Introducing the Shims plugin
Wed Feb 12, 2020 12:17 pm
siclark offline
Re: Introducing the Shims plugin
Hi, I am new to MQTT and struggling to get my first device setup in Shims.
Its an Aqara temp and humidity sensor and it publishes its payload like the attached from MQTT explorer , and I have set up my Shims device as per attached.
The broker devices shows its receiving the message but the Shims device is not updating. Is this to do with the format of the JSON, or likely my setup of the device.
Any pointers would be appreciated.
Simon .
Screenshot 2020-02-12 at 18.15.04.png (228.33 KiB) Viewed 2695 times
Screenshot 2020-02-12 at 18.14.18.png (83.06 KiB) Viewed 2695 times
Wed Feb 12, 2020 12:27 pm
"Master" is the third field in the topic, so you need to change the "Topic Field" to 2.
If that still doesn't work, make sure you've got a trigger set up for that topic.
Wed Feb 12, 2020 3:43 pm
siclark offline
Cheers.. had tried 2 as well, and just changed to that, but no luck.
The trigger bit was where I was most confused. Yes I have one setup, but not entirely sure its correct. I only have trigger, no action set. I think thats correct? I have tried lots of combinations of Match strings here.
Screenshot 2020-02-12 at 21.42.13.png (121.58 KiB) Viewed 2665 times
Wed Feb 12, 2020 3:46 pm
Your topic is 'zigbee2mqtt/Aqara/Master'. So you need:
Match:  zigbee2mqtt
Match:  Aqara
Any:
End:
You need a term in the list for each component of the topic, left to right --> top to bottom. Except you can skip trailing topic components using the 'End:' term.
Wed Feb 12, 2020 4:02 pm
siclark offline
Thanks... still no joy. How do I enter the End: terms. I only see Match or Any in the drop down?
Wed Feb 12, 2020 4:06 pm
Oops. That version was in pre-release state. I just updated the release version.
Wed Feb 12, 2020 4:29 pm
siclark offline
I dont see the End: option on the 0.1.3 version I just downloaded, but regardless , I have this working now.
Thanks, another amazing contribution the the Indigo world.
I now have a zigbee temp and humidity sensor reporting into Indigo via a zigbee USB stick on a Pi, talking to my MQTT broker on my NAS, to Indigo on the Mac, and reports in the blink of an eye!
I'll get a full write up done soon as this is a really easy (once you understand MQTT and Shims) setup that gives access to a new range of cheap sensors.
Wed Feb 12, 2020 8:56 pm
cuhouse offline
siclark wrote:
I dont see the End: option on the 0.1.3 version I just downloaded.
I think you want to update the MQTT Connector Plugin to 0.3.2 to get the update for the “End” Completion.
Indigo 2022.1.2, Big Sur v11.7.1, Dedicated late 2014 Mac Mini, PowerLinc 2413U.
Thu Feb 13, 2020 1:54 pm
siclark offline
Good point, all working now.
What I dont seem to be able to work out is how to do the multi states, as it doesnt appear I have a dict in the payload json? Or is my lack of python knowledge showing?
Thu Feb 13, 2020 1:57 pm
If there isn't a nested dict, then you can't do multi-states. There is an edge case where it might be useful to do multi-states with the top-level dict, but I didn't code it that way originally. I should do that one of these days.
Thu Feb 13, 2020 2:20 pm
Pre-release 0.2.0: https://github.com/FlyingDiver/Indigo-S ... /tag/0.2.0
Adds battery level support in Indigo UI
Adds multi-states support to all device types
Adds support for multi-states key at top level of message payload
If the payload looks like this:
{ "battery":100, "voltage":3145, "temperature":24.95, "humidity":38.72, "pressure":1012, "linkquality":36}
Then putting a period (".") in the multi-states field will give you:
Screen Shot 2020-02-13 at 3.22.21 PM.png (90.59 KiB) Viewed 2597 times
Thu Feb 13, 2020 2:37 pm
siclark offline
Awesome.. that works!
Sat Feb 22, 2020 1:43 pm
Pre-release 0.2.3: https://github.com/FlyingDiver/Indigo-S ... /tag/0.2.3
Added generic device (no state value).
Added capability to show energy usage in Indigo UI.
Energy UI (and now battery UI) are available for JSON payloads only.
Added info level logging of sent actions.
Wed Apr 22, 2020 2:42 am
jaknudsen offline
May I ask how you got it to work? :) I believe I have set up Broker device, trigger and sensor devices correctly, but the sensor devices are not updating.
edit: Found it! I had a typo in the Topic Subscriptions settings of the Broker device :oops:
Wed May 06, 2020 2:06 pm
shapa offline
Controlling sonoff device (tasmota), works fine.
But the device status in Indigo UI is not changing (always staying "off") and the last update is always "2000-01-01 00:00"
What I'm doing wrong? :)
Screenshot 2020-05-06 at 21.05.44.png (102.34 KiB) Viewed 2089 times
