kennybroh wrote:Looking at your circadian scenes (BTW, I use MBR as the name for my bedroom too) I noticed you have the interval set to 600 or 10 minutes. Does that mean it changes every 10 minutes or just checks the time every 10 minutes? If so, it will not run for the length of time I assume it is intended to. I must be missing part of how it works.
And I assume the error someone else reported would result from a temp setting outside the range of that bulb? For example, I think the MR16s temp range is 2700-9000. but your scene parameters for MBR circ go down to 1500. I just started the scene so I'll wait to see if I see errors.
If there is a sufficient delta in either brightness or color temp, it will change it.
kennybroh wrote:What is it chacking against? The time of day and some table of appropriate settings as the day wears on?
The circadian algorithm used in the scene is relatively crude.. The quick notes from my docs:The values form a gradient that increases from sunrise to midday, and decreases at the end of day around sunset. The algorithm will adjust based on a percentage of each interval. The values must be ordered such that: Late Night<Pre-Sunrise<Post-Sunrise<AM Peak<Max, also Max>Pre-Sunset>Post-Sunset>Late Night.
