Hue Lights discussion
Wed Oct 03, 2018 5:19 am
Busta999 offline
Anyone tried a Zigbee Light lInk Compatible - Led WW/CW Cont
Anyone played with this?
Could it work with the Hue Plugin @nathan ? Pretty Please...
I assume I add it to the Hue hub and then run Hue Plugin in debug and start it - capture and post back here?
Possibly?
I already have the PSUs, but this would be a much cheaper version of the Hue LED Strip and fit for purpose, I don't need colour in the kitchen for this utility function.
I've just ordered this as it claims full compatibility with Hue/Alexa/Tradfri..
CCT Controller that works with ZigBee Light Link(ZLL)
CCT/wamwhite-coldwhite controllercompatible with ZigBee Gateways, for example Philips Hue, Osram Lightify, Ikea Tradfri, Amazon Echo. This new generation of CCT/color change temperature controller works with ZigBee ZLL profile and is useable for the most ZigBee Gateways on the market, please so Notes for tested compatibility.
With this controller you can control different LED products and can set a white color you like. For example warm white, cold white, pure white and so on. With an App and a daylight sensor it is possible to change the light color like the day outside, to make a full automatically light control.
You can control with this controller many kinds of LED that works with a PWM control.
Like LED Stripes, LED Indoor or Outdoor light with 12 or 24 Volt.
Technical data:
- Input voltage DC 12-24 Volt
- Output current per channel 6 Ampere
- Output current max. 15 Ampere
- protection class IP20
- working temperature -20°C to 60°C
- dimensions 23,5x48x89 mm
- constant voltage
- common anode
The controller will be work with the most ZigBee Light Link and ZigBee 3.0 Gateways.
It is tested with Philips Hue, Osram Lightify, Ikea Tradfri, Amazon Echo Plus
It looks like it could be pretty nice for the new Kitchen.
i.e. One of these controlling two runs of LED strips one 6500k the other 2400k.
I am trying with with 2x5M waterproof IP65 300 unit SMD 2835 LED Ribbon 1200lm 12v DC one 6500k the other a warm white so expect something around 2400-2700k.
If it works - I hoping to hook in a few of these around the kitchen so I can drive a daylight Mode, evening mode and a super bright mode with both strings on.
Wed Oct 03, 2018 7:05 am
roussell offline
Heh, you beat me to this. I was literally looking at these last night and have one and a light strip in my Amazon cart. Before I ordered I was going to post here to see if there was a chance of the plugin supporting it. I’m assuming it can, as long as the Hue hub can see it and the functionality is added to the plugin.
Terry
Wed Oct 03, 2018 7:30 am
Busta999 offline
Re: Hue Lights discussion
It looks like it will support 72w,
Planinng on 4 strings down each side of the kitchen, one 6500k and a 2400k on top of units to proved two levels of ceiling light. One 6500k over counter tops and one 2400k by foot board
Have one of these units controlling for each side
Have a hue motion detector turn on 2400k strings on movement and Alexa to control 6500k
A cunning plan, I’ll try to test it once it arrives but kinda busy moving house next week so may get distracted.
Mike
Wed Oct 03, 2018 8:19 am
neilk offline
That is funny, just ordered one of these today https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1 with a view to doing the same thing. We are having an extension built and I am looking at the lighting and the cost/practicality of using all Hue products. I will report back also.
Thu Oct 04, 2018 1:21 am
nsheldon offline
Hi guys.
If you can control a light using the Hue mobile app, then the Hue Lights plugin can be adapted to control it (even if it doesn't currently support that specific light).
Yep. I know it's a bit tedious, but that's currently what's required in order for me to add support.
Thu Oct 04, 2018 1:25 am
Busta999 offline
Nathan, no bother at all.
But is it possible to have these definitions in a text/config file then we can just add them directly without having to keep bothering you?
Thanks for this Plugin very much appreciated, especially when you added motion detection/temp sensor to it :-)
Mike
Thu Oct 04, 2018 2:26 am
nsheldon offline
Hi Mike.
You can add the modelIDs to the plugin yourself in the "supportedDevices.py" file within the plugin bundle. That's all I do. Of course, the problem with you doing it is that as soon as you install an update to the the plugin, that file is overwritten. I assume what you really mean is an external configuration file that isn't overwritten by the plugin. I'll certainly keep that option in mind for future updates.
Kind regards,
Nathan
Thu Oct 04, 2018 3:25 pm
neilk offline
I installed this tonight, and it seems to work well. It added first time to the hue hub, and the log output is
 {u'swversion': u'1.0.2', u'name': u'Zigbee strip', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:12:4b:00:19:c7:9e:87-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 58112, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.5611, 0.2693], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 317, u'sat': 199}, u'manufacturername': u'ShenZhen_Homa', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'HOMA1001'}
I just have a low quality RGB strip to hand, and will order a better quality RGBW strip for further testing and a proper power supply, I want to test and compare with the Fibaro RGBW controller I just bought. I don't know if the capabilities change dynamically as the unit has DIP switches to set single colour, RGB, RGBW and Warm or Cool White. It seems responsive, colour fidelity was off but that is probably a function of a low quality strip.
Thu Oct 04, 2018 11:42 pm
nsheldon offline
Version 1.6.20 Posted
  • Added support for the ShenZhen Homa white and color LED light strip controller.
Fri Oct 05, 2018 6:51 am
gmoeller offline
Osram SMART+ Outdoor Plug
I just got hands on an Osram SMART+ outdoor plug:
https://smartplus.ledvance.com/products ... /index.jsp
(scroll down..)
It properly added to my HUE Hub (On/Off plug) and can be controlled via the app.
Now I want to add this device to the Hue Lights plugin and face some problems.
First, I tried to add it as a "Living Whites" - "Generic Light" but the plug does not appear in the device list.
Same results when trying the other devices, the plug is not listed in the device list.
The only way to make it (somewhat) work is when I create a "Room" in the HUE app and pick that romm via "HUE Group" in the plugin.
When added to devices, I am able to switch the plug but I will not get any status update.
So, when I switch the device to "On", the plug will actually react and switches on - but the device status in Indigo is still "OFF"...
Any idea how I can solve this - or do you have to add the SMART+ outdoor plug to the plugin first?
Thanks a lot in advance!
Guido
Fri Oct 05, 2018 8:03 am
Busta999 offline
Ok Nathan
Got the zigbee WW/CW up and running in Hue
2018-10-05 14:52:45.408   Hue Lights Debug   Loaded lights list - {u'24': {u'swversion': u'1.29.0_r21169', u'name': u'Dawn', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:06'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:7a:3e:72-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'25': {u'swversion': u'5.105.0.21536', u'name': u'Ensuite', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:33'}, u'uniqueid': u'00:17:88:01:02:05:36:2f-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW001'}, u'26': {u'swversion': u'1.29.0_r21169', u'name': u'Globe Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:54'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:7a:3a:ff-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 41192, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3234, 0.3384], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 65}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'27': {u'swversion': u'1.29.0_r21169', u'name': u'Globe Middle', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:12'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:c8:ac:2b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 41192, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3234, 0.3384], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 65}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'20': {u'swversion': u'1.29.0_r21169', u'name': u'Landing Ceiling 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:40'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:78:e7:b1-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'21': {u'swversion': u'1.29.0_r21169', u'name': u'Landing Ceiling 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:25'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:78:e5:6f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'22': {u'swversion': u'1.29.0_r21169', u'name': u'Office Ceiling', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:59'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:73:00:44-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.445, 0.4067], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 346, u'sat': 0}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'23': {u'swversion': u'1.29.0_r21169', u'name': u'Backdoor', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-01-15T14:48:30'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:78:d7:70-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.0, 0.0], u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'ct': 0, u'sat': 0}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'28': {u'swversion': u'1.29.0_r21169', u'name': u'Bathroom Sink 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:35'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:27:f9:da-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 126, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'797DDD7C', u'config': {u'function': u'functional', u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'29': {u'swversion': u'1.29.0_r21169', u'name': u'Bathroom Bath', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:43:06'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:27:ed:ae-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 126, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'797DDD7C', u'config': {u'function': u'functional', u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'1': {u'swversion': u'5.105.0.21169', u'name': u'Back', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:43:00'}, u'uniqueid': u'00:17:88:01:00:d0:fa:d1-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 33923, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3235, 0.3385], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 222}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'3': {u'swversion': u'5.105.0.21169', u'name': u'Molly', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:48'}, u'uniqueid': u'00:17:88:01:00:e1:f5:b4-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.177, 0.0588], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'5': {u'swversion': u'5.105.0.21169', u'name': u'Sunroom Uplight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:32'}, u'uniqueid': u'00:17:88:01:00:e1:13:2f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'ct': 367, u'sat': 0}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'swversion': u'5.105.0.21169', u'name': u'Sunroom Downlight New', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:43:40'}, u'uniqueid': u'00:17:88:01:00:e0:3a:2d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 0, u'ct': 367, u'sat': 0}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'7': {u'swversion': u'5.105.0.21169', u'name': u'Front', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:19'}, u'uniqueid': u'00:17:88:01:00:e0:30:48-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 33923, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3235, 0.3385], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 222}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'6': {u'swversion': u'5.105.0.21169', u'name': u'Middle', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:26'}, u'uniqueid': u'00:17:88:01:00:e0:3a:e7-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 33923, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3235, 0.3385], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 222}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'9': {u'swversion': u'5.105.0.21169', u'name': u'WC', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:43:24'}, u'uniqueid': u'00:17:88:01:00:e4:e7:2c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'8': {u'swversion': u'5.105.0.21169', u'name': u'Mike', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:14'}, u'uniqueid': u'00:17:88:01:00:d6:87:1e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 13524, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5017, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 443, u'sat': 200}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'11': {u'swversion': u'5.105.1.21778', u'name': u'Backlight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:07'}, u'uniqueid': u'00:17:88:01:00:c3:f8:da-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': True, u'hue': 39518, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3217, 0.3385], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'sat': 102}, u'manufacturername': u'Philips', u'config': {u'function': u'decorative', u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC012'}, u'13': {u'swversion': u'5.105.0.21169', u'name': u'Office Backlight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:43:18'}, u'uniqueid': u'00:17:88:01:00:da:2c:9c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'12': {u'swversion': u'5.105.0.21169', u'name': u'Front Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:42:54'}, u'uniqueid': u'00:17:88:01:00:da:2d:a4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'15': {u'swversion': u'5.105.0.21169', u'name': u'Utility', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:23'}, u'uniqueid': u'00:17:88:01:00:da:2c:c6-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'14': {u'swversion': u'5.105.0.21169', u'name': u'Garage  Ceiling', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:11'}, u'uniqueid': u'00:17:88:01:00:da:33:ea-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 750}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB004'}, u'17': {u'swversion': u'5.105.0.21169', u'name': u'Desk', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-02-16T14:56:55'}, u'uniqueid': u'00:17:88:01:01:1d:21:a5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 0, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.445, 0.4067], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 346, u'sat': 0}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'16': {u'swversion': u'5.105.0.21169', u'name': u'Front Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:15'}, u'uniqueid': u'00:17:88:01:10:52:a8:d5-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'none'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'19': {u'swversion': u'1.29.0_r21169', u'name': u'Globe Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:47'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:7a:a6:d6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 41192, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3234, 0.3384], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 65}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'18': {u'swversion': u'5.105.0.21536', u'name': u'Hallway', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:46'}, u'uniqueid': u'00:17:88:01:02:07:07:1d-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'none', u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'ct': 366}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW001'}, u'31': {u'swversion': u'1.29.0_r21169', u'name': u'Bathroom Sink', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:41'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:03:51:af:18-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 126, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'797DDD7C', u'config': {u'function': u'functional', u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}, u'30': {u'swversion': u'1.29.0_r21169', u'name': u'Master', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:41:18'}, u'productid': u'Philips-LCT010-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:4e:1b:9b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 806, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'6A139B19', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT010'}, u'37': {u'swversion': u'1.0.3', u'name': u'Light Strip WW/CW', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'00:12:4b:00:13:0a:53:2c-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 233}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'GLEDOPTO'}, u'36': {u'swversion': u'1.29.0_r21169', u'name': u'Study Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-08T14:14:46'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:0d:6f:71-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 60, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'FF6681C4', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'35': {u'swversion': u'1.29.0_r21169', u'name': u'Study Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-08T14:14:43'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:47:a7:67-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'bri': 60, u'alert': u'none'}, u'manufacturername': u'Philips', u'swconfigid': u'FF6681C4', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'34': {u'swversion': u'1.29.0_r21169', u'name': u'Sofa Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-04T23:59:08'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9d:a4:5b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 41192, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3234, 0.3384], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 65}, u'manufacturername': u'Philips', u'swconfigid': u'0612AD68', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'33': {u'swversion': u'1.29.0_r21169', u'name': u'Sofa Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-04T23:55:03'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:02:9d:a7:f1-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 41192, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3234, 0.3384], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 167, u'sat': 65}, u'manufacturername': u'Philips', u'swconfigid': u'0612AD68', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'32': {u'swversion': u'1.29.0_r21169', u'name': u'Bathroom Shower', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-29T22:40:30'}, u'productid': u'Philips-LTW013-1-GU10CTv1', u'uniqueid': u'00:17:88:01:02:9f:14:05-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 250, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance spot', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'none', u'reachable': False, u'mode': u'homeautomation', u'bri': 126, u'ct': 367}, u'manufacturername': u'Philips', u'swconfigid': u'797DDD7C', u'config': {u'function': u'functional', u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW013'}}
The unit is called Light Strip WW/CW so it is a bit easier to find
Not sure which bit you need, hopefully this is good.
Mike
Mon Oct 15, 2018 1:02 am
nsheldon offline
Version 1.6.21 Posted
  • Added support for the Dredesn Elektronik FLS-CT lp LED color temperature light.
  • Added support for a Generic ZigBee WW/CW light strip.
Mon Oct 15, 2018 1:05 am
nsheldon offline
Re: Osram SMART+ Outdoor Plug
Hi Guido.
In order to support your device, I need to see the debug log output like Mike provided. You can get that by going to Plugins -> Hue Lights -> Toggle Debugging then reloading the plugin (Plugins -> Hue Lights -> Reload).
Regards,
Nathan
(scroll down..)
Guido
Fri Oct 19, 2018 1:57 am
MarcoGT offline
Does the plugin work will all Hue lights? (for example, new stand lamp and so on)
All that we have to do is to add the modelID to the config?
Fri Oct 19, 2018 1:10 pm
nsheldon offline
If you can control the light with the Hue app on your iPhone or Android phone but can’t find the light in the Hue Lights plugin, the modelID for that light just needs to be added to the correct list in the “supportedDevices.py” file within the Hue Lights plugin package. The plugin will see the light after that.
Page 61 of 103 1 ... 58, 59, 60, 61, 62, 63, 64 ... 103
