NameNotUniqueError
Sat Nov 09, 2019 5:53 pm
Peel offline
NameNotUniqueError
I ended up deleting the sense plugin and all of it's devices, including the plugin, preference file, and log from the Indigo folder within Library, and stopped/restarted the server before reinstalling..
Once I reinstalled, I'm getting the same error that @norcoscia got when he merged two devices: NameNotUniqueError. It's showing up for each device that was created. Further, each device that it does create does not show an on/off icon for, nor any power reading, even on devices that are current on and showing a draw within the sense app itself.
Looking at the plugin.log it looks like after creating all of the devices, it tries to create then a second, and third... time.
Screen Shot 2019-11-09 at 15.07.23.png (137.58 KiB) Viewed 413 times
My Indigo log then gets filled with the same error over and over again every 90 seconds as per my specified polling rate.
Screen Shot 2019-11-09 at 15.37.48.png (98.23 KiB) Viewed 413 times
I've attached the plugin.log from within the com.howartp.sense folder.
plugin.log
(12.29 KiB) Downloaded 17 times
Sun Nov 10, 2019 3:16 pm
Re: NameNotUniqueError
I've just pushed v1.0.5 as a first step towards this.
It's fixed the error I had on my copy of Indigo (which was using Nacrosia's login deails) - I purposely didn't fix my copy manually as I wanted to code a fix for it.
However now it's fixed, I can't see the error any more so please let me know if you still get it - and provide the logs with debugging turned on.
Peter
Sun Nov 10, 2019 4:56 pm
Peel offline
Yes! The devices all now show individual power icons and the power draw for each, and more importantly, no more error messages.
Screen Shot 2019-11-10 at 14.54.37.png (146.18 KiB) Viewed 375 times
Tue Nov 26, 2019 9:21 am
rapamatic offline
I am getting this error now, here's the debug log details... I have merged some devices in the sense app (I don't remember any specifics since I did this a while ago).
Any ideas?
Nov 26, 2019 at 9:16:57 AM
   Sense Debug                     IDs: [u'51860e1c', u'd708ca01', u'core', u'always_on', u'241e147f', u'03847b73', u'6ae38f7e', u'a4052429', u'd17aaac1', u'8e6cc103', u'2004270d', u'kmyOfcBb', u'efd2af83', u'W7P45wlF', u'c6ddcf65', u'ef1139d9', u'6915a118', u'b7d20f08', u'3f60cbee', u'7ca48bfe', u'd6a8cc68', u'unknown', u'49e4d4ef', u'5b78d121', u'4d3aa99e', u'c34a1638', u'4ae068ca']
   Sense Debug                     Active: 4176.89941406w
   Sense Debug                     Daily: 24.41173kw
   Sense Debug                     CSV Output: 2019-11-26 09:16:57.487301,4176
   Sense Debug                     CREATED: Master AC
   Sense Debug                     {u'icon': u'ac', u'id': u'8995a507', u'tags': {u'DefaultMake': None, u'PeerNames': [{u'UserDeviceTypeDisplayString': u'AC', u'Icon': u'ac', u'Percent': 83.0, u'Name': u'AC', u'UserDeviceType': u'AC'}, {u'UserDeviceTypeDisplayString': u'Dryer', u'Icon': u'washer', u'Percent': 4.0, u'Name': u'Dryer', u'UserDeviceType': u'Dryer'}, {u'UserDeviceTypeDisplayString': u'Pool Pump', u'Icon': u'pump', u'Percent': 4.0, u'Name': u'Pool pump', u'UserDeviceType': u'PoolPump'}, {u'UserDeviceTypeDisplayString': u'Power Tool', u'Icon': u'drill', u'Percent': 4.0, u'Name': u'Saw', u'UserDeviceType': u'PowerTool'}, {u'UserDeviceTypeDisplayString': u'Pump', u'Icon': u'pump', u'Percent': 1.0, u'Name': u'Sewage pump', u'UserDeviceType': u'Pump'}, {u'UserDeviceTypeDisplayString': u'Pump', u'Icon': u'pump', u'Percent': 1.0, u'Name': u'Pump', u'UserDeviceType': u'Pump'}], u'OriginalName': u'AC 4', u'DefaultUserDeviceType': u'AC', u'DefaultModel': None, u'DateCreated': u'2019-04-23T11:04:15.026Z', u'Type': u'CentralAC', u'UserDeletable': u'true', u'Pending': u'false', u'DeployToMonitor': u'true', u'UserEditableMeta': u'true', u'user_editable': u'true', u'DefaultLocation': None, u'AlwaysOn': u'false', u'Revoked': u'false', u'TimelineDefault': u'false', u'Mature': u'true', u'UserDeviceTypeDisplayString': u'AC', u'DateFirstUsage': u'2019-04-09', u'ModelCreatedVersion': u'46', u'Alertable': u'true', u'UserMergeable': u'true', u'ModelUpdatedVersion': u'85', u'name_useredit': u'true', u'UserEditable': u'true', u'TimelineAllowed': u'true', u'DeviceListAllowed': u'true'}, u'name': u'Master AC'}
   Sense Error                     NameNotUniqueError
Tue Nov 26, 2019 9:33 am
rapamatic offline
Ok, issue here was I had two devices with the same name in Sense. I renamed one of the devices and all is well now... checking for this type of situation and handling more gracefully is probably something to add to the long term wish list :)
Tue Nov 26, 2019 4:49 pm
rapamatic wrote:
Checking for this type of situation and handling more gracefully is probably something to add to the long term wish list :)
True, and there's already code towards that in the plugin.
Unfortunately Sense doesn't fully use unique constant IDs, and simultaneously allows duplicate names as you've discovered, so I have to refer to the device name in some areas of the code.
I've added another line in my copy, but won't publish it until I get more time to test it.
(If you want to play with your version and test, grab 1.0.6 then add the following at line 201:
               except NameNotUniqueError as e:
                  self.errorLog("Duplicate device found - please ensure Sense devices are all uniquely named")
Peter
