Newbie help required - sending mqtt events from Indigo
Wed Oct 21, 2020 9:35 am
anupchavda offline
Hi
I have an LED device that uses MQTT subscriptions to change colour depending on the message recieved. What i want to do is create a workflow that takes the alarm status (alarm_armed=true/false) to push it to my mosquitto broker which then in turn is read by the device to change colour based on those 2 variables
How would i go about pushing events from indigo to my mosquitto server?
Wed Oct 21, 2020 10:39 am
Re: Newbie help required - sending mqtt events from Indigo
Use the MQTT Connector plugin, and create a Broker device that's configured to communicate with your Mosquito server.
Then use the "MQTT Connector Actions" -> "Publish Message" action to send the message. The topic and payload will depend on the specs for the LED device.
Screen Shot 2020-10-21 at 12.36.08 PM.png (215.61 KiB) Viewed 1195 times
Screen Shot 2020-10-21 at 12.36.20 PM.png (189.59 KiB) Viewed 1195 times
Wed Oct 21, 2020 2:19 pm
anupchavda offline
Thanks for this.
My setup is that i have a raspberry pi with Mosquitto on it...its running actively and its internal IP is 192.168.1.170
I am able to send messages from the server by using a command such as: "mosquitto_pub -h localhost -t "dsc" -m "false"" and this works correctly (it makes node-red do the action i was expecting)
I am now looking to extend this further by getting indigo to do the trigger.
I installed the MQQT Connector Plugin and on the setup screen, i have the following:
Section: Connection Info
IP Address or Hostname: 192.168.1.170
Port: 1883
MQTT PRotocol: MQTTv311
Transport protocol: TCP
Username: <pi username>
Password: <pi password>
use SSL/TLS < unchecked>
when i activate the plugin, my log shows as "MQTT Connector Error MQTT: Disconnected with result code 1
What am i doing wrong?
Thanks for the help!
Wed Oct 21, 2020 2:22 pm
You would not use the rPi username and password. You would use the one configured for Mosquitto, or leave blank if you don't have them set up.
Wed Oct 21, 2020 5:29 pm
anupchavda offline
i've removed the username and password and i'm still getting the disconnection error code of 1 not sure how to set this up now
Wed Oct 21, 2020 6:12 pm
I recommend you get an MQTT client like http://mqtt-explorer.com to test your connection from the Indigo machine to your rPi MQTT server. Once you have that working, then using the same info in the MQTT plugin should just work.
I suspect you don't have the firewall rules on the rPi set up properly to allow connections from outside systems.
