Take a look at this page: OTA updates
I am not seeing the update_available at the moment.
Looks like you have to publish a message to zigbee2mqtt to perform the update.
autolog wrote:Take a look at this page: OTA updates
autolog wrote:I think it is because that function isn't available in the MQTT Shim plugin. It effectively tells Indigo to zero the Total Usage. It isn't a zigbee2mqtt problem AFAICS. I expect it will be added in due course once it is reported to Joe.
FlyingDiver wrote:autolog wrote:I think it is because that function isn't available in the MQTT Shim plugin. It effectively tells Indigo to zero the Total Usage. It isn't a zigbee2mqtt problem AFAICS. I expect it will be added in due course once it is reported to Joe.
Actually that command is supposed to tell the device to reset it’s counter. I haven’t implemented it in the shim because I have no idea what it’s supposed to look like. Does the documentation for the Salus plug show how to do that via MQTT?
