For perpetuity, this sketch allows the arduino with ethernet shield to connect to network, subscribe to mqtt, receive payload, then control a big a$$ stepper motor using an a4988 driver the payload is formatted in Indigo as (no single quotes) '{"top":200, "bottom":50, "left":-200, "right":100}'
Thanks FlyingDiver!
It's time for me to get weird with controlling motors from Indigo
- Code: Select all
// This sketch allows the arduino with ethernet shield to connect to network, subscribe to mqtt,
// receive payload, then control a big a$$ stepper motor using an a4988 driver
// The payload is formatted in Indigo as (no single quotes) '{"top":200, "bottom":50, "left":-200, "right":100}'
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
#include <AccelStepper.h>
#include <ArduinoJson.h>
// Define stepper motor connections and motor interface type. Motor interface type must be set to 1 when using a driver:
#define leftDirPin 2
#define leftStepPin 3
#define motorInterfaceType 1
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, leftStepPin, leftDirPin);
// Ethernet and MQTT related objects
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
// Set your MAC address and IP address here
byte mac[] = { 0xDE, 0xAA, 0xBB, 0xCC, 0xDD, 0x00 };
IPAddress ip(192, 168, 1, 159);
//Enter your mqtt server configurations
const char* mqttServer = "192.168.1.REDACTED"; //Enter Your mqttServer address
const int mqttPort = 1883; //Port number
const char* mqttUser = "REDACTED"; //User
const char* mqttPassword = "REDACTED"; //Password
void setup()
// Useful for debugging purposes
Serial.begin(9600);
// Set the maximum speed in steps per second:
stepper.setMaxSpeed(1000);
// initialize the Ethernet shield using DHCP:
Serial.println("Obtaining an IP address using DHCP");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to obtain an IP address");
// check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware)
Serial.println("Ethernet shield was not found");
// check for Ethernet cable
if (Ethernet.linkStatus() == LinkOFF)
Serial.println("Ethernet cable is not connected.");
// BELOW IS ERROR CHECKING FOR IP CONNECTIVITY
Serial.print("- Arduino's IP address : ");
Serial.println(Ethernet.localIP());
Serial.print("- Gateway's IP address : ");
Serial.println(Ethernet.gatewayIP());
Serial.print("- Network's subnet mask : ");
Serial.println(Ethernet.subnetMask());
Serial.print("- DNS server's IP address: ");
Serial.println(Ethernet.dnsServerIP());
// Ethernet takes some time to boot!
delay(3000);
// Set the MQTT server to the server stated above ^
mqttClient.setServer(mqttServer, mqttPort);
mqttClient.setCallback(MQTTcallback);
while (!mqttClient.connected()) {
Serial.println("Connecting to MQTT...");
if (mqttClient.connect("NewEthernetShield", mqttUser, mqttPassword )) {
Serial.println("Connected");
} else {
Serial.print("failed with state ");
Serial.println(mqttClient.state()); //If you get state 5: mismatch in configuration
delay(2000);
mqttClient.publish("ethernetshield/test", "Hello from EthernetShield v2");
mqttClient.subscribe("ethernetshield/test");
//////////////////////////////////////THIS IS THE THING////////////////////////////////////////
void MQTTcallback(char* topic, byte* payload, unsigned int length) {
int speed = 400;
int targetPosition;
StaticJsonBuffer<54> jsonBuffer;
//char inData[80]; // I THINK THIS IS THE CAHR ARRAY INTO WHICH THE BYTE ARRAY GOES< STARTING WITH BYTe NUMBER 26 WHY???
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Payload: ");
for(int i =0; i<length; i++)Serial.print((char)payload[i]);
Serial.println();
//THIS NEXT PART USES A {POINTER TO THE ROOT OF THE PARSED JSON, I THINK
JsonObject& root = jsonBuffer.parseObject((char[])payload);
//CHECK THE CONTENTS
Serial.println("Instructions:");
Serial.print("Top:");
Serial.println((int)root["top"]);
Serial.print("Bottom:");
Serial.println((int)root["bottom"]);
Serial.print("Left:");
Serial.println((int)root["left"]);
Serial.print("Right:");
Serial.println((int)root["right"]);
//TELL IT WHAT ROLLER's INFO TO TURN
targetPosition = (int)root["left"];
// SET CURRENT POSITION
stepper.setCurrentPosition(0);
Serial.println("Stepper current position set to 0");
Serial.print("Stepper target position is:");
//MAKE THE SPEED NEGATIVE IF TARGET IS NEGATIVE
if(targetPosition<0) speed*=-1;
int lastPosition = 0;
while(stepper.currentPosition() != targetPosition)
stepper.setSpeed(speed);
stepper.runSpeed();
/*int currentPosition = stepper.currentPosition();
if(currentPosition%20==0 && currentPosition>lastPosition){
Serial.print(currentPosition);
Serial.print(" ");
lastPosition = currentPosition;
Serial.print("\n");
Serial.println("Done");
Serial.println("-----------------------");
void loop()
mqttClient.loop();
