Device turning off - Shims or MQTT issue?
Tue Aug 13, 2019 4:59 am
AndyVirus offline
OK. Different issue. (Sorry did not know where to post, Shims or MQTT)
On my Switch Device. After 4 mins a blank message is sent to the /cmd/sonoff/POWER topic which turns off my switch.
Pressing ON sends ON
Pressing Off sends OFF
Every 3-4 mins a blank message is sent which results in switch turning OFF.
13 Aug 2019 at 11:45:14
   Shims Debug                     Owl Lamp MQTT: actionControlDevice: Turn On
   Shims Debug                     received notification of MQTT message type ##SONOFF## from MQTT Broker
   Shims Debug                     Owl Lamp MQTT: message_handler: '##SONOFF##' stat/sonoff_owl_lamp/RESULT -> {"POWER":"ON"}
   Shims Debug                     Owl Lamp MQTT: Updating state to True
13 Aug 2019 at 11:48:10
   Shims Debug                     Owl Lamp MQTT: message_handler: '##SONOFF##' stat/sonoff_owl_lamp/RESULT -> {"POWER":"OFF"}
   Shims Debug                     Owl Lamp MQTT: Updating state to False
13 Aug 2019 at 11:50:10
13 Aug 2019 at 11:51:06
Screenshot 2019-08-13 at 11.56.22.png (79.16 KiB) Viewed 1656 times
Tue Aug 13, 2019 5:27 am
Re: Introducing the Shims plugin
It sure looks like your broker is actually sending out those Power Off messages. They're not blank, the payload is there.
Do you have MQTT Explorer or MQTT Box running? It would be good to see if another client is seeing them (or not).
Do you have multiple Broker devices defined? Try changing the trigger to use the one you're actually using.
Tue Aug 13, 2019 5:48 am
AndyVirus offline
I say its blank becuse watching the topic using MQTT.fx on my mac, I can see that there is a publish to /cmnd/sonoff/POWER but nothing is in the payload. If i send ON or OFF then ON or OFF is published but every few mins a payload of blank is sent:
I have change from Any Broker to the specific broker (slip of finger when setting up) and same issue.
MQTT Debug Sonoff Trigger: Removing Trigger
MQTT Debug Sonoff Trigger: Adding Trigger (This was me changing the broker in the Trigger)
13 Aug 2019 at 12:32:19
13 Aug 2019 at 12:34:35
Payload when ON is clicked
Blank payload sent every few mins
no payload.png (108.76 KiB) Viewed 1641 times
Tue Aug 13, 2019 5:56 am
The topic '/cmnd/sonoff_owl_lamp/POWER' has no payload. Without one, it's a request status command. But your trigger is on "stat/sonoff_owl_lamp/RESULT", which has a JSON payload of "{"POWER":"OFF"}".
So it looks like something is sending out the status request (POWER topic), which is replying with a RESULT payload, which is causing your lamp to turn off. Do you have any other devices connected to the broker? It's almost like you have two devices with the same name.
Tue Aug 13, 2019 6:07 am
AndyVirus offline
How weird! It seems to happen with MQTT and Shims plugins disabled so totally something local. Sorry to waste your time.
I only have 1 broker and 1 Sonoff (powered). I have connected to the tasmota gui and see if there is some auto off or something set and cant see anything. Will reset the thing. Something is going weird. Wish i could see for sure in MQTT tools who (ip) sent the topic publish. Must be a way...
On a side note, while looking though setting i can see that Tasmota can emulate WeMo and Philips Hue Bridge if you need another example. I know you have WeMo but Hue might be interesting.
Emulation
None
Belkin WeMo single device
Hue Bridge multi device
Thanks for you help and patience.
Tue Aug 13, 2019 6:09 am
You would need to restart your Mosquitto broker with the --verbose option for it to log (to stderr) the client actions. That should tell you where the message is coming from.
The client doesn't get that info, so you have to use the broker to debug it.
Tue Aug 13, 2019 6:13 am
AndyVirus offline
Will give that a go. Need to shut the Smappee up first as that publishes ever second.
Annoyingly since connecting to the GUI of Tasmota (or pressing the button on the Sonnoff to turn on the Lamp a), the RESULT topic has not changed and neither has any more blank POWER publishes occurred. Grrr.
Tue Aug 13, 2019 6:17 am
Re: Device turning off - Shims or MQTT issue?
I move these posts to their own thread...
Tue Aug 13, 2019 2:19 pm
cuhouse offline
Andy,
I saw this today on the Tasmota WiKi referring to ghost switching. Might be something you would want to check? https://github.com/arendst/Sonoff-Tasmota/wiki/PowerOnState-Configuration#side-effects-with-using-mqtt-messages
Go into the Tasmota console of the device and type powerretain. If the output is {"PowerRetain":"OFF"} then probably not your issue. If it is on, you may want to check if the broker has retained flag.
I use MQTT Explorer and you can see whether it has a retained flag on your broker. It also allows you to clear it.
May help.
Jody
Edit: I just watched the video tutorial referenced in the link above and there are a few other things you could try.
Screen Shot 2019-08-13 at 4.06.12 PM.png (54.76 KiB) Viewed 1536 times
Indigo 2022.1.2, Big Sur v11.7.1, Dedicated late 2014 Mac Mini, PowerLinc 2413U.
Tue Aug 13, 2019 11:50 pm
AndyVirus offline
I will take a look. Definitely sounds like the reason. I cant make it happen now. Seemed to stop totally after i restarted the broker in verbose mode so retained does make sense. I did see some retained flags on certain topics using MQTT.fx. Thanks for the info!
I can say with absolute certainty that this is NOT a plugin issue with Shims or MQTT plugin at least.
Wed Aug 14, 2019 4:28 am
There was a bug in the first couple MQTT plugin versions that all messages were getting sent with retain = True. That's been fixed. So maybe that's how it got set originally.
