MQTT Config help... On M1 :P
Tue Dec 08, 2020 10:17 am
ppespepe offline
Hello everyone!
Hope you are all having a great day so far. Some quick questions if I may.
I know Big Sur/M1 is not supported but in case anyone can give me a hand because somehow I don't think it has nothing to do with the M1 thing or the Big Sur or even the ocean at the side of Big Sur...
I'm getting a weird behavior on MQTT, I think is because I messed it up badly with the install of mosquitto. Somehow I remember it was only a matter of "brew install mosquitto" and off you went but now I had to change something on the conf file for it to accept externel (to the pc where it is running) connections.
I started migrating from a very old Mac Mini Late 2012 i7 2.3 with SSD and yada, yada, yada to a shinny new M1 (the basic, cheapest one) and everything is working great but MQTT...
Anyway, here it comes:
d with result code 1
   MQTT Connector                  MQTT Broker 1: Subscribing to: home/# (0)
   Trigger                         SceneSwitch 1 Subscribe
   MQTT Connector Error            MQTT Broker 1: Disconnected with result code 1
If I reload the Plugin, everything start to work flawlessly again... for a while :D
Below the SceneSwitch 1 Subscribe config:
Screen Shot 2020-12-08 at 10.02.31 AM.png (372.13 KiB) Viewed 1008 times
Any ideas?
For the most part, everything is running extremely well on this entry level 8GB of RAM and 256 of Storage... So if you are thinking about getting into one, even when everything but SecuritySpy is running under Rosetta2, this thing works wonderful and uses almost no electric power... which is in my book, how a HomeAutomation device should work.
Even Indigo Touch works great :P
M1 Indigo with touch.jpg (407.54 KiB) Viewed 1008 times
Thanks in advance!!! :P
PP
Tue Dec 08, 2020 11:50 am
ppespepe offline
Re: MQTT Config help... On M1 :P
Oooooooops... as it appears, al that was needed is to reboot the mac... I didn't reboot anything after mosquitto install nor considered it was necessary but for whatever reason, it appears to be working flawlessly after reboot :D
Tue Dec 08, 2020 12:09 pm
That was easy.
