Hue Lights discussion
Mon Sep 13, 2021 1:58 am
nsheldon offline
Re: Hue Lights discussion
Version 1.7.57 Posted
  • Fixed a bug that would cause continuous Indigo error messages if a motion sensor was disabled on the Hue bridge.
  • Added support for a new Hue ambiance candle bulb.
  • Added support for a Hue Aurelle panel.
Sat Sep 18, 2021 8:32 am
yassi offline
Hi Nathan!
Would you please be so kind to add a new bulb to the plugin?
It's a Lightway/Megos E27, 806 lm bulb, 9W.
The model number is L122CB63H11A or TS0505B (in the Hue app)
They can be found at ALDI in Germany.
I was able to add it to the Hue app.
Attached the debug log. Had to cut it, because it was way too long. And I've replaced some information (email, API).
For the bulb please look for the strings TZ3000_kohbva1f and TS0505B in the log.
Thanks in advance!
Yassi
18. Sep 2021 at 15:59:16
   Hue Lights                      Debug logging enabled
   Hue Lights Debug                Turning on debug logging (due to plugin prefs being updated).
   Hue Lights Debug                Starting parseAllHueSensorsData.
   Hue Lights Debug                Starting updateSensorsList.
   Hue Lights Debug                Starting updateLightsList.
   Hue Lights Debug                Sending command to bridge: http://192.168.100.105/api/xxx/lights
   Hue Lights Debug                Got response {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}
   Hue Lights Debug                Loaded lights list - {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}
   Hue Lights Debug                Starting parseAllHueLightsData.
   Hue Lights Debug                parseAllHueLightsData: There are 8 lights on the Hue bridge and 9 Indigo devices controlling Hue devices.
   Hue Lights Debug                Starting updateGroupsList.
   Hue Lights Debug                Sending command to bridge: http://192.168.100.105/api/xxx/groups
   Hue Lights Debug                Got response {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}
   Hue Lights Debug                Loaded groups list - {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}
   Hue Lights Debug                Starting parseAllHueGroupsData.
   Hue Lights Debug                Starting parseOneHueGroupData.
   Hue Lights Debug                updateDeviceState: Updating device Schlafzimmer alle Lampen state: alertMode. Old value = . New value = lselect
   Hue Lights Debug                updateDeviceState: Updating device Schlafzimmer alle Lampen state: effect. Old value = . New value = none
   Hue Lights Debug                updateDeviceState: Updating device Schlafzimmer alle Lampen state: effect. Old value = none. New value =
   Hue Lights Debug                updateDeviceState: Updating device Schlafzimmer alle Lampen state: alertMode. Old value = lselect. New value =
   Hue Lights Debug                Starting didDeviceCommPropertyChange.
   Reloading plugin "Hue Lights 1.7.57"
   Stopping plugin "Hue Lights 1.7.57" (pid 11083)
   Hue Lights Debug                runConcurrentThread stopped.
   Hue Lights Debug                runConcurrentThread exiting.
   Hue Lights Debug                Stopping device: Alle Hue Lampen
   Hue Lights Debug                Stopping device: Bettlampe
   Hue Lights Debug                Stopping device: Bettlampe links
   Hue Lights Debug                Stopping device: Bettlampe rechts
   Hue Lights Debug                Stopping device: Couchlampe
   Hue Lights Debug                Stopping device: Flurlampe
   Hue Lights Debug                Stopping device: Papierlampe
   Hue Lights Debug                Stopping device: Schlafzimmer alle Lampen
   Hue Lights Debug                Stopping device: Tischlampe
   Hue Lights Debug                Plugin shutdown called.
   Stopped plugin "Hue Lights 1.7.57"
   Starting plugin "Hue Lights 1.7.57" (pid 11234)
   Hue Lights Debug                Debug logging started at plugin initialization.
   Hue Lights Debug                Starting plugin initialization.
   Started plugin "Hue Lights 1.7.57"
   Hue Lights Debug                Startup called.
   Hue Lights Debug                Running plugin version check (if enabled).
   Hue Lights Debug                pluginPrefs contains 30 presets.
   Hue Lights Debug                pluginPrefs are:
Prefs : (dict)
     address : 192.168.100.105 (string)
     debugLabel :  (string)
     emailLabel :  (string)
     hostId : 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq (string)
     instructions0 :  (string)
     instructions1 :  (string)
     instructions2 :  (string)
     instructions3 :  (string)
     labelAddress :  (string)
     labelHostId :  (string)
     maxPresetCount : 30 (string)
     maxPresetCountLabel :  (string)
     noticeLabel :  (string)
     noticeLabel0 :  (string)
     presets : (list)
          Item : (list)
               Item : Preset #1 Tischlampe (string)
               Item : (dict)
                    alertMode : lselect (string)
                    alertMode.ui : lselect (string)
                    blueLevel : 0 (real)
                    blueLevel.ui : 0 (string)
                    brightnessLevel : 0 (integer)
                    brightnessLevel.ui : 0 (string)
                    colorBlue : 0 (integer)
                    colorBlue.ui : 0 (string)
                    colorGreen : 0 (integer)
                    colorGreen.ui : 0 (string)
                    colorMode : hs (string)
                    colorMode.ui : hs (string)
                    colorRed : 0 (integer)
                    colorRed.ui : 0 (string)
                    colorTemp : 2933 (integer)
                    colorTemp.ui : 2933 (string)
                    colorX : 0.4396 (real)
                    colorX.ui : 0.4396 (string)
                    colorY : 0.3711 (real)
                    colorY.ui : 0.3711 (string)
                    effect : none (string)
                    effect.ui : none (string)
                    greenLevel : 0 (real)
                    greenLevel.ui : 0 (string)
                    hue : 28 (integer)
                    hue.ui : 28 (string)
                    onOffState : false (bool)
                    online : true (bool)
                    online.ui : True (string)
                    redLevel : 0 (real)
                    redLevel.ui : 0 (string)
                    saturation : 65 (integer)
                    saturation.ui : 65 (string)
                    whiteLevel : 35 (real)
                    whiteLevel.ui : 35 (string)
                    whiteTemperature : 2933 (real)
                    whiteTemperature.ui : 2933 (string)
               Item : -1 (integer)
          Item : (list)
               Item : Preset #1 Bettlampe (string)
               Item : (dict)
                    blueLevel : 35 (real)
                    blueLevel.ui : 35 (string)
                    brightnessLevel : 100 (integer)
                    brightnessLevel.ui : 100 (string)
                    colorBlue : 90 (integer)
                    colorBlue.ui : 90 (string)
                    colorGreen : 167 (integer)
                    colorGreen.ui : 167 (string)
                    colorRed : 254 (integer)
                    colorRed.ui : 254 (string)
                    greenLevel : 65 (real)
                    greenLevel.ui : 65 (string)
                    hue : 28 (integer)
                    onOffState : true (bool)
                    redLevel : 100 (real)
                    redLevel.ui : 100 (string)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 3 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 4 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 5 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 6 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 7 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 8 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 9 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 10 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 11 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 12 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 13 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 14 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 15 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 16 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 17 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 18 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 19 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 20 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 21 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 22 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 23 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 24 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 25 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 26 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 27 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 28 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 29 (string)
               Item : (dict)
               Item : -1 (integer)
          Item : (list)
               Item : Preset 30 (string)
               Item : (dict)
               Item : -1 (integer)
     sep0 :  (string)
     sep00 :  (string)
     sep1 :  (string)
     sep2 :  (string)
     showDebugInfo : true (bool)
     startPairingButton :  (string)
     title :  (string)
     updaterEmail : notify@xxx.de (string)
     updaterEmailsEnabled : true (bool)
     updaterLastCheck : 1631973504 (real)
     updaterLastVersionEmailed : 1.7.55 (string)
   Hue Lights Debug                The username Hue Lights uses to connect to the Hue bridge is 7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq
   Hue Lights Debug                Starting getHueConfig.
   Hue Lights Debug                Got response {u'rules': {u'10': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'33:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 0}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'false', u'address': u'/groups/5/state/all_on'}, {u'operator': u'dx', u'address': u'/groups/5/state/all_on'}, {u'operator': u'gt', u'value': u'0', u'address': u'/sensors/5/state/status'}]}, u'3': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'21:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'JOrd2tQKbGzRdd-'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'0', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/lastupdated'}, {u'operator': u'eq', u'value': u'true', u'address': u'/groups/5/state/all_on'}]}, u'2': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'20:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'storelightstate': True}, u'method': u'PUT', u'address': u'/scenes/JOrd2tQKbGzRdd-'}, {u'body': {u'scene': u'lrC6RwPn-8LjnFS'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/status'}]}, u'5': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'28:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'y7El64GXzhzIGkJ'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:01:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'4': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'27:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'nVpH9TdzRbEeEUb'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:00:01', u'address': u'/sensors/5/state/lastupdated'}]}, u'7': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'30:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'XAVo7dYKhN6HXsf'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:03:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'6': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'29:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'VXPFSFZx81MGTah'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:02:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'9': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'32:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 1}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:05:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'8': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'31:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'aSGOie4t7NLFOKg'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:04:00', u'address': u'/sensors/5/state/lastupdated'}]}}, u'resourcelinks': {u'57987': {u'classid': 2, u'name': u'Autumn living scenes', u'links': [u'/rules/10', u'/rules/9', u'/rules/8', u'/rules/7', u'/rules/6', u'/rules/5', u'/rules/4', u'/rules/3', u'/rules/2', u'/scenes/aSGOie4t7NLFOKg', u'/scenes/XAVo7dYKhN6HXsf', u'/scenes/VXPFSFZx81MGTah', u'/scenes/y7El64GXzhzIGkJ', u'/scenes/nVpH9TdzRbEeEUb', u'/scenes/lrC6RwPn-8LjnFS', u'/scenes/JOrd2tQKbGzRdd-', u'/sensors/5', u'/groups/5', u'/lights/5'], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'-HucBhPLKto0tAXF693k8g:0:DSbafeG6CfheFO2ohGfOfisbk9M'}, u'11496': {u'classid': 1, u'name': u'HueLabs 2.0', u'links': [u'/resourcelinks/57987'], u'recycle': False, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'All installed formulas'}}, u'scenes': {u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4', u'6', u'7'], u'image': u'a1f7da49-d181-4328-abea-68c9dc4b5416', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4', u'6', u'7'], u'image': u'e101a77f-9984-4f61-aac8-15741983c656', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4', u'6', u'7'], u'image': u'7fd2ccc5-5749-4142-b7a5-66405a676f03', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'nVpH9TdzRbEeEUb': {u'picture': u'', u'locked': True, u'name': u'Scene scene1 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2', u'5'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4', u'6', u'7'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'aSGOie4t7NLFOKg': {u'picture': u'', u'locked': True, u'name': u'Scene scene5 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'y7El64GXzhzIGkJ': {u'picture': u'', u'locked': True, u'name': u'Scene scene2 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'JOrd2tQKbGzRdd-': {u'picture': u'', u'group': u'5', u'name': u'Scene storageScene ', u'appdata': {}, u'lights': [u'5'], u'lastupdated': u'2020-11-30T19:52:00', u'recycle': True, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': True, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4', u'6', u'7'], u'image': u'1e42b2e8-d02e-40d2-9c8d-b1fd8216c686', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4', u'6', u'7'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'XAVo7dYKhN6HXsf': {u'picture': u'', u'locked': True, u'name': u'Scene scene4 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4', u'6', u'7'], u'image': u'b90c8900-a6b7-422c-a5d3-e170187dbf8c', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'VXPFSFZx81MGTah': {u'picture': u'', u'locked': True, u'name': u'Scene scene3 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4', u'6', u'7'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4', u'6', u'7'], u'image': u'a6a03e6a-fe6e-45bc-b686-878137f3ba91', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4', u'6', u'7'], u'image': u'4f2ed241-5aea-4c9d-8028-55d2b111e06f', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2', u'5'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4', u'6', u'7'], u'image': u'adfa9c3e-e9aa-4b65-b9d3-c5b2c0576715', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2', u'5'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrC6RwPn-8LjnFS': {u'picture': u'', u'locked': True, u'name': u'Scene scene0 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}}, u'lights': {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}, u'5': {u'name': u'Tischlampe, Falling leaves, 30', u'uniqueid': u'2:10:bc5b-aef1-4b40-be99', u'config': {u'on': True, u'reachable': True}, u'swversion': u'2.0', u'state': {u'status': 0, u'lastupdated': u'2020-11-30T19:52:08'}, u'manufacturername': u'Philips', u'recycle': True, u'type': u'CLIPGenericStatus', u'modelid': u'HUELABSVTOGGLE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e': {u'last use date': u'2021-06-06T10:48:03', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'67e4487f-aa2c-41f7-b2ea-c3bd63600505': {u'last use date': u'2021-09-18T13:58:01', u'create date': u'2021-06-06T10:50:25', u'name': u'Hue Beta#iPhone XR'}, u'6ada8095-fcf7-46fb-acd0-5c88cf1e1888': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2021-09-18T13:59:29', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'8227f6c7-8a38-43c2-a1fc-55eec72589e8': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'd7474a44-5a98-4521-8b00-3e843ee4ed54': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}, u'3e4c7d2b-a7b7-45d1-8517-90b06f37cd1f': {u'last use date': u'2020-11-05T10:05:19', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'b7b7c171-2f17-4f14-91c8-0c78cf058c89': {u'last use date': u'2020-11-29T20:15:26', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'111', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2021-09-15T12:48:08'}, u'lastchange': u'2021-09-15T12:49:00', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': True, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2021-09-18T15:59:29', u'proxyport': 0, u'UTC': u'2021-09-18T13:59:29', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.46.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1947054040', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights Debug                Loaded entire Hue bridge configuration - {u'rules': {u'10': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'33:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 0}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'false', u'address': u'/groups/5/state/all_on'}, {u'operator': u'dx', u'address': u'/groups/5/state/all_on'}, {u'operator': u'gt', u'value': u'0', u'address': u'/sensors/5/state/status'}]}, u'3': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'21:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'JOrd2tQKbGzRdd-'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'0', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/lastupdated'}, {u'operator': u'eq', u'value': u'true', u'address': u'/groups/5/state/all_on'}]}, u'2': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'20:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'storelightstate': True}, u'method': u'PUT', u'address': u'/scenes/JOrd2tQKbGzRdd-'}, {u'body': {u'scene': u'lrC6RwPn-8LjnFS'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'dx', u'address': u'/sensors/5/state/status'}]}, u'5': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'28:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'y7El64GXzhzIGkJ'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:01:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'4': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'27:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'nVpH9TdzRbEeEUb'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:00:01', u'address': u'/sensors/5/state/lastupdated'}]}, u'7': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'30:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'XAVo7dYKhN6HXsf'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:03:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'6': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'29:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'VXPFSFZx81MGTah'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:02:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'9': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'32:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'status': 1}, u'method': u'PUT', u'address': u'/sensors/5/state'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:05:00', u'address': u'/sensors/5/state/lastupdated'}]}, u'8': {u'status': u'enabled', u'lasttriggered': u'none', u'timestriggered': 0, u'name': u'31:', u'created': u'2020-11-30T19:51:56', u'actions': [{u'body': {u'scene': u'aSGOie4t7NLFOKg'}, u'method': u'PUT', u'address': u'/groups/5/action'}], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'conditions': [{u'operator': u'eq', u'value': u'1', u'address': u'/sensors/5/state/status'}, {u'operator': u'ddx', u'value': u'PT00:04:00', u'address': u'/sensors/5/state/lastupdated'}]}}, u'resourcelinks': {u'57987': {u'classid': 2, u'name': u'Autumn living scenes', u'links': [u'/rules/10', u'/rules/9', u'/rules/8', u'/rules/7', u'/rules/6', u'/rules/5', u'/rules/4', u'/rules/3', u'/rules/2', u'/scenes/aSGOie4t7NLFOKg', u'/scenes/XAVo7dYKhN6HXsf', u'/scenes/VXPFSFZx81MGTah', u'/scenes/y7El64GXzhzIGkJ', u'/scenes/nVpH9TdzRbEeEUb', u'/scenes/lrC6RwPn-8LjnFS', u'/scenes/JOrd2tQKbGzRdd-', u'/sensors/5', u'/groups/5', u'/lights/5'], u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'-HucBhPLKto0tAXF693k8g:0:DSbafeG6CfheFO2ohGfOfisbk9M'}, u'11496': {u'classid': 1, u'name': u'HueLabs 2.0', u'links': [u'/resourcelinks/57987'], u'recycle': False, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'Link', u'description': u'All installed formulas'}}, u'scenes': {u'-cndADBHxR71zS9': {u'picture': u'', u'group': u'3', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'R2BaF_r03_d06'}, u'lights': [u'3'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'c37A8UgQg5CTb03': {u'picture': u'', u'group': u'4', u'name': u'Entspannen', u'appdata': {u'version': 1, u'data': u'vJEIV_r04_d01'}, u'lights': [u'4', u'6', u'7'], u'image': u'a1f7da49-d181-4328-abea-68c9dc4b5416', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'WZnkjWsKhaR3A0v': {u'picture': u'', u'group': u'4', u'name': u'Lesen', u'appdata': {u'version': 1, u'data': u'taa8l_r04_d02'}, u'lights': [u'4', u'6', u'7'], u'image': u'e101a77f-9984-4f61-aac8-15741983c656', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'0U5B7gai07Ju1UY': {u'picture': u'', u'group': u'4', u'name': u'Energie tanken', u'appdata': {u'version': 1, u'data': u'AB5Ky_r04_d04'}, u'lights': [u'4', u'6', u'7'], u'image': u'7fd2ccc5-5749-4142-b7a5-66405a676f03', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'nVpH9TdzRbEeEUb': {u'picture': u'', u'locked': True, u'name': u'Scene scene1 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'FknzutOGHm4BYsX': {u'picture': u'', u'group': u'1', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'usdOu_r01_d07'}, u'lights': [u'1', u'2', u'5'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'hQaXlPphHWVOxDF': {u'picture': u'', u'group': u'4', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'eSBHw_r04_d05'}, u'lights': [u'4', u'6', u'7'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'aSGOie4t7NLFOKg': {u'picture': u'', u'locked': True, u'name': u'Scene scene5 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'y7El64GXzhzIGkJ': {u'picture': u'', u'locked': True, u'name': u'Scene scene2 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'JOrd2tQKbGzRdd-': {u'picture': u'', u'group': u'5', u'name': u'Scene storageScene ', u'appdata': {}, u'lights': [u'5'], u'lastupdated': u'2020-11-30T19:52:00', u'recycle': True, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': True, u'type': u'GroupScene'}, u'dXMWPRKM1o19CJb': {u'picture': u'', u'group': u'4', u'name': u'Nordlichter', u'appdata': {u'version': 1, u'data': u'yTx1G_r04_d17'}, u'lights': [u'4', u'6', u'7'], u'image': u'1e42b2e8-d02e-40d2-9c8d-b1fd8216c686', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'yQ17vjEsOf3udxO': {u'picture': u'', u'group': u'4', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'ehrih_r04_d07'}, u'lights': [u'4', u'6', u'7'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'XAVo7dYKhN6HXsf': {u'picture': u'', u'locked': True, u'name': u'Scene scene4 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'Pu5spbERsxuPreh': {u'picture': u'', u'group': u'4', u'name': u'Konzentrieren', u'appdata': {u'version': 1, u'data': u'6ztbk_r04_d03'}, u'lights': [u'4', u'6', u'7'], u'image': u'b90c8900-a6b7-422c-a5d3-e170187dbf8c', u'lastupdated': u'2020-11-29T20:23:31', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'VXPFSFZx81MGTah': {u'picture': u'', u'locked': True, u'name': u'Scene scene3 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}, u'yFwsHk1yJxSFl89': {u'picture': u'', u'group': u'3', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'lNgcI_r03_d05'}, u'lights': [u'3'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'kdzO5Ko18osmZD3': {u'picture': u'', u'group': u'4', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'fNBn4_r04_d06'}, u'lights': [u'4', u'6', u'7'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrfEjORNiWi57sk': {u'picture': u'', u'group': u'4', u'name': u'Tropend\xe4mmerung', u'appdata': {u'version': 1, u'data': u'oZLWi_r04_d16'}, u'lights': [u'4', u'6', u'7'], u'image': u'a6a03e6a-fe6e-45bc-b686-878137f3ba91', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'9Emql0TziBf5wSL': {u'picture': u'', u'group': u'4', u'name': u'Sonnenuntergang Savanne', u'appdata': {u'version': 1, u'data': u'L4qxq_r04_d15'}, u'lights': [u'4', u'6', u'7'], u'image': u'4f2ed241-5aea-4c9d-8028-55d2b111e06f', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'S0mKdDgaKyvV-Me': {u'picture': u'', u'group': u'3', u'name': u'Nachtlicht', u'appdata': {u'version': 1, u'data': u'1Iamu_r03_d07'}, u'lights': [u'3'], u'image': u'28bbfeff-1a0c-444e-bb4b-0b74b88e0c95', u'lastupdated': u'2017-08-19T10:18:21', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'h9bdCAjaKr5tpVq': {u'picture': u'', u'group': u'1', u'name': u'Hell', u'appdata': {u'version': 1, u'data': u'1VI5t_r01_d05'}, u'lights': [u'1', u'2', u'5'], u'image': u'732ff1d9-76a7-4630-aad0-c8acc499bb0b', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'7QgI7NTQy8fZcu3': {u'picture': u'', u'group': u'4', u'name': u'Fr\xfchlingsbl\xfcten', u'appdata': {u'version': 1, u'data': u'Q5MeU_r04_d18'}, u'lights': [u'4', u'6', u'7'], u'image': u'adfa9c3e-e9aa-4b65-b9d3-c5b2c0576715', u'lastupdated': u'2020-11-29T20:23:32', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'UusHfDe9hOQiIAW': {u'picture': u'', u'group': u'1', u'name': u'Gedimmt', u'appdata': {u'version': 1, u'data': u'tMqXz_r01_d06'}, u'lights': [u'1', u'2', u'5'], u'image': u'8c74b9ba-6e89-4083-a2a7-b10a1e566fed', u'lastupdated': u'2019-06-22T16:10:42', u'recycle': False, u'version': 2, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'locked': False, u'type': u'GroupScene'}, u'lrC6RwPn-8LjnFS': {u'picture': u'', u'locked': True, u'name': u'Scene scene0 ', u'appdata': {}, u'lastupdated': u'2020-11-30T19:51:55', u'lights': [u'5'], u'version': 2, u'recycle': True, u'owner': u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e', u'type': u'LightScene'}}, u'lights': {u'1': {u'swversion': u'5.130.1.30000', u'name': u'Couchlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:36'}, u'uniqueid': u'00:17:88:01:10:2f:f2:0b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'1.88.1', u'name': u'Flurlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2021-08-12T12:25:50'}, u'productid': u'Philips-LWB010-1-A19DLv3', u'uniqueid': u'00:17:88:01:02:86:2a:7c-0b', u'capabilities': {u'control': {u'mindimlevel': 5000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'swconfigid': u'2628EA25', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'2': {u'swversion': u'5.130.1.30000', u'name': u'Papierlampe', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2020-03-03T13:20:33'}, u'uniqueid': u'00:17:88:01:02:30:83:9b-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Signify Netherlands B.V.', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'5': {u'swversion': u'V1.04.12', u'name': u'Tischlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T14:58:57'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:a2-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'4': {u'swversion': u'2.0', u'name': u'Bettlampe', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-01-25T16:47:48'}, u'uniqueid': u'00:15:8d:00:02:0a:f5:3c-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.7, 0.3], [0.11, 0.82], [0.12, 0.08]], u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 204}, u'manufacturername': u'innr', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'RB 185 C'}, u'7': {u'swversion': u'V1.04.12', u'name': u'Bettlampe links', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2020-11-29T20:21:55'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:5a:0b-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'6': {u'swversion': u'V1.04.12', u'name': u'Bettlampe rechts', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-06-08T17:55:26'}, u'uniqueid': u'7c:b0:3e:aa:00:ab:64:b3-03', u'capabilities': {u'control': {u'ct': {u'max': 555, u'min': 151}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 370, u'sat': 0}, u'manufacturername': u'OSRAM', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'PAR 16 50 RGBW - LIGHTIFY'}, u'8': {u'swversion': u'', u'name': u'X', u'swupdate': {u'state': u'notupdatable', u'lastinstall': None}, u'uniqueid': u'60:a4:23:ff:fe:c1:fe:96-01', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 322, u'sat': 35}, u'manufacturername': u'_TZ3000_kohbva1f', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'TS0505B'}}, u'groups': {u'1': {u'name': u'Wohnzimmer', u'lights': [u'5', u'1', u'2'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 1, u'ct': 370, u'sat': 0}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Flur', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'K\xfcche', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Custom group for $lights', u'lights': [u'5'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.3805, 0.3769], u'bri': 254, u'ct': 370, u'sat': 0}}, u'4': {u'name': u'Schlafzimmer', u'lights': [u'7', u'6', u'4'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'ct', u'effect': u'none', u'alert': u'lselect', u'xy': [0.4578, 0.4101], u'bri': 1, u'ct': 370, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'6': {u'name': u'G\xe4stebad', u'lights': [u'8'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.0, 0.0], u'bri': 254, u'ct': 322, u'sat': 35}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}}, u'schedules': {}, u'sensors': {u'1': {u'name': u'Daylight', u'config': {u'on': True, u'configured': False, u'sunriseoffset': 30, u'sunsetoffset': -30}, u'swversion': u'1.0', u'state': {u'daylight': None, u'lastupdated': u'none'}, u'manufacturername': u'Signify Netherlands B.V.', u'type': u'Daylight', u'modelid': u'PHDL00'}, u'2': {u'name': u'HL-S00-5000', u'uniqueid': u'4c:61:70:41:70:70:73-HL-00-00', u'config': {u'on': True, u'reachable': True}, u'swversion': u'1.0', u'state': {u'status': 0, u'lastupdated': u'none'}, u'manufacturername': u'LapApps, LLC', u'recycle': False, u'type': u'CLIPGenericStatus', u'modelid': u'HL_STATE'}, u'5': {u'name': u'Tischlampe, Falling leaves, 30', u'uniqueid': u'2:10:bc5b-aef1-4b40-be99', u'config': {u'on': True, u'reachable': True}, u'swversion': u'2.0', u'state': {u'status': 0, u'lastupdated': u'2020-11-30T19:52:08'}, u'manufacturername': u'Philips', u'recycle': True, u'type': u'CLIPGenericStatus', u'modelid': u'HUELABSVTOGGLE'}}, u'config': {u'starterkitid': u'', u'portalconnection': u'connected', u'whitelist': {u'9c2c7bf5-2429-46fa-a8f9-9c4d26a2dd5e': {u'last use date': u'2021-06-06T10:48:03', u'create date': u'2017-08-02T17:59:29', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'67e4487f-aa2c-41f7-b2ea-c3bd63600505': {u'last use date': u'2021-09-18T13:58:01', u'create date': u'2021-06-06T10:50:25', u'name': u'Hue Beta#iPhone XR'}, u'6ada8095-fcf7-46fb-acd0-5c88cf1e1888': {u'last use date': u'2017-08-01T20:42:29', u'create date': u'2017-07-08T16:02:57', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'7HYhiGzk0Fu8DBfvRn4aKFOapMVGPrZbsQCck5cq': {u'last use date': u'2021-09-18T13:59:29', u'create date': u'2016-11-16T18:34:51', u'name': u'Indigo Hue Lights'}, u'8227f6c7-8a38-43c2-a1fc-55eec72589e8': {u'last use date': u'2017-01-13T17:20:31', u'create date': u'2017-01-13T17:10:51', u'name': u"hue_ios_app#Yasmin's iPhone SE"}, u'd7474a44-5a98-4521-8b00-3e843ee4ed54': {u'last use date': u'2019-01-26T14:08:55', u'create date': u'2019-01-07T19:52:07', u'name': u'LightShow-Mac'}, u'3e4c7d2b-a7b7-45d1-8517-90b06f37cd1f': {u'last use date': u'2020-11-05T10:05:19', u'create date': u'2017-01-13T17:09:38', u'name': u"OnSwitch#Yasmin's iPhone SE"}, u'b7b7c171-2f17-4f14-91c8-0c78cf058c89': {u'last use date': u'2020-11-29T20:15:26', u'create date': u'2019-01-07T20:42:26', u'name': u"HueLights#Yasmin's iPhone SE"}}, u'zigbeechannel': 20, u'timezone': u'Europe/Berlin', u'gateway': u'192.168.100.254', u'modelid': u'BSB002', u'portalstate': {u'communication': u'disconnected', u'outgoing': True, u'signedon': True, u'incoming': False}, u'proxyaddress': u'none', u'datastoreversion': u'111', u'replacesbridgeid': None, u'swupdate2': {u'bridge': {u'state': u'noupdates', u'lastinstall': u'2021-09-15T12:48:08'}, u'lastchange': u'2021-09-15T12:49:00', u'checkforupdate': False, u'state': u'noupdates', u'autoinstall': {u'on': True, u'updatetime': u'T14:00:00'}}, u'dhcp': True, u'localtime': u'2021-09-18T15:59:29', u'proxyport': 0, u'UTC': u'2021-09-18T13:59:29', u'factorynew': False, u'swupdate': {u'devicetypes': {u'bridge': False, u'sensors': [], u'lights': []}, u'url': u'', u'text': u'', u'checkforupdate': False, u'updatestate': 0, u'notify': True}, u'apiversion': u'1.46.0', u'mac': u'00:17:88:40:4e:5f', u'linkbutton': False, u'bridgeid': u'001788FFFE404E5F', u'ipaddress': u'192.168.100.105', u'portalservices': False, u'name': u'Philips hue', u'swversion': u'1947054040', u'netmask': u'255.255.255.0', u'internetservices': {u'swupdate': u'connected', u'time': u'connected', u'remoteaccess': u'disconnected', u'internet': u'connected'}, u'backup': {u'status': u'idle', u'errorcode': 0}}}
   Hue Lights                      Loaded 8 lights.
   Hue Lights                      Loaded 6 groups.
   Hue Lights                      Loaded 24 scenes.
   Hue Lights                      Loaded 3 sensors.
   Hue Lights Debug                Starting device: Alle Hue Lampen
   Hue Lights Debug                Starting rebuildDevice.
   Hue Lights Debug                Checking if the Alle Hue Lampen device needs to be rebuilt.
   Hue Lights Debug                Device details before rebuild check:
address : 192.168.100.105 (GID 0)
batteryLevel : None
blueLevel : 0.0
brightness : 0
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueGroup
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
     com.nathansheldon.indigoplugin.HueLights : (dict)
          SupportsColor : true (bool)
          SupportsRGB : true (bool)
          SupportsRGBandWhiteSimultaneously : false (bool)
          SupportsWhite : true (bool)
          SupportsWhiteTemperature : true (bool)
          WhiteTemperatureMax : 6500 (string)
          WhiteTemperatureMin : 2000 (string)
          address : 192.168.100.105 (GID 0) (string)
          defaultBrightness :  (string)
          groupClass :  (string)
          groupId : 0 (string)
          groupLights : (list)
          groupLightsDisabler : false (bool)
          nameOnHub :  (string)
          rate :  (string)
          savedBrightness :  (string)
          type :  (string)
greenLevel : 0.0
lastChanged : 2000-01-01 00:00:00
lastSuccessfulComm : 2000-01-01 00:00:00
ledStates : []
model : Hue Group
name : Alle Hue Lampen
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : False
ownerProps : com.nathansheldon.indigoplugin.HueLights : (dict)
     rate :  (string)
     type :  (string)
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.nathansheldon.indigoplugin.HueLights : (dict)
     rate :  (string)
     type :  (string)
protocol : Plugin
redLevel : 0.0
remoteDisplay : True
states : States : (dict)
     alertMode :  (string)
     allOn : false (bool)
     anyOn : false (bool)
     blueLevel : 0 (integer)
     colorMode :  (string)
     colorTemp : 0 (integer)
     colorX : 0 (integer)
     colorY : 0 (integer)
     effect :  (string)
     greenLevel : 0 (integer)
     groupMemberIDs :  (string)
     hue : 0 (integer)
     redLevel : 0 (integer)
     saturation : 0 (integer)
     whiteLevel : 0 (integer)
     whiteTemperature : 0 (integer)
subModel :
subType :
supportsAllOff : False
supportsColor : True
supportsRGB : True
supportsStatusRequest : True
supportsWhite : True
supportsWhiteTemperature : True
version : None
whiteLevel : 0.0
whiteLevel2 : None
   Hue Lights Debug                Verifying the Alle Hue Lampen group device.
   Hue Lights Debug                Telling server to reload state list and display state.
   Hue Lights Debug                Starting getDeviceStateList for the "Alle Hue Lampen" device.
   Hue Lights Debug                rebuildDevice complete.
   Hue Lights Debug                Hue Group device definition:
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
folderId : 0
     com.indigodomo.indigoserver : (dict)
          rate :  (string)
          type :  (string)
greenLevel : 0.0
ledStates : []
model : Hue Group
onState : False
     rate :  (string)
     type :  (string)
     rate :  (string)
     type :  (string)
protocol : Plugin
redLevel : 0.0
     effect :  (string)
     hue : 0 (integer)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 0.0
whiteLevel2 : None
   Hue Lights Debug                Starting device: Bettlampe
   Hue Lights Debug                Checking if the Bettlampe device needs to be rebuilt.
address : 192.168.100.105 (ID 4)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
deviceTypeId : hueBulb
enabled : True
errorState :
folderId : 1036166448
          publish-device : true (bool)
          sub-type : Color Dimmer (string)
          address : 192.168.100.105 (ID 4) (string)
          bulbId : 4 (string)
          defaultBrightness : 100 (string)
          manufacturerName : innr (string)
          modelId : RB 185 C (string)
          nameOnBridge : Bettlampe (string)
          nameOnHub : Bettlampe (string)
          nameOnbridge : Bettlampe (string)
          rate : 5 (string)
          savedBrightness : 1 (integer)
          swVersion : 2.0 (string)
          type : Extended color light (string)
          uniqueId : 00:15:8d:00:02:0a:f5:3c-01 (string)
greenLevel : 0.0
lastChanged : 2021-09-16 20:02:21
lastSuccessfulComm : 2021-09-16 20:02:21
ledStates : []
model : Hue Color/Ambiance (Original, Downlight, Spotlight, etc.)
onState : False
     bulbId : 4 (string)
     rate : 5 (string)
     bulbId : 4 (string)
     rate : 5 (string)
protocol : Plugin
redLevel : 0.0
     blueLevel : 0.00000000 (real)
     colorMode : ct (string)
     colorMode.ui : ct (string)
     colorTemp : 2703 (integer)
     colorTemp.ui : 2703 (string)
     colorX : 0.4578 (real)
     colorX.ui : 0.4578 (string)
     colorY : 0.4101 (real)
     colorY.ui : 0.4101 (string)
     greenLevel : 0.00000000 (real)
     hue : 0 (integer)
     hue.ui : 0 (string)
     redLevel : 0.00000000 (real)
     saturation : 80 (integer)
     saturation.ui : 80 (string)
     whiteLevel : 20.00000000 (real)
     whiteLevel.ui : 20 (string)
     whiteTemperature : 2703.00000000 (real)
     whiteTemperature.ui : 2703 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 20.0
whiteLevel2 : None
   Hue Lights Debug                Verifying the Bettlampe lighting device properties.
   Hue Lights Debug                Starting getDeviceStateList for the "Bettlampe" device.
   Hue Lights Debug                Hue device definition:
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
          bulbId : 4 (string)
          rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
     bulbId : 4 (string)
     rate : 5 (string)
     bulbId : 4 (string)
     rate : 5 (string)
protocol : Plugin
redLevel : 0.0
     alertMode : lselect (string)
     alertMode.ui : lselect (string)
     blueLevel.ui : 0 (string)
     brightnessLevel : 0 (integer)
     brightnessLevel.ui : 0 (string)
     colorBlue : 0 (integer)
     colorBlue.ui : 0 (string)
     colorGreen : 0 (integer)
     colorGreen.ui : 0 (string)
     colorRed : 0 (integer)
     colorRed.ui : 0 (string)
     effect : none (string)
     effect.ui : none (string)
     greenLevel.ui : 0 (string)
     hue : 0 (integer)
     hue.ui : 0 (string)
     online : true (bool)
     online.ui : True (string)
     redLevel.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 20.0
whiteLevel2 : None
   Hue Lights Debug                Starting device: Bettlampe links
   Hue Lights Debug                Checking if the Bettlampe links device needs to be rebuilt.
address : 192.168.100.105 (ID 7)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
          address : 192.168.100.105 (ID 7) (string)
          bulbId : 7 (string)
          defaultBrightness : 75 (string)
          manufacturerName : OSRAM (string)
          modelId : PAR 16 50 RGBW - LIGHTIFY (string)
          nameOnBridge : Bettlampe links (string)
          nameOnHub : Bettlampe links (string)
          rate : 5 (string)
          swVersion : V1.04.12 (string)
          uniqueId : 7c:b0:3e:aa:00:ab:5a:0b-03 (string)
greenLevel : 0.0
lastChanged : 2021-09-16 13:24:48
lastSuccessfulComm : 2021-09-16 13:24:48
ledStates : []
onState : False
     bulbId : 7 (string)
     rate : 5 (string)
     bulbId : 7 (string)
     rate : 5 (string)
protocol : Plugin
redLevel : 0.0
     alertMode : select (string)
     alertMode.ui : select (string)
     colorX : 0.3805 (real)
     colorX.ui : 0.3805 (string)
     colorY : 0.3769 (real)
     colorY.ui : 0.3769 (string)
     hue : 0 (integer)
     hue.ui : 0 (string)
     saturation.ui : 0 (string)
     whiteLevel : 100.00000000 (real)
     whiteLevel.ui : 100 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
   Hue Lights Debug                Verifying the Bettlampe links lighting device properties.
   Hue Lights Debug                Starting getDeviceStateList for the "Bettlampe links" device.
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
          bulbId : 7 (string)
          rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
     bulbId : 7 (string)
     rate : 5 (string)
     bulbId : 7 (string)
     rate : 5 (string)
protocol : Plugin
redLevel : 0.0
     hue : 0 (integer)
     hue.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
   Hue Lights Debug                Starting device: Bettlampe rechts
   Hue Lights Debug                Checking if the Bettlampe rechts device needs to be rebuilt.
address : 192.168.100.105 (ID 6)
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
          address : 192.168.100.105 (ID 6) (string)
          bulbId : 6 (string)
          nameOnBridge : Bettlampe rechts (string)
          nameOnHub : Bettlampe rechts (string)
          rate : 5 (string)
          uniqueId : 7c:b0:3e:aa:00:ab:64:b3-03 (string)
greenLevel : 0.0
lastChanged : 2021-09-17 22:23:46
lastSuccessfulComm : 2021-09-17 22:23:46
ledStates : []
onState : False
     bulbId : 6 (string)
     rate : 5 (string)
     bulbId : 6 (string)
     rate : 5 (string)
protocol : Plugin
redLevel : 0.0
     hue : 0 (integer)
     hue.ui : 0 (string)
subModel :
subType :
supportsRGB : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
   Hue Lights Debug                Verifying the Bettlampe rechts lighting device properties.
   Hue Lights Debug                Starting getDeviceStateList for the "Bettlampe rechts" device.
batteryLevel : None
blueLevel : 0.0
brightness : 0
configured : True
description :
enabled : True
errorState :
          bulbId : 6 (string)
          rate : 5 (string)
greenLevel : 0.0
ledStates : []
onState : False
     bulbId : 6 (string)
     rate : 5 (string)
Sun Sep 19, 2021 3:40 am
nsheldon offline
Re: Hue Lights discussion
Hi Yassi.
Sure! Thanks for all the details. I'll add support in the next plugin version.
Sun Sep 19, 2021 3:45 am
yassi offline
nsheldon wrote:
Hi Yassi.
Great! Thanks a lot, Nathan!
Gesendet von iPhone mit Tapatalk
Fri Sep 24, 2021 3:30 pm
jroach offline
I noticed that my Hue lights were not working through Indigo.
The IP address of the Hue hub is 192.168.1.3 while Indigo it says that it is 192.168.1.2. Restarted Indigo (same), unplugged the hub (same),.
I then looked at the plugin and it was correct (192.168.1.3) but the address in the list of devices is still 192.168.1.2.
I removed the Preferences file for the hue plugin (disabling the plugin first), enabled, then configured. I enter the IP, press the button and hit "Pair".
It says "pairing" but that never goes to anything else.
Is it stuck?
Fri Sep 24, 2021 4:57 pm
jroach offline
Correction, Hue lights work from Indigo but the IP address is still different and triggers/schedules seem to be flakey.
Sat Sep 25, 2021 2:52 pm
nsheldon offline
Hi. For the device addresses in Indigo, if the IP address of the Hue hub changes after the device in Indigo was created, the Indigo device will not reflect the new IP address of the Hue hub unless you edit the device in Indigo. The device address, at least with the Hue Lights plugin, is not actually critical to the device working in Indigo. It's just a reference value primarily for sorting and searching purposes. As you've noticed, the device continues to work even if the device address shown is incorrect.
As for flaky triggers and schedules, that's not really enough information to determine what the source of the problem is. You'll probably need to do some more trial and error testing to narrow down under what conditions the triggers and schedules fail and under which conditions they succeed in order to determine the source of the problem. For example, do triggers based on a specific device fail? Or a specific group of devices? Do they fail during specific times of day, when some other device is on (or off)? Is it the trigger that fails to be activated or the action taken by the trigger that fails to complete? (I'm assuming the latter).
Sat Sep 25, 2021 3:05 pm
nsheldon offline
Version 1.7.58 Posted
  • Added support for the Lightway/Megos E27 806 lumen bulb.
Sun Sep 26, 2021 9:56 am
yassi offline
Thanks, Nathan!
Looking good!
Yassi
Tue Oct 12, 2021 5:03 pm
andarv offline
I really appreciate your pluggin.
When I was adding a few new lights I wasn't able to find them as new devices, the plugin identifies correct number of lights but they don't show up as HUE devices under device settings.
I tried to reload, re pair etc but it doesn't make any difference.
It's two lamps that doesn't show up.
Hue ambient ceiling (have a working one with model nr LTC003)
Model 3261330P6
Hue Color pendant
Model 4090331P9_01 (and 02)
Thu Oct 14, 2021 12:23 am
nsheldon offline
Thanks for the report. I can add support for those in the next update. However, could you please provide a screenshot from the Hue app showing those models just so I can be sure I get the exact model ID and light type down? Thanks.
Model 3261330P6
Hue Color pendant
Fri Oct 15, 2021 12:33 am
andarv offline
Here are the two lamps.
The pendant consits of two separate lamps one for Up/down
Fri Oct 15, 2021 1:02 am
nsheldon offline
Great! Thanks! I'll add support in the next release.
Sat Oct 16, 2021 2:27 pm
andarv offline
Great, thanks for the support!
Skickat från min IN2023 via Tapatalk
Sat Oct 16, 2021 3:40 pm
vtmikel offline
Hi there-
Thanks for the great plugin.
I was hoping to make a request. I run scenes for my Hue lights which animate them slowly. The plugin floods the indigo log with updates. I was wondering if there was a way to quiet some of the updates to the log?
Thanks again.
Mike
Page 91 of 103 1 ... 88, 89, 90, 91, 92, 93, 94 ... 103
