Had to restore to new computer
Posted: Mon Dec 26, 2022 6:18 am
.. and I haven't managed to get your amazing Room plugin to work again.
I had a hardware problem and after 2 fraught days getting a back up, new hardware and a restore, I am a bit stuck with the plugin.
I have tried to delete everything and go for clean re-install, but I think I might have just made things worse.
Any advice gratefully received.
WHEN PLUGIN TRIES TO INITIALISE I GET
Roon Error Error in plugin execution InitializeMain:
File "plugin.py", line 13, in <module>
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/PIL/Image.py", line 100, in <module>
type: dlopen(/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/PIL/_imaging.cpython-310-darwin.so, 0x0002): tried: '/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/PIL/_imaging.cpython-310-darwin.so' (mach-o file, but is an incompatible architecture (have (x86_64), need (arm64e)))
Stopping plugin "Roon 2022.0.0" (pid 91494)
Stopped plugin "Roon 2022.0.0"
Chris
Chris
