a bug or a feature? :)
Mon Dec 28, 2020 8:21 am
I'm not sure. I'm not adding the double quotes, they're in the payload like that. But I would have assumed that the JSON decoder would remove them. I'll need to run some tests to see what's going on.
Mon Dec 28, 2020 11:45 am
I'm declaring this an Indigo bug. ;)
When I do the JSON decode, those fields are returned as type 'unicode'. When I update the state with a value that's type unicode, the quotes are there. If I coerce the values to string before updating the state, the quotes go away.
But I really don't want to coerce them, because they might actually have Unicode characters in them.
What to do?
Mon Dec 28, 2020 12:10 pm
I'm not following - can you show your work as an example?
Mon Dec 28, 2020 12:17 pm
I have just tried this in my Roon Plugin and am not getting any quotes:
key_value_list.append({'key': 'one_line_1', 'value': u"UNICODE Tëst: {0}".format(self.globals[K_ROON][K_ZONES][zone_id][K_NOW_PLAYING][K_ONE_LINE][K_LINE_1])})
gives:
UNICODE Tëst: Piano Concerto No. 18 in B-Flat Major, K. 456: I. Allegro vivace - Salzburger Kammerphilharmonie / Yoon K. Lee / Wolfgang Amadeus Mozart
Admittedly not the same, but it doesn't seem to be adding quotes to the state value?
Mon Dec 28, 2020 12:25 pm
Well, crap, now I can't replicate it. That is, I can't get it to put the quotes in there at all. With or without the string coercion.
When I first set up a test device using Jon's device template and MQTT topic/payload message, I got quotes in some fields as he's showing above. When I determined I was sending Unicode in the value keys of the updateStatesOnServer call, I tried it with coerced ASCII. And the quotes went away. Now I'm trying to do it without the coercion, and no quotes anymore.
I'm so confused.
But, on the other hand, I'm doing this with my refactored Shims plugin, in which I eliminated at least 100 lines of duplicated code. ;)
Edit: Actually, the new version is more like 300 lines shorter.
