Hue Lights discussion
Sat Oct 23, 2021 6:48 pm
nsheldon offline
Re: Hue Lights discussion
Version 1.7.59 Posted
  • Added support for a new Hue Still Ceiling light.
  • Added support for 2 new Hue color pendant lights.
  • Added support for a new Hue dimmable light.
Sun Nov 07, 2021 8:05 am
reugster offline
HI Nathan,
I have a few more bulbs to add. Let me know if you need anything else.
THanks
LTA010 75 (1100) White Ambiance
LCA007 75w (1100) White and Color
LCA005 800 White and Color
LTA008 800 White Ambiance
Sun Nov 07, 2021 11:55 am
nsheldon offline
Hi.
Thanks for the report. I think you covered everything I need. Thanks! I’ll add support in the next update.
Sun Nov 07, 2021 2:40 pm
indigo2200 offline
HI, thanks for this wonderful plug-in.
Does the plug-in support Innr SP 220 zigbee smart plug OR the Ikea Trådløs wall-plug??
Tue Nov 09, 2021 12:57 pm
Korey offline
reugster wrote:
HI Nathan,
I seem to have the same model (LCA005) not showing up in the plugin.
Except there is no 800 in the bulb info.
Got response {u'1': {u'swversion': u'1.76.11', u'name': u'Hue color lamp 1', u'swupdate': {u'state': u'readytoinstall', u'lastinstall':
u'2021-11-09T00:08:40'}, u'productid': u'Philips-LCA005-1-A19ECLv7', u'uniqueid': u'00:17:88:01:0b:63:1b:18-0b', u'capabilities': {u'control': {u'ct':
{u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'},
u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 6866, u'colormode': u'hs',
u'effect': u'none', u'alert': u'select', u'xy': [0.5516, 0.4134], u'reachable': True, u'mode': u'homeautomation', u'bri': 84, u'ct': 500, u'sat': 254},
u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'FC478E3A', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode':
u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA005'}, u'3': {u'swversion': u'1.76.11',
Screen Shot 2021-11-09 at 10.45.36 AM.png (99.81 KiB) Viewed 2322 times
Korey
Tue Nov 09, 2021 11:47 pm
reugster offline
Korey wrote:
reugster wrote:
HI Nathan,
Its just the lumens of the bulb . I needed to differentiate from the 1100 as I had 4 sets of different bulbs.
Wed Nov 10, 2021 2:41 am
nsheldon offline
The Hue Lights plugin doesn't yet support the Innr SP 220 plug, but if you can pair it with the Hue bridge, the plugin can be updated to support that plug. The plugin does support one model of the IKEA Tradfri plug, but without the exact model ID from the Hue app, I don't know if it's the same plug as the one you're looking it. But again, if you can pair the plug with the Hue bridge, support can be added to the plugin.
Wed Nov 10, 2021 2:52 am
nsheldon offline
Version 1.7.60 Posted
  • Added support for 2 new Hue white/color lights.
  • Added support for 2 new Hue ambiance lights.
  • Added support for the Innr SP 220 plug.
Wed Nov 10, 2021 10:27 am
Korey offline
Thanks for adding the new bulbs! :D
Unfortunately the plugin now gives this error:
Nov 10, 2021 at 8:21:05 AM
   Stopping plugin Hue Lights (pid 94162)
   Stopped plugin Hue Lights
   Upgrading plugin Hue Lights to newer version 1.7.60 (previous version moved to trash)
   Loading plugin "Hue Lights 1.7.60"
   Starting plugin "Hue Lights 1.7.60" (pid 94270)
   Hue Lights Error                Error in plugin execution InitializeMain:
  File "plugin.py", line 33, in <module>
SyntaxError: ('invalid syntax', ('/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Hue Lights.indigoPlugin/Contents/Server Plugin/supportedDevices.py', 270, 440, "kAmbianceDeviceIDs = ['LLM010', 'LLM011', 'LLM012', 'LTW001', 'LTC001', 'LTC003', 'LTC002', 'LTC003', 'LTW004', 'LTC011', 'LTW010', 'LTW011', 'LTW012', 'LTW013', 'LTW014', 'LTW015', 'LTE001', 'LTF001', 'LTF002', 'LTG001', 'LTG002', 'LTD001', 'LTD002', 'LTP001', 'LTP002', 'LTP003', 'LTP004', 'LTP005', 'LTD003', 'LTD009', 'LTD010', 'LTD011', 'LFF001', 'LTT001', 'LDT001', 'LTB002', 'LTA001', 'LTA002', 'LTA003', 'LTA008', 'LTA010'. 'HML001', 'HML002', 'HML003', 'HML004', 'HML005', 'HML006', '3402931P7', '3261330P6', 'Classic A60 TW', 'PAR16 50 TW', 'RS 128 T', 'RS 228 T', 'FLOALT panel WS 30x90', 'FLOALT panel WS 30x30', 'FLS-CT', 'TRADFRI bulb E26 WS opal 1000lm', 'TRADFRI bulb E27 WS opal 1000lm', 'TRADFRI bulb E27 WS opal 980lm', 'TRADFRI bulb E14 WS opal 600lm', 'TRADFRI bulb GU10 WS 400lm', 'ZBT-ColorTemperature', 'TS0502A', 'MR16 TW OSRAM']\n"))
   Stopping plugin "Hue Lights 1.7.60" (pid 94270)
   Stopped plugin "Hue Lights 1.7.60"
Korey
Wed Nov 10, 2021 12:33 pm
nsheldon offline
Whoa! Thanks. I'll check that and get it fixed shortly.
Wed Nov 10, 2021 6:23 pm
nsheldon offline
Version 1.7.61 Posted
  • Fixed a syntax error bug in version 1.7.60 that caused the plugin to crash during loading.
Wed Nov 10, 2021 6:55 pm
Korey offline
Thanks for the quick fix!!! :D :D
Korey
Thu Nov 11, 2021 2:53 pm
cesarvog offline
Hi Mr. Sheldon,
I hope you don't mind I took the liberty of modifying myself the supported devices file, to try to add support to the following 3 way in wall Zigbee switch device, I got cheap from an online store here in Brazil:
- https://zigbee.blakadder.com/3A_HGZB-43.html
Once I got hold of the Zigbee device itself, I then proceeded adding it to my deCONZ ConbeeII Zigbee interface.
Since I also have Homebridge running in my network, I was then able to make the three switches appear on the Homebridge Accessories web page and on Apple's Home app in my iPhone. Clicking on each individual device showed all three worked as expected, in the deCONZ Phoscon web interface (primary link), as well as the Homebridge Web Interface (secondary link), and also in the Home App (tertiary link). I was already happy with those results, but since Indigo is my main automation hub, I was eager to find a way to create individual devices for each switch in Indigo. Trying creating the devices as Hue Lights in Indigo failed because the current release did not have the device model in it's dictionary.
So I took the plunge and modified the above mentioned file myself andI must admit I was happily surprised to find out that my clumsy intervention was successful, as I was then able to add the 3 switches successfully as Hue light devices.
So, for the sake of other users that may also own the above mentioned device, I thought it would be nice to drop you this little post.
Please refer to the 3 attached files below for more info.
Best regards and thank you once again for this wonderful plugin.
Cesar
PS: I'm running Indigo 2021.1.2 and Hue Light plugin version 1.7.61
supportedDevices.txt
Modified supportedDevices.py file
(17.46 KiB) Downloaded 62 times
Device in Homebridge from where I got the Model
Screen Shot 2021-11-11 at 17.20.58.png (64.19 KiB) Viewed 2219 times
Devices in Indigo
Screen Shot 2021-11-11 at 17.20.37.png (29.01 KiB) Viewed 2219 times
Sun Nov 14, 2021 3:22 pm
I have to get 30+ lamps for my new home I like to go with either Ikea or Philips Hue ($=2*ikea).
I don't like the shelly devices, they sometimes don't work and don't have nice physical dimmers.
As I understand it (please comment or correct me)
1. Ikea tradfri only uses zigbee and works with its owns dimmers and the Ikea app through the Ikea gateway and ?? also through the Philips hue gateway and also the Philips hue dimmers ??
2. Philips Hue bulbs come EITHER in zigbee OR in bluetooth versions (??not both??),
With the hue bridge/gateway you can set light/color.. through iPhone app and hue dimmers. Bluetooth can bet set also directly iPhone app bluetooth--> bulb; When using bluetooth the bridge/iphone has to be within 10 meters to talk to the bulb
3. the Indigo Hue plugin talks to the Philips hue bridge / gateway through HTTP / Restful interface. Only one gateway is supported, for a second bridge a second plugin with changed name for the plugin has to be used.
Is this correct?
Sun Nov 14, 2021 4:39 pm
siclark offline
Another option if you are starting from scratch is the hubitat as a hub then you can use any bulb and a wider choice of zigbee devices.
Page 92 of 103 1 ... 89, 90, 91, 92, 93, 94, 95 ... 103
