MQTT comunication between Indigo and Home assistant
Mon Mar 30, 2020 10:53 am
Re: MQTT comunication between Indigo and Home assistant
Here's the relevant lines from the log. (Z-wave Debug is not useful here).
   MQTT Connector Debug            MQTT: Message received: indigo/devices/1803139087/command/set, payload: off
   MQTT Connector Debug            MQTT: Device command match, DevId: 1803139087, command: set, payload: off
   Z-Wave                          sent "Spotlight - TV Area - Living Room" off
   MQTT Connector Debug            MQTT: Message received: indigo/devices/1803139087/command/brightness, payload: 100
   MQTT Connector Debug            MQTT: Device command match, DevId: 1803139087, command: brightness, payload: 100
   Z-Wave                          sent "Spotlight - TV Area - Living Room" set brightness to 100
You can see that HA sent a brightness 100. So this is an HA issue, not an MQTT plugin issue.
Mon Mar 30, 2020 10:57 am
haavarda offline
Thanks a lot for the clarification and your support!
Håvard
