Hue Lights discussion
Mon Jun 18, 2018 9:27 am
jaga01 offline
Re: Hue Lights discussion
Hi nsheldon,
Thank you very much for including INNR PowerPlug, I just testet it and it works splendid. I am now able to control my Lamp with a flic button as well as through Indigo as normal.
Regards, Jacob
Mon Jun 18, 2018 10:38 am
nsheldon offline
Hi Jacob.
Excellent! I'm glad the INNR plug works with the plugin now. Happy automating!
Mon Jun 18, 2018 10:55 am
jaga01 offline
Hi Nathan, I get a strange behavior. I am controlling the INNR PowerPlug with the Scene Master ZRC-90. I am trying to have it toogle on/off, but it is only respondig with on. Then I have to create a double click with a specific off command in order to have it turn off. All my other Hue bulbs that i have does acknowledge the toogle On/off. And when I look at the PowerPlug it seems that it is also able to slide up and down for dimming. But i don´t think a powerplug can do that. Do you have an idea to why I am not able to establish toogle on/off?
Regards, Jacob
Mon Jun 18, 2018 11:16 am
nsheldon offline
Hi Jacob.
The Hue Lights plugin should be able to respond to Toggle on/off commands for the INNR plug just like any other light it supports. If that's not working, either there's a bug in the plugin or the Hue bridge is treating the INNR on/off plug differently when it receives the command from the Hue Lights plugin. I'll need to see debug log output showing the interaction between the ZRC-90, Indigo, Hue Lights and the Hue bridge.
As for the dimming slider... No, the INNR on/off plug doesn't support dimming, but the Hue Lights plugin wasn't originally designed to work with plain on/off devices, so it assumes everything is at least dimmable. Since this is the only on/off device integrated with the Hue Lights plugin, creating a whole new device type and set of code just to handle this one device would have been too time consuming. If the slider is used, when it's set to anything other than zero, the plugin should turn on the INNR plug. When the slider is set to zero, that should turn the plug off. Let me know if that's not working.
Mon Jun 18, 2018 12:14 pm
jaga01 offline
It is very strange. It seems that it works for 3 repetitions then it does not respond any more. But from the HUE App it works splendid. I am talking about the toggle on/off.
It is also responding to ON and Off. When I press the on and of button in indigo it is also responding.
So again it respons when a ON has been issued. It works for 3-7 repetitions and stops again. It is always in the ON position where it is not possible to turn off. So toggle Of does not work sometimes.
RGDS, Jacob
Mon Jun 18, 2018 12:36 pm
jaga01 offline
I am not able to attach a pdf nor post the log into the screen. It to big. What do I do? Regards, Jacob
Mon Jun 18, 2018 1:03 pm
nsheldon offline
Hi Jacob.
You can either try sending a private message in the forum or you can send me an email at nathan AT nathansheldon DOT com.
I suspect the issue is related to the delay between when a Hue device is changed and when the Hue Lights plugin is able to see that change (which can be as high as 20 seconds).
Mon Jun 18, 2018 3:42 pm
jaga01 offline
Its sent via e-mail. RGDS, Jacob
Tue Aug 07, 2018 12:11 pm
Redrocker offline
Hi Nathan,
I picked up one of those new Hue Outdoor Calla Pathway lights today. Will there be support for those? No major hurry, as you can't find the add-ons anywhere yet. So I have one lonely pathway light. They are of pretty good quality though. I'll wait patiently, like everyone else. I suspect they will be plentiful in time for the "pretty colors" to reflect off the snow when it comes. :shock:
Thank you,
~Mark
Indigo 7.x
Tue Aug 07, 2018 12:46 pm
akimball offline
Question for Mark... is the calla light a pathway frame with a regular hue bulb inside? Or is it a complete sealed new hue type? I’m planning in throwing in several for my front yard lighting.
-Al
Tue Aug 07, 2018 1:43 pm
Redrocker offline
They are a new "sealed" type, easily added to the Hue app, but doesn't appear under Nathan's plugin under any of the choices. The starter kit, with one light was easily ordered on BestBuy.com, but no-one has the additional lights. Amazon actually fails over to one of those Oops pages if you try to order them, and even Phillips site has the order button greyed out. I'm thinking of putting it on the middle of the flower bed in the front of the house until more become available.
~Mark
Indigo 7.x
Tue Aug 07, 2018 11:09 pm
nsheldon offline
Hi Mark.
I don't see that device listed in Philips's Hue API list of supported devices yet. But they're slow to update that. If you can tell me the exact model ID of that device (case sensitive), I can add support for it. The easiest way is to just enable debug logging (Plugins menu -> Hue Lights -> Toggle Debugging), reload the plugin, then paste in the first part of the log up to where it shows the number of lights found. I can find the model ID from that.
Redrocker wrote:
Hi Nathan,
Thank you,
Wed Aug 08, 2018 4:44 am
Redrocker offline
Thank you the quick reply Nathan. I hope this isn't too much information, but here goes:
  Hue Lights Debug                Starting parseAllHueGroupsData.
   Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Starting parseAllHueSensorsData.
   Hue Lights Debug                Starting updateLightsList.
   Hue Lights Debug                Sending command to hub: http://192.168.1.180/api/IuAeXfJJyBjPuG0R9iVl3mTRd2esAFOJXKyOwLN0/lights
   Hue Lights Debug                Got response {u'24': {u'swversion': u'1.30.4_r23032', u'name': u'Hue outdoor bollard 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'ENA-LCF001-1-CallaBollardv1', u'uniqueid': u'00:17:88:01:04:50:a2:6d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 500, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue outdoor bollard', u'state': {u'on': False, u'hue': 1416, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.6404, 0.3337], u'reachable': True, u'mode': u'homeautomation', u'bri': 199, u'ct': 153, u'sat': 234}, u'manufacturername': u'Philips', u'swconfigid': u'8C6A0DD9', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'bollard'}, u'type': u'Extended color light', u'modelid': u'LCF001'}, u'13': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:53'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:c9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'15': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:07'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:af-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'14': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:10'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:1c:de:8e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'22': {u'swversion': u'5.105.0.21169', u'name': u'Arcade machine', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-12T02:24:36'}, u'uniqueid': u'00:17:88:01:02:af:5a:7f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'16': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:58'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:00-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'19': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 6', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-14T20:37:12'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:82:6e:df-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-14T20:36:11'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:1c:fe:ff-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'23': {u'swversion': u'5.105.0.21536', u'name': u'Back hall light', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:10:56:d9:bd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14955, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4588, 0.4104], u'reachable': True, u'mode': u'homeautomation', u'bri': 48, u'ct': 369, u'sat': 143}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'20': {u'swversion': u'5.105.1.21778', u'name': u'Front bar lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-30T08:16:54'}, u'uniqueid': u'00:17:88:01:00:ce:e2:b8-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 38677, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3678, 0.372], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 61}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'1': {u'swversion': u'1.29.0_r21169', u'name': u'Lamp post', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-11T22:20:44'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:88:46:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8005, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4835, 0.4144], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 413, u'sat': 177}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'3': {u'swversion': u'1.29.0_r21169', u'name': u'Living room light left', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:71:30:02-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'2': {u'swversion': u'1.29.0_r21169', u'name': u'Living room lamp right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:73:39:7d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'5': {u'swversion': u'5.105.0.21169', u'name': u'Bedroom lamp right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e6:48:cb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'swversion': u'5.105.1.21778', u'name': u'TV light strip', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:ce:a3:bd-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 21708, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.3088, 0.6343], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'sat': 254}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'7': {u'swversion': u'1.29.0_r21169', u'name': u'Window light', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:cb:f2:53-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'6': {u'swversion': u'5.105.0.21169', u'name': u'Bedroom lamp left', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:b1:9a:98-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'8': {u'swversion': u'5.105.1.21778', u'name': u'Desk', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:ce:e2:b7-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 39949, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.1516, 0.2256], u'reachable': True, u'mode': u'homeautomation', u'bri': 169, u'sat': 254}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'21': {u'swversion': u'5.105.0.21169', u'name': u'Back bar light', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-01-17T18:35:04'}, u'uniqueid': u'00:17:88:01:02:af:bd:b3-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
   Hue Lights Debug                Loaded lights list - {u'24': {u'swversion': u'1.30.4_r23032', u'name': u'Hue outdoor bollard 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'ENA-LCF001-1-CallaBollardv1', u'uniqueid': u'00:17:88:01:04:50:a2:6d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 500, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue outdoor bollard', u'state': {u'on': False, u'hue': 1416, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.6404, 0.3337], u'reachable': True, u'mode': u'homeautomation', u'bri': 199, u'ct': 153, u'sat': 234}, u'manufacturername': u'Philips', u'swconfigid': u'8C6A0DD9', u'config': {u'function': u'decorative', u'direction': u'omnidirectional', u'archetype': u'bollard'}, u'type': u'Extended color light', u'modelid': u'LCF001'}, u'13': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:53'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:c9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'15': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:07'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:af-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'14': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:10'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:1c:de:8e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'22': {u'swversion': u'5.105.0.21169', u'name': u'Arcade machine', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-03-12T02:24:36'}, u'uniqueid': u'00:17:88:01:02:af:5a:7f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'16': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 5', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-13T02:35:58'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:62:e1:00-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'19': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 6', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-14T20:37:12'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:82:6e:df-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.29.0_r21169', u'name': u'Can light 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-14T20:36:11'}, u'productid': u'Philips-LCT011-1-BR30ECLv1', u'uniqueid': u'00:17:88:01:02:1c:fe:ff-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 2000, u'maxlumen': 650, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'swconfigid': u'808DBD55', u'config': {u'function': u'mixed', u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT011'}, u'23': {u'swversion': u'5.105.0.21536', u'name': u'Back hall light', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:10:56:d9:bd-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 14955, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4588, 0.4104], u'reachable': True, u'mode': u'homeautomation', u'bri': 48, u'ct': 369, u'sat': 143}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'20': {u'swversion': u'5.105.1.21778', u'name': u'Front bar lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-30T08:16:54'}, u'uniqueid': u'00:17:88:01:00:ce:e2:b8-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 38677, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3678, 0.372], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'sat': 61}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'1': {u'swversion': u'1.29.0_r21169', u'name': u'Lamp post', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2017-12-11T22:20:44'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:88:46:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8005, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4835, 0.4144], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 413, u'sat': 177}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'3': {u'swversion': u'1.29.0_r21169', u'name': u'Living room light left', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:71:30:02-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'2': {u'swversion': u'1.29.0_r21169', u'name': u'Living room lamp right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:73:39:7d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8402, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4099], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'5': {u'swversion': u'5.105.0.21169', u'name': u'Bedroom lamp right', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:e6:48:cb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'4': {u'swversion': u'5.105.1.21778', u'name': u'TV light strip', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:ce:a3:bd-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 21708, u'colormode': u'hs', u'effect': u'none', u'alert': u'none', u'xy': [0.3088, 0.6343], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'sat': 254}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'7': {u'swversion': u'1.29.0_r21169', u'name': u'Window light', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:cb:f2:53-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'3027B5DE', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'6': {u'swversion': u'5.105.0.21169', u'name': u'Bedroom lamp left', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:b1:9a:98-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'8': {u'swversion': u'5.105.1.21778', u'name': u'Desk', u'swupdate': {u'state': u'noupdates', u'lastinstall': None}, u'uniqueid': u'00:17:88:01:00:ce:e2:b7-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 5000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue lightstrip', u'state': {u'on': False, u'hue': 39949, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.1516, 0.2256], u'reachable': True, u'mode': u'homeautomation', u'bri': 169, u'sat': 254}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Color light', u'modelid': u'LST001'}, u'21': {u'swversion': u'5.105.0.21169', u'name': u'Back bar light', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-01-17T18:35:04'}, u'uniqueid': u'00:17:88:01:02:af:bd:b3-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 39392, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.3691, 0.3719], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 230, u'sat': 13}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
   Hue Lights Debug                Starting parseAllHueLightsData.
   Hue Lights Debug                parseAllHueLightsData: There are 19 lights on the Hue bridge and 18 Indigo devices controlling Hue devices.
   Hue Lights Debug                Starting updateGroupsList.
   Hue Lights Debug                Sending command to hub: http://192.168.1.180/api/IuAeXfJJyBjPuG0R9iVl3mTRd2esAFOJXKyOwLN0/groups
I believe this is the light: u'Hue outdoor bollard 1', u'swupdate'
Thank you
~Mark
Indigo 7.x
Thu Aug 09, 2018 1:22 am
nsheldon offline
Version 1.6.15 Posted
  • Added support for the Hue calla pathway bollard light.
Thu Aug 09, 2018 3:20 am
Redrocker offline
Thank you Nathan. I’ll check it out this afternoon.
~Mark
Indigo 7.x
Page 59 of 71 1 ... 56, 57, 58, 59, 60, 61, 62 ... 71
