Getting an error can anyone help me with it?
Fri Feb 12, 2021 8:48 am
d1staples offline
Hello,
I'm getting this error with the latest version V 1.0.7, and I got a different error with the previous version, so it has never worked for me. Below is the error. It does look like it's getting data as the Active Watts is changing every 10 seconds when it re-trys.
Thanks in advance, Dan
Sense Home Energy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sense Home Energy Debug IDs: [u'']
Sense Home Energy Debug Active: 4642.50097656w
Sense Home Energy Debug Daily: 10.920795kw
Sense Home Energy Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 221, in runConcurrentThread
File "plugin.py", line 143, in getDevices
KeyError: 'core'
Tue Feb 23, 2021 4:34 pm
Re: Getting an error can anyone help me with it?
Hi Dan
Core is the "Active Watts" device that the plugin creates when you install the plugin.
Can you delete your Active Watts device, then go into Plugins > Sense > Configure Plugin and hit Save. (Don't hit cancel or the routine doesn't run.)
Peter
