I am using sonoff switches flashed with tasmota and MQTT connector I can operate the switches from indigo.
One problem if you operate the switches from Alexa or the device indigo does not know the status has changed.
Is there a way round this?
wasimpson wrote:I am using sonoff switches flashed with tasmota and MQTT connector I can operate the switches from indigo.
wasimpson wrote:Sorry if subscribed to the wrong topic but i was not sure exactly where the question should be posted as I assume there should be a way to have indigo check the status of the device via MQTT?
