Hue Lights discussion
Thu Nov 25, 2021 3:51 am
nsheldon offline
Re: Hue Lights discussion
Hi Karl.
kw123 wrote:
1. Ikea tradfri only uses zigbee and works with its owns dimmers and the Ikea app through the Ikea gateway and ?? also through the Philips hue gateway and also the Philips hue dimmers ??
I'm not sure. I've tried to pair one model of Ikea lights with the Hue bridge and it didn't work, but I know many others have successfully paired different Ikea/Tradfri lights with the Hue bridge because they've asked me to add support. So if you can pair an Ikea light with the Hue bridge, I can add support in the Hue Lights plugin. But if you're not able to get the Ikea light to work with the Hue bridge, I couldn't do anything to fix that.
2. Philips Hue bulbs come EITHER in zigbee OR in bluetooth versions (??not both??),
With the hue bridge/gateway you can set light/color.. through iPhone app and hue dimmers. Bluetooth can bet set also directly iPhone app bluetooth--> bulb; When using bluetooth the bridge/iphone has to be within 10 meters to talk to the bulb
My understanding is that the new Hue lights that support Bluetooth also support ZigBee, but not both at the same time (so if you set them up using Bluetooth, they don't work with the Hue bridge until you reset them and pair them with the Hue bridge, then Bluetooth doesn't work). However, I'm not positive about this as I've not tested it myself.
3. the Indigo Hue plugin talks to the Philips hue bridge / gateway through HTTP / Restful interface. Only one gateway is supported, for a second bridge a second plugin with changed name for the plugin has to be used.
Is this correct?
Yes. The Hue Lights plugin only supports communicating with one Hue bridge at a time, and only via HTTP/RESTful interface. Using a second bridge requires duplicating the plugin and changing the plugin ID within the plugin bundle so it looks like a new plugin to Indigo (thus creating separate preferences and settings for the 2nd copy of the plugin).
Wed Dec 01, 2021 2:03 pm
christeren offline
Hello - I have been adding devices to my iOS Hue app, and they work fine there, but Inidigo will not sow the new devices to be added. They do appear in Groups, but not individual devices.
One type is Philips Hue White Decorative Candle, LWE001 (450 Lumen) Dimmable Soft While 2700k
Another type is eWeLink On/Off Plug, Model SA-003-Zigbee
When I Reload Hue Hub Config the correct number of bulbs and switches is reported, and they appear in Group settings, but I can not make individual devices with them. Am I missing something? Or could they be added please to the supported devices?
Thank you so much!
Wed Dec 01, 2021 5:30 pm
nsheldon offline
Hi.
Thanks for the report and details. I'll add support for those 2 device types in the next plugin update.
Fri Dec 03, 2021 8:52 am
DirkWe offline
Hi Nathan from Germany,
i recently bought two (E14) innr-bulbs (half the money of the hue versions). Any chance for them to make it to your next update ?
In my Hue-App everything works fine, a hack of the "supportedDevices.py" leads to a working on/off, but no chance for the Colors...
The bulbs are coded "RB 250 C" from innr. Do you need antything else? Maybe the JSON from the response of the HUE-Bridge?
Thanks in advance...
Dirk
Tue Dec 07, 2021 7:09 am
MarcoGT offline
I have a couple of Innr bulbs (I am also from Germany) and they will work fine.
You should set log level to debug so that Nathan can see the details of the bulb and add them with the next update
Tue Dec 07, 2021 11:28 am
nsheldon offline
Hi Dirk.
Sorry for the delay. Yes, as MarcoGT said, debug log output will be helpful. I suspect the issue is that the edits made to the supportedDevices.py file were just in the wrong area as I have a few working innr color bulbs as well (though obviously a different model). Getting the debug log output will help. I'd also need to know the name of one of the bulbs to look for in the debug log output.
Wed Dec 08, 2021 1:22 am
nsheldon offline
Version 1.7.62 Posted
  • Added support for a 3A Smart Home DE on/off light switch.
  • Added support for another Hue White Candle bulb.
  • Added support for an eWeLink on/off plug.
  • Added support for an innr color/color temperature candle bulb.
Thu Dec 09, 2021 2:03 pm
cesarvog offline
Thanks, Mr. Sheldon!
Mon Dec 13, 2021 2:00 pm
Dtmr offline
Hi Nathan,
I bought some Philips Hue White and colour ambience Lily Outdoor spot lights (Model 1741430P7; Software 1.93.3) but I can't find them in the device list.
It looks like the US version has a different model number: 1746730V7
- US: https://www.philips-hue.com/en-us/p/hue ... /1746730V7
- DE: https://www.philips-hue.com/de-de/p/hue ... /1741430P7
It would be great if you could add them in the next plugin release (and I hope that I'm not just too blind to find them in the list :shock: )
Cheers and Thanks,
Dietmar
Mon Dec 27, 2021 6:22 pm
nsheldon offline
Hi Dietmar.
Thanks for the report. I'll add support for that light (and the US version) in the next update.
Mon Dec 27, 2021 7:00 pm
nsheldon offline
Version 1.7.63 Posted
  • Added support for 2 new Hue outdoor Lily spotlights.
Tue Dec 28, 2021 6:44 am
MarcoGT offline
I bought a FLOALT Ikea Lamp, here the debug:
The name of the lamp is Soffitto Camera"
Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Sending command to bridge: http://192.168.1.30/api/fRgyDBWyp9x4Cbd0Cnb1V1DKM21DrCqGKlwO0jNi/sensors
   Hue Lights Debug                Got response {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': True, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': True, u'lastupdated': u'2021-12-28T07:31:00'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'5': {u'name': u'Hue ambient light sensor 1', u'uniqueid': u'00:17:88:01:09:16:f8:d9-02-0400', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-02T20:01:49'}, u'swversion': u'6.1.1.27575', u'capabilities': {u'primary': False, u'certified': True}, u'productname': u'Hue ambient light sensor', u'state': {u'dark': True, u'daylight': False, u'lightlevel': 12545, u'lastupdated': u'2021-12-28T12:40:36'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'ZLLLightLevel', u'config': {u'on': True, u'tholdoffset': 7000, u'battery': 100, u'ledindication': False, u'alert': u'none', u'reachable': True, u'usertest': False, u'tholddark': 18634, u'pending': []}, u'modelid': u'SML001'}, u'4': {u'name': u'Hue motion sensor 1', u'uniqueid': u'00:17:88:01:09:16:f8:d9-02-0406', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-02T20:01:49'}, u'swversion': u'6.1.1.27575', u'capabilities': {u'primary': True, u'certified': True}, u'productname': u'Hue motion sensor', u'state': {u'lastupdated': u'2021-12-28T12:41:53', u'presence': False}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'ZLLPresence', u'config': {u'on': True, u'battery': 100, u'sensitivity': 2, u'ledindication': False, u'alert': u'none', u'reachable': True, u'usertest': False, u'sensitivitymax': 2, u'pending': []}, u'modelid': u'SML001'}, u'6': {u'name': u'Hue temperature sensor 1', u'uniqueid': u'00:17:88:01:09:16:f8:d9-02-0402', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-02T20:01:49'}, u'swversion': u'6.1.1.27575', u'capabilities': {u'primary': False, u'certified': True}, u'productname': u'Hue temperature sensor', u'state': {u'temperature': 2353, u'lastupdated': u'2021-12-28T12:41:19'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'ZLLTemperature', u'config': {u'on': True, u'battery': 100, u'ledindication': False, u'alert': u'none', u'reachable': True, u'usertest': False, u'pending': []}, u'modelid': u'SML001'}}
   Hue Lights Debug                Starting parseAllHueSensorsData.
   Hue Lights Debug                Starting updateLightsList.
   Hue Lights Debug                Sending command to bridge: http://192.168.1.30/api/fRgyDBWyp9x4Cbd0Cnb1V1DKM21DrCqGKlwO0jNi/lights
   Hue Lights Debug                Got response {u'11': {u'swversion': u'2.0.022', u'name': u'Balcone camera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-01-26T19:50:03'}, u'uniqueid': u'cc:cc:cc:ff:fe:a3:1a:d5-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 447}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'10': {u'swversion': u'2.0.022', u'name': u'Balcone sala', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-01-26T19:42:07'}, u'uniqueid': u'cc:cc:cc:ff:fe:36:c4:10-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 447}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'12': {u'swversion': u'1.2.217', u'name': u'Soffitto Camera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2021-12-27T12:33:24'}, u'uniqueid': u'8c:f6:81:ff:fe:09:9f:a3-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 338}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'FLOALT panel WS 60x60'}, u'1': {u'swversion': u'1.88.1', u'name': u'Camino', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-11T19:52:38'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:03:bb:4d:dc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'303C735A', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'3': {u'swversion': u'67.91.1', u'name': u'Reno', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-10-18T19:58:29'}, u'uniqueid': u'00:17:88:01:03:31:c1:65-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': False, u'hue': 5202, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5354, 0.3767], u'reachable': True, u'mode': u'homeautomation', u'bri': 157, u'sat': 118}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'customsettings': {u'xy': [0.5355, 0.3752], u'bri': 157}, u'mode': u'custom'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'2': {u'swversion': u'67.91.1', u'name': u'Rosy', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-10-18T19:59:17'}, u'uniqueid': u'00:17:88:01:03:31:c1:6a-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': False, u'hue': 8220, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5418, 0.3938], u'reachable': True, u'mode': u'homeautomation', u'bri': 2, u'sat': 161}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'customsettings': {u'xy': [0.5415, 0.39], u'bri': 2}, u'mode': u'custom'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'5': {u'swversion': u'2.0.022', u'name': u'Lampada soggiorno 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T10:19:57'}, u'uniqueid': u'cc:cc:cc:ff:fe:56:c3:94-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 380}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'4': {u'swversion': u'2.0.022', u'name': u'Plafoniera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-15T17:54:16'}, u'uniqueid': u'cc:cc:cc:ff:fe:3a:8a:c7-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Samsung', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-18T21:04:09'}, u'uniqueid': u'7c:b0:3e:aa:0a:03:29:ef-03', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'OSRAM', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'plug'}, u'type': u'On/Off plug-in unit', u'modelid': u'Plug 01'}, u'6': {u'swversion': u'2.0.022', u'name': u'Lampada soggiorno 2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T10:27:01'}, u'uniqueid': u'14:b4:57:ff:fe:7e:13:0c-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 380}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'9': {u'swversion': u'V1.04.12', u'name': u'Sony', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-26T13:44:57'}, u'uniqueid': u'7c:b0:3e:aa:00:b2:78:98-03', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'OSRAM', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'plug'}, u'type': u'On/Off plug-in unit', u'modelid': u'Plug 01'}, u'8': {u'swversion': u'1.2.214', u'name': u'Lampada soggiorno 3', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-20T18:26:02'}, u'uniqueid': u'00:0d:6f:ff:fe:fd:6d:82-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E14 W op/ch 400lm'}}
   Hue Lights Debug                Loaded lights list - {u'11': {u'swversion': u'2.0.022', u'name': u'Balcone camera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-01-26T19:50:03'}, u'uniqueid': u'cc:cc:cc:ff:fe:a3:1a:d5-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 447}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'10': {u'swversion': u'2.0.022', u'name': u'Balcone sala', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-01-26T19:42:07'}, u'uniqueid': u'cc:cc:cc:ff:fe:36:c4:10-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 447}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'12': {u'swversion': u'1.2.217', u'name': u'Soffitto Camera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2021-12-27T12:33:24'}, u'uniqueid': u'8c:f6:81:ff:fe:09:9f:a3-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 127, u'ct': 338}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'FLOALT panel WS 60x60'}, u'1': {u'swversion': u'1.88.1', u'name': u'Camino', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-11T19:52:38'}, u'productid': u'Philips-LTW012-1-E14CTv1', u'uniqueid': u'00:17:88:01:03:bb:4d:dc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 450, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance candle', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'303C735A', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'tableshade'}, u'type': u'Color temperature light', u'modelid': u'LTW012'}, u'3': {u'swversion': u'67.91.1', u'name': u'Reno', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-10-18T19:58:29'}, u'uniqueid': u'00:17:88:01:03:31:c1:65-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': False, u'hue': 5202, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5354, 0.3767], u'reachable': True, u'mode': u'homeautomation', u'bri': 157, u'sat': 118}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'customsettings': {u'xy': [0.5355, 0.3752], u'bri': 157}, u'mode': u'custom'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'2': {u'swversion': u'67.91.1', u'name': u'Rosy', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-10-18T19:59:17'}, u'uniqueid': u'00:17:88:01:03:31:c1:6a-0b', u'capabilities': {u'control': {u'colorgamut': [[0.704, 0.296], [0.2151, 0.7106], [0.138, 0.08]], u'mindimlevel': 10000, u'maxlumen': 120, u'colorgamuttype': u'A'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue bloom', u'state': {u'on': False, u'hue': 8220, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5418, 0.3938], u'reachable': True, u'mode': u'homeautomation', u'bri': 2, u'sat': 161}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'customsettings': {u'xy': [0.5415, 0.39], u'bri': 2}, u'mode': u'custom'}, u'direction': u'upwards', u'archetype': u'huebloom'}, u'type': u'Color light', u'modelid': u'LLC011'}, u'5': {u'swversion': u'2.0.022', u'name': u'Lampada soggiorno 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T10:19:57'}, u'uniqueid': u'cc:cc:cc:ff:fe:56:c3:94-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 380}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'4': {u'swversion': u'2.0.022', u'name': u'Plafoniera', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-15T17:54:16'}, u'uniqueid': u'cc:cc:cc:ff:fe:3a:8a:c7-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'ceilinground'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Samsung', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-18T21:04:09'}, u'uniqueid': u'7c:b0:3e:aa:0a:03:29:ef-03', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'OSRAM', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'plug'}, u'type': u'On/Off plug-in unit', u'modelid': u'Plug 01'}, u'6': {u'swversion': u'2.0.022', u'name': u'Lampada soggiorno 2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-16T10:27:01'}, u'uniqueid': u'14:b4:57:ff:fe:7e:13:0c-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 250}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 380}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'TRADFRI bulb E27 WS opal 1000lm'}, u'9': {u'swversion': u'V1.04.12', u'name': u'Sony', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-26T13:44:57'}, u'uniqueid': u'7c:b0:3e:aa:00:b2:78:98-03', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': False, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'OSRAM', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'plug'}, u'type': u'On/Off plug-in unit', u'modelid': u'Plug 01'}, u'8': {u'swversion': u'1.2.214', u'name': u'Lampada soggiorno 3', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-11-20T18:26:02'}, u'uniqueid': u'00:0d:6f:ff:fe:fd:6d:82-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Dimmable light', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'IKEA of Sweden', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'TRADFRI bulb E14 W op/ch 400lm'}}
   Hue Lights Debug                Starting parseAllHueLightsData.
   Hue Lights Debug                parseAllHueLightsData: There are 12 lights on the Hue bridge and 14 Indigo devices controlling Hue devices.
   Hue Lights Debug                Starting updateGroupsList.
   Hue Lights Debug                Sending command to bridge: http://192.168.1.30/api/fRgyDBWyp9x4Cbd0Cnb1V1DKM21DrCqGKlwO0jNi/groups
   Hue Lights Debug                Got response {u'10': {u'name': u'Soggiorno', u'lights': [u'8', u'6', u'5', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 254, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'13': {u'name': u'Balconi', u'lights': [u'10', u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 1, u'ct': 447}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'12': {u'name': u'Televisori', u'lights': [u'7', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'TV'}, u'3': {u'name': u'Camera', u'lights': [u'12', u'3', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8220, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5418, 0.3938], u'bri': 2, u'ct': 338, u'sat': 161}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'2': {u'name': u'Cucina', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'5': {u'name': u'Bagno Di Servizio', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'4': {u'name': u'Cameretta', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 1, u'ct': 362}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kids bedroom'}, u'7': {u'name': u'Anticamera', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'6': {u'name': u'Bagno Padronale', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Marco', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'8': {u'name': u'Box', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}}
   Hue Lights Debug                Loaded groups list - {u'10': {u'name': u'Soggiorno', u'lights': [u'8', u'6', u'5', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 254, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'13': {u'name': u'Balconi', u'lights': [u'10', u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 1, u'ct': 447}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'12': {u'name': u'Televisori', u'lights': [u'7', u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'TV'}, u'3': {u'name': u'Camera', u'lights': [u'12', u'3', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8220, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5418, 0.3938], u'bri': 2, u'ct': 338, u'sat': 161}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'2': {u'name': u'Cucina', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'5': {u'name': u'Bagno Di Servizio', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'4': {u'name': u'Cameretta', u'lights': [u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select', u'colormode': u'ct', u'bri': 1, u'ct': 362}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kids bedroom'}, u'7': {u'name': u'Anticamera', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'6': {u'name': u'Bagno Padronale', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Marco', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'8': {u'name': u'Box', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}}
   Hue Lights Debug                Starting parseAllHueGroupsData.
Thank you
Marco
Tue Dec 28, 2021 11:01 am
AusTxNerd offline
Added three new outdoor models
First, thanks for a great plugin :D and for making it so easy to add new models.
I've added the following three models to `kHueBulbDeviceIDs` and they are working as expected:
# 1746330V7 - Hue Appear Outdoor wall light, White and color ambiance
# 1743830V7 - Hue Econic Outdoor Wall light, White and color ambiance
# 1741930V7 - Hue Calla Outdoor bollard, White and color ambiance
Mike
Tue Dec 28, 2021 12:26 pm
nsheldon offline
Hey Mike.
Thanks! And thanks for the report. I’ll include those in the next plug-in update.
Fri Dec 31, 2021 12:20 am
jakey12 offline
Having similar issue with the 100w/1600 Lumens bulbs.
Philips Hue White and Color Ambiance E26 1600lm (LCA009)
Here is some of the output from the debug
swconfigid: "219F5576",
productid: "Philips-LCA009-1-A21ECLv1"
type: "Extended color light",
modelid: "LCA009",
manufacturername: "Signify Netherlands B.V.",
productname: "Hue color lamp",
Page 93 of 103 1 ... 90, 91, 92, 93, 94, 95, 96 ... 103
