I am trying to learn something about mqtt. And to do that I want to set up some communication between Indigo and Home assistant over mqtt. I am able to publish from indigo, and I am able to see the "package" on the developer tool in HA.
But for some reason I am not able to update any states in HA. Is there something with they way it is formatted in the mqtt plugin that could cause this?
- Code: Select all
Message 7 received on indigo/variables/1085500151/update at 6:23 PM:
{ 'name': MQTT_Test, 'variableId':1085500151, 'value': ON }
QoS: 0 - Retain: true
Could it be possible to add support for the HA MQTT Discovery feature?
https://www.home-assistant.io/docs/mqtt/discovery/
Håvard
