Shims error and feature request
Sat Aug 15, 2020 2:00 pm
kmarkley offline
I'm trying to bring my 3D printer status into indigo via octoprint and MQTT. I have it working for key states, but am encountering an error when using the Multi-State Key:
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 107, in runConcurrentThread
  File "plugin.py", line 132, in processMessages
  File "plugin.py", line 416, in update
StandardError: LowLevelBadParameterError -- illegal character in XML tag name or value
This is apparently because some JSON keys begin with an underscore. Here's a sample payload:
"state_string": "Operational"
"_timestamp": 1597520731
"_event": "PrinterStateChanged"
"state_id": "OPERATIONAL"
Would it be possible to strip leading underscores when creating device states?
Relatedly, would it be possible to (optionally) define a display state for on/off sensor devices? In my case, I'd like the display state to equal the "state_string" JSON key and the the on condition to be "state_string" == "Operational".
Thanks.
Sat Aug 15, 2020 2:04 pm
Re: Shims error and feature request
Would you mind creating GitHub issues for the key error?
For the other, once the key error is fixed you can probably get what you want using the Masquerade plugin. If that's not going to work, maybe I can do something in Shims.
Sat Aug 15, 2020 2:11 pm
kmarkley offline
Done
