Introducing the Shims plugin
Mon Aug 12, 2019 6:47 am
FlyingDiver online
Re: Introducing the Shims plugin
Short answer is, I noticed the same behavior yesterday and have been reworking the code to make this work better. The stop/start is fixed. This is a Sonoff device, like the SV?
What Topic are you triggering on? I stopped using the stat/sonoff/POWER topic and switch to using stat/sonoff/RESULT topic which has a JSON payload that looks like '{"POWER":"OFF"}'.
I'll post 0.0.2 later today that should fix the stop/start issue.
Mon Aug 12, 2019 6:50 am
FlyingDiver online
I'm doing some testing for when an additional relay output is connected to the SV. I was having some issues reliably detecting which switch (relay) I was getting the status of. I want to work on that a bit before I release 0.0.2
Mon Aug 12, 2019 7:19 am
AndyVirus offline
Yes this is a Sonoff device. I am triggering on stat/sonoff/POWER but happy to switch to the RESULT topic.
Shout whenever 0.0.2 is ready and Ill happily re-test.
Thanks for all this BTW. Really appreciate all your effort/time/work/patience/skill on MQTT and Indigo!
Mon Aug 12, 2019 7:38 am
AndyVirus offline
Also setup a Generic Sensor to monitor totalPower of Smappee, works well but at 1 second intaval updates my log was flooded with
Shims Total Power: Stopping Device
Shims Total Power: Starting Device
Disabled for now. Just FYI.
Mon Aug 12, 2019 8:19 am
FlyingDiver online
Release 0.0.2 - https://github.com/FlyingDiver/Indigo-S ... /tag/0.0.2
Added Status Update control to Switch (relay) device.
Made JSON default for state location.
Fixed issue when key is not in the JSON payload.
Fixed repeated device stop/start.
Mon Aug 12, 2019 8:57 am
AndyVirus offline
That has stopped the Starting/Stopping for both Switch and Generic Sensor.
On/Off is still not consistent for state though. I sometimes have to hit off a few times for the state to change. Usually for off but sometimes for on.
Seems like the Publish is publishing each time i press on or off consistently, it just the state that is not consistent. I have changed over to RESULT as JSON instead of RAW on POWER topic. Both yield the same result and issue.
Let me know if you need me to to try anything in my environment to assist with anything.
Mon Aug 12, 2019 8:58 am
FlyingDiver online
Turn on debug logging, press the button a couple times, then post the log segment.
Mon Aug 12, 2019 9:07 am
AndyVirus offline
OK. I cant make it not work now :-)
I put the wrong plugin into debug and restarted the plugin (MQTT Plugin) and then My Shim device did nothing at all.
I then put MQTT back to Information Only and put the right plugin (Shims) into debug and restarted the plugin (as it was doing nothing when pressing on or off) and all worked consistently.
Turned off debug and still works consistently.
So...if it happens again, ill put "shims" in debug as you asked and try again :-)
Mon Aug 12, 2019 12:09 pm
FlyingDiver wrote:
autolog wrote:
In another post, you replied:
FlyingDiver wrote:
... Oh wait, no, the Smappee uses arrays of values in the payload. Can't help you with that (yet).
Looking forward to the yet update. :wink:
And I forgot the reply to this when I posted 0.0.1 yesterday. The new key syntax you want is channelPowers.[0].power. Done.
Just tried it and it works - thanks. :)
Tue Aug 13, 2019 4:11 pm
FlyingDiver online
Release 0.0.3 - https://github.com/FlyingDiver/Indigo-S ... /tag/0.0.3
Now has support for device controlled dimmer devices. Assuming it's controlled by a PWM pin on the device using Tasmota.
I've tested a set-up where the Sonos was configured with one or two relay outputs, and one PWM (dimmer) output. That works fine. Trying to do two PWM outputs doesn't work, as the Tasmota firmware assume if you have two PWM outputs configured, they're both connected to the same light and one is controlling color temp. I haven't figure out a way around that. Probably won't bother. Real life results using actual MQTT controlled lights or dimmers would be appreciated.
Sat Aug 17, 2019 9:19 am
FlyingDiver online
Release 0.0.4 - https://github.com/FlyingDiver/Indigo-Shims/releases
Handles backlogged messages now.
Warning: Plugin has been renamed. Disable and remove old plugin before installing this one. Nothing else will need to be changed.
Sat Dec 28, 2019 7:27 am
Colly offline
cuhouse wrote:
I have read that another manufacturer (Shelly) has a device that will run with their app or can run MQTT. I am planning to order one to try with Flying Diver’s Plug-ins. They run around US $29. Much more expensive than Sonoff but the one I am looking at is UL listed.
Jody
( Loving these new MQTT plugins)
Did you ever get to try the Shelly device? https://shop.shelly.cloud They seem to have a good range of products at a very reasonable price.
Sat Dec 28, 2019 5:19 pm
cuhouse offline
Colly,
I have been using a Shelly HT in my refrigerator for over 4 months. I depleted the first battery within the first month from my initial testing/trial and error. I had to turn off the humidity wakeup. as the humidity change is too much of a swing in the refrigerator when the door is opened and it would cause the HT to send updates too often. The more frequent the WiFi transmits the shorter the battery life. I have been using it on the current battery for 3 months.
I am using the Shelly firmware but have the their Shelly Cloud option turned off. I have the optional MQTT client running and using it with Flying Divers MQTT plugin. Very happy with the HT and the plugin.
I placed the HT behind the bottom drawer in the refrigeration section. I have a trigger set to alert my wife and I if the temperature is greater than 50 F. I have a few other notifications set within Indigo also. I plan to purchase a Shelly 2.5 soon since it has the UL approval. Also just got a $30 gift card for Christmas :D
Screenshot 2019-12-28 at 5.08.35 PM.png (64.02 KiB) Viewed 2969 times
Indigo 2022.1.2, Big Sur v11.7.1, Dedicated late 2014 Mac Mini, PowerLinc 2413U.
Sat Dec 28, 2019 5:23 pm
Colly offline
Excellent, I’ll place an order for a few to try out. Interested in the 50A energy monitoring. Thanks for the update.
Sat Dec 28, 2019 6:28 pm
cuhouse offline
I just placed an order for a Shelly 2.5. I will most likely flash it with Tasmota. Thanks for the prompting :D
