Shims templates
Posted: Thu Jul 09, 2020 9:11 am
Aqara temperature/humidity sensor
Hue colour temp bulb
Hue colour bulb
Hue Remote
Aqara Opple switch
- Code: Select all
message_type: '##AqaraTemp##'
props:
SupportsBatteryLevel: true
SupportsSensorValue: true
battery_payload_key: battery
battery_payload_type: json
configDone: true
reports_battery_status: true
shimSensorPrecision: '1'
shimSensorSubtype: Temperature-C
state_dict_payload_key: .
state_location: payload
state_location_payload_key: temperature
state_location_payload_type: json
state_location_topic_field: '0'
uid_location: topic
uid_location_topic_field: '2'
trigger:
match_list: '["Match: zigbee2mqtt", "Match: AqaraTemp", "Any: ", "End: "]'
queueMessage: true
type: shimValueSensor
- Code: Select all
message_type: '##HueBulb##'
props:
SupportsColor: true
SupportsStatusRequest: true
SupportsWhite: true
SupportsWhiteTemperature: true
action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/set
brightness_scale: '255'
color_temp_payload_key: color_temp
color_temp_scale: Mirek
color_value_payload_key: color
dimmer_action_payload: '{"state": "ON", "brightness": {{brightness}} }'
dimmer_action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/set
off_action_payload: 'OFF'
on_action_payload: 'ON'
rgb_scale: '255'
set_rgb_template: '{"state":"ON","brightness":{{brightness}},"color":{"r":{{redLevel}},"g":{{greenLevel}},"b":{{blueLevel}}}}'
set_rgb_topic: zigbee2mqtt/HueBulb/{{uniqueID}}/set
set_temp_template: '{"state":"ON","brightness":{{brightness}},"color_temp":{{color_temp}}}'
set_temp_topic: zigbee2mqtt/HueBulb/{{uniqueID}}/set
state_location_payload_key: state
status_action_payload: '{"state": ""}'
status_action_template: zigbee2mqtt/HueBulb/{{uniqueID}}/get
uid_location: topic
value_location_payload_key: brightness
trigger:
match_list: '["Match: zigbee2mqtt", "Match: HueBulb", "Any: ", "End: "]'
queueMessage: true
type: shimColor
Hue colour bulb
- Code: Select all
props:
SupportsColor: true
SupportsRGB: true
SupportsWhite: true
color_space: HueC
rgb_scale: '255'
set_rgb_template: '{"state":"ON","brightness":{{brightness}},"color":{"x":{{x}},"y":{{y}}}}'
uid_location: topic
trigger:
queueMessage: true
type: shimColor
Hue Remote
- Code: Select all
message_type: '##HueRemote##'
props:
SupportsOnState: true
shimSensorSubtype: Generic
state_location_payload_key: action
uid_location: topic
trigger:
match_list: '["Match: zigbee2mqtt", "Match: HueRemote", "Any: ", "End: "]'
queueMessage: true
type: shimOnOffSensor
Aqara Opple switch
- Code: Select all
MQTT Shims
message_type: '##AqaraOpple##'
props:
state_location_payload_key: click
uid_location: topic
trigger:
match_list: '["Match: zigbee2mqtt", "Match: AqaraOpple", "Any: ", "End: "]'
queueMessage: true
