Roon Controller
Mon Feb 18, 2019 9:19 am
autolog offline
Roon Controller
I have started work on a new plugin. :D
It makes extensive use of a python library created by Marcel van der Veldt; see here: Python Roon
It will enable control of a Roon system from Indigo.
For more info on Roon, see here: Roon
If anyone who uses Roon is interested in alpha testing the plugin when it is available, just post your interest on this thread. :)
Tue Apr 30, 2019 2:34 am
ChiefMonk offline
Re: Roon Controller
I am using Roon and love it, so count me in
Chris
Tue Apr 30, 2019 10:52 am
autolog offline
Re: Roon Controller
Chris
PM with link sent. :)
Wed May 01, 2019 3:14 pm
IndigoSam offline
Re: Roon Controller
Blimey Jon, you are a coding machine! :)
Yes, I use Roon. Very interested in this.
Sam.
Wed May 01, 2019 4:45 pm
autolog offline
Re: Roon Controller
IndigoSam wrote:
... Very interested in this.
Thu May 02, 2019 1:42 pm
IndigoSam offline
Re: Roon Controller
Thanks Jon.
So, how do we use this then? Not seeing any config or new devices?
Am I being a bit thick?
(Oh, and 'About' goes to TRV controller, obviously not a priority, but so you know.)
Sam.
Thu May 02, 2019 2:02 pm
autolog offline
Re: Roon Controller
Hi Sam,
You should get a config dialog from the plugin menu.
If it isn't appearing, try downloading the zip file again and re-installing - maybe it didn't install correctly?
Fri May 03, 2019 2:38 am
IndigoSam offline
Re: Roon Controller
I should probably be posting on the beta feedback thread.
I'm getting the following error on start up:
   Roon Error                      Error in plugin execution InitializeMain:
  File "plugin.py", line 17, in <module>
ImportError: No module named PIL
Sam.
Fri May 03, 2019 2:49 am
autolog offline
Re: Roon Controller
Missing bit of documentation. :oops:
You need to open a terminal session and do a pip install of Pillow i.e.:
pip install Pillow
This is needed for processing the album and artist images. :)
Fri May 03, 2019 5:35 am
autolog offline
Re: Roon Controller
Agreed - thread now locked. :D
See the thread: Roon Controller Plugin Beta feedback
Sun May 05, 2019 6:21 am
autolog offline
Re: Roon Controller
IndigoSam wrote:
... (Oh, and 'About' goes to TRV controller, obviously not a priority, but so you know.)
Fixed in next (upcoming) version. :)
