zigbee2mqtt & zigbee USB for Hue bulbs
Fri Jul 03, 2020 8:41 am
FlyingDiver online
Re: zigbee2mqtt & zigbee USB for Hue bulbs
siclark wrote:
I am finally getting back to these. Looking at the Aqara wireless switches to control the light bulbs. They work great for on/off, and dimming zwave bulbs, but the MQTT color device which is the bulb doesnt appear to support Brighten/Dim By or Start Brightening/Dimming. which I would love be able to use with the hold / release commands from the Aqara wireless switches.
Is that an easy change?
Not sure. I'll take a look.
Fri Jul 03, 2020 9:18 am
FlyingDiver online
Try 0.3.2: https://github.com/FlyingDiver/Indigo-S ... /tag/0.3.2
This has both the brightness/onOffState change requested, and also implements BrightenBy and DimBy. The start/stop commands would require additional templates for the MQTT commands and would be a lot more work.
0.3.X is still pre-release. Let me know if these are stable enough to be released on the Plugin Store.
Fri Jul 03, 2020 10:07 am
siclark offline
Thanks will do.
Brighten by would normally be fine but the hold doesn’t seem to change anything in the mqtt message, ie no time or counter so nothing for the indigo trigger to react to so holding would just trigger once rather than multiple times.
I need to spend a a little more time on these switches.
I can use double click to activate brighten by set amount and that will work. Its much better than what I have today it had with the hue hub
Fri Jul 03, 2020 10:13 am
FlyingDiver online
So does it send a message when you start to hold (press down) and another when you release? If so, there's probably something you could do with repeating timers and a stop timer on the release.
Or maybe a pester device.
Fri Jul 03, 2020 10:25 am
siclark offline
Exactly. Yes I was thinking same. Just a bit more complicated.
Fri Jul 03, 2020 12:31 pm
siclark offline
I am getting this error now
   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 107, in runConcurrentThread
  File "plugin.py", line 131, in processMessages
  File "plugin.py", line 453, in update
NameError: global name 'state_list' is not defined
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Jul 03, 2020 12:52 pm
FlyingDiver online
Fri Jul 03, 2020 12:58 pm
siclark offline
Thbanks..
On and off work without error now, but get this on Brighten by
   MQTT Shims Error                Error in plugin execution ExecuteAction:
  File "plugin.py", line 904, in actionControlDevice
NameError: global name 'dev' is not defined
Fri Jul 03, 2020 1:30 pm
FlyingDiver online
Thu Jul 09, 2020 5:01 am
siclark offline
Had some issues with the Hue Remote and its taken me a few days to get this working again, so not been playing with the latest version.
Brighten by and dim by are working well now.
I have turned off my hue hub and deleted all the old Hue devices from Indigo as well as my previous devices that used the node-red solution.
I am sure there will be a few more tweaks that could be made but I am happy with how this is working now.
Thanks for your work on this, and its great we can have zigbee devices of all sorts working with Indigo without an expensive hub.
Simon
