No triggering (almost)
Tue Jun 01, 2021 4:08 pm
Hax offline
Howdy.
Doing a roll your own with some ESP8266's.
First project as a 'Hello Omicron Persei 8' project is a relay and PIR sensor.
I can send a message from Indigo to turn on/off the relay. Works as expected.
But getting the PIR to trigger a trigger in indigo just ain't happening. (I did get it to fire the trigger if I use the ANY.)
Trigger Event Settings:
Broker: A-MQTT-Garage
Topic string matching:
Match: 65ON
Match: 65OFF
End: 65ON
I've tried every combo of the matching. The only thing that does cause a trigger to run is ANY, but any value on those subscribed topics cause the trigger.
The messages do come in:
   MQTT Connector Debug            A-MQTT-Garage: Message topic: 65Topic, payload = 65OFF
   MQTT Connector Debug            A-MQTT-Garage: processReceivedMessage: 65Topic, payload: 65OFF
   MQTT Connector Debug            A-MQTT-Garage: Saved states, topic: 65Topic, payload: 65OFF
Tue Jun 01, 2021 4:21 pm
Re: No triggering (almost)
Match: 65TOPIC
End:
You match on the Topic, not the Payload.
