Page 68 of 103
Re: Hue Lights discussion
Posted:
Fri Mar 15, 2019 1:12 pm
by Busta999
Yup
I should have been clearer.
I have good quality strips but the range of zigbee controllers I have tried are not as solid as the hue contollers
Posted:
Fri Mar 15, 2019 11:15 pm
by nsheldon
Hello again. Glad I could help.
I'm actually not the best person to ask about which specific lights to get as I've only had experience using the original Philips branded Hue Light Strip. I've not seen or used any non-Philips products yet with the Hue bridge.
Assuming the Hue bridge sends the correct ZigBee commands with the WW/CW and RGB-CCT controllers (and the controller understands them), you should be able to set the color temperature on any controller that supports the color temperature method specifying color.
joesan wrote:Thanks Nathan. You're a gent.
May I ask you, what's the best option to choose here to control a WW/CW strip?
I can switch on and alter the colour temperature of my white only strips using the Gledopto RGB-CCT controller but it's a bit hit and miss. If I bought the GLEDOPTO CW/WW controller what model of light would I choose and would your Hue plugin only show controls for white (as opposed to RGB)?
Posted:
Mon Mar 18, 2019 8:16 am
by Busta999
Nathan..
Ok another Enhancement Request.
The first was an option to make the Hue Plugin less noisy in the Indigo Log.
The new one is the option to log Hue events to a CSV - ideally the way that AutoLog has with his TRV plugin.
This means that the logs can be read by Dave17's MatPlotLib Plugin, but the Hue Plugin writes to the CSV when activity offers and now a sample every minute/5 mins /15mins, which are pretty useless at recording activity such as Motion sensors. i.e. the CSV engine has to be performing its periodic status update exactly the same time as an event is occurring or miss it all together.
Neither important or urgent in any shape or form.
Posted:
Mon Mar 18, 2019 10:34 am
by nsheldon
Hi again.
Thanks for the suggestion. The reduced logging frequency is still a possibility. That could be useful for a lot of users and wouldn’t require a huge amount of coding (though it would require quite a few hours of work). Adding native CSV output, while not completely off the table, is less likely (at least from me) as it would require a lot of coding and would be only useful to a small number of people. Anyone is welcome to create a new GutHub branch of the plugin code and make any changes they like though. But again, I appreciate the suggestions.
Posted:
Mon Mar 18, 2019 1:04 pm
by Busta999
Understood - just my 5c worth
Posted:
Mon Mar 18, 2019 2:09 pm
by joesan
Hi Nathan,
Re this point. It makes sense that if you haven't use the Hue lights that you may not be the most familiar with the alternatives. I think the basis of the issue is that Hue strips are all RGB so the plugin shows RGB controls. In my case (and this may be an edge case where not many people are doing the same thing) I'm trying to control only CW/WW but the Hues strip plugin attempts to allow RGB control. I think it is this aspect that may be resulting in less reliable results. So, when I attempt to switch the strip on, it will not come on until I adjust the temperature and I cannot switch it off by clicking the OFF button.
It's very curious but it's not something I'm sure can be fixed.
Posted:
Mon Mar 18, 2019 4:10 pm
by Busta999
My view is that this a Hue Plugin.
It works great for my Hue lights and motion sensor.
The fact it controls non Hue Zigbeeis a great bonus.
The zigbee devices I control through the Hue Plugin largely work,often well with some painful exceptions.
The zigbee light strips often turn on at only 25% or not at all reporting they are on and 100%.
I use Indigo to always send an additional on/100% whenever an On is sent, to ensure it lights up.
My take away is that the Hue Plugin is for controlling Hue lights, which it does exceptionally well.
If it does anything else a bonus, can’t ask for more, even if it doesn’t work well.
Maybe we could get someone to write a zigbee Controller plug-in?
Posted:
Sun Mar 24, 2019 3:29 pm
by nsheldon
Version 1.7.0 Posted- Added support for the Hue Tap and Hue Dimmer Switches.
- Changed all references to the "Hue hub" to "Hue bridge".
Posted:
Tue Mar 26, 2019 4:29 am
by nsheldon
Version 1.7.1 Posted- Added support for the Run Less Wire switch.
- Fixed a bug that would prevent Hue Tap switches from appearing in the device selection list.
Posted:
Wed Mar 27, 2019 3:50 am
by nsheldon
Version 1.7.2 Posted- Fixed a bug with Run Less Wire switch support that would not allow you to select a Run Less Wire switch device in the device selection dialog.
- Fixed a bug with Run Less Wire switch support that returned numerous errors when the plugin attempted to update the online state of the switch which has no online state.
- Fixed a bug with Run Less Wire switch support that would not update switch states during initial plugin load.
Posted:
Sun Mar 31, 2019 1:35 pm
by nsheldon
Version 1.7.3 Posted- Added support for the Hue Signe Floor light.
- Added button hold states for the Run Less Wire switch device. Note that this feature is still experimental.
- Fixed issue where Run Less Wire switch button ON states may not be saved.
Posted:
Mon Apr 15, 2019 7:38 am
by Turribeach
Hi guys, I have read the last few pages of this thread and it seems third party devices can work with the Philips Hue Bridge and the Hue Lights plugin. I have been looking around for years for a Z-Wave rotary dimmer and I still can't find one. But I found this ZigBee Rotary Dimmer today:
https://auroralighting.com/gb/productdetail/au-a1zb2wdmThis sounds like a long shot but will it work with the Philips Hue Bridge and the Hue Lights plugin? I presume that in order for a device to work with this plugin it needs to be added to the plugin and it should also work with the Philips Hue Bridge right?
Posted:
Mon Apr 15, 2019 10:54 am
by nsheldon
Hi..
While most 3rd party lights either are already or can easily be supported by the Hue Lights plugin because supporting them doesn’t require new code. With the exception of the Run Less Wire switch, no 3rd party non-light devices (including switches) are supported. However, that doesn’t meant those ZigBee devices won’t work with the Hue bridge. The bridge appears to support many ZigBee standard devices.
Posted:
Mon Apr 29, 2019 10:29 am
by c64
Hi Nathan,
We all very much appreciate your work here! Our houses all have beautiful lighting as result - thank you!
May I put in a vote for Innr RS228 lamp support? I've taken the liberty of adding the debug code as others have.
The bulb is called "Tresen1" - it's a Innr RS 228 GU10 lamp.
- Code: Select all
29/04/2019, 5:25:58 PM
Hue Lights Turning on debug logging
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.47/api/rLyZsLoM5RWlJu01Zv5gWOSQ92Fhk4Ry-Q4ya9yy/lights
Hue Lights Debug Got response {u'11': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-23T15:10:32'}, u'uniqueid': u'00:15:8d:00:03:56:ab:ae-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'13': {u'swversion': u'2.0', u'name': u'Tresen1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:20:02'}, u'uniqueid': u'00:15:8d:00:03:61:87:46-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Fins bathroom striplight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-09T13:27:20'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:0c:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 344, u'sat': 119}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'14': {u'swversion': u'2.0', u'name': u'Tresen2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:24:38'}, u'uniqueid': u'00:15:8d:00:03:61:9e:f4-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Entrance Diele Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:26'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:03:e1:49:1d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 254}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Sideboard', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:05'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:9e:97:d1-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 215, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'2': {u'swversion': u'1.46.13_r26312', u'name': u'Upstairs Bookshelf', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:00'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:04:e3:8a:d0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 144, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Black Lady Head', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:48:55'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:04:22:91:75-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Studio Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:10'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4d:53:cc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard L', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:15'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:79:6a:4d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard R', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:20'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:80:ee-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'9': {u'swversion': u'1.0.6', u'name': u'Lounge Strip Lighting', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-14T18:21:52'}, u'uniqueid': u'00:12:4b:00:1b:92:0e:f8-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'reachable': False, u'mode': u'homeautomation', u'bri': 57, u'ct': 482, u'sat': 20}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'GL-C-008'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Unit Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T15:31:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:94:37-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Loaded lights list - {u'11': {u'swversion': u'2.0', u'name': u'On/Off plug 1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-23T15:10:32'}, u'uniqueid': u'00:15:8d:00:03:56:ab:ae-01', u'capabilities': {u'control': {}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'On/Off plug', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'alert': u'select'}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'On/Off plug-in unit', u'modelid': u'SP 120'}, u'13': {u'swversion': u'2.0', u'name': u'Tresen1', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:20:02'}, u'uniqueid': u'00:15:8d:00:03:61:87:46-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Fins bathroom striplight', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-03-09T13:27:20'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:0c:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 344, u'sat': 119}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'14': {u'swversion': u'2.0', u'name': u'Tresen2', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-04-29T14:24:38'}, u'uniqueid': u'00:15:8d:00:03:61:9e:f4-01', u'capabilities': {u'control': {u'ct': {u'max': 454, u'min': 200}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Color temperature light', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 447}, u'manufacturername': u'innr', u'config': {u'function': u'functional', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Color temperature light', u'modelid': u'RS 228 T'}, u'1': {u'swversion': u'1.46.13_r26312', u'name': u'Entrance Diele Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:26'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:03:e1:49:1d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 254}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'3': {u'swversion': u'1.46.13_r26312', u'name': u'Sideboard', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:05'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:9e:97:d1-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 215, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'2': {u'swversion': u'1.46.13_r26312', u'name': u'Upstairs Bookshelf', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:00'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:04:e3:8a:d0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 144, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Black Lady Head', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:48:55'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:04:22:91:75-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Studio Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:10'}, u'productid': u'Philips-LWB010-1-A19DLv4', u'uniqueid': u'00:17:88:01:03:4d:53:cc-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 806}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 183, u'alert': u'lselect'}, u'manufacturername': u'Philips', u'swconfigid': u'322BB2EC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB010'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard L', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:15'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:79:6a:4d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Lounge Sideboard R', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-05T13:49:20'}, u'productid': u'Philips-LTW010-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:80:ee-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 806, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'lselect', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'7A2E82CC', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'customsettings': {u'bri': 254, u'ct': 447}, u'mode': u'custom'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW010'}, u'9': {u'swversion': u'1.0.6', u'name': u'Lounge Strip Lighting', u'swupdate': {u'state': u'notupdatable', u'lastinstall': u'2019-02-14T18:21:52'}, u'uniqueid': u'00:12:4b:00:1b:92:0e:f8-0b', u'capabilities': {u'control': {u'ct': {u'max': 65535, u'min': 0}, u'colorgamuttype': u'other'}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': False}, u'productname': u'Extended color light', u'state': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'reachable': False, u'mode': u'homeautomation', u'bri': 57, u'ct': 482, u'sat': 20}, u'manufacturername': u'GLEDOPTO', u'config': {u'function': u'mixed', u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Extended color light', u'modelid': u'GL-C-008'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Unit Lightstrip', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-14T15:31:13'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:49:94:37-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7676, u'colormode': u'xy', u'effect': u'none', u'alert': u'none', u'xy': [0.5016, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 144, u'ct': 443, u'sat': 199}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 13 lights on the Hue bridge and 11 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.47/api/rLyZsLoM5RWlJu01Zv5gWOSQ92Fhk4Ry-Q4ya9yy/groups
Hue Lights Debug Got response {u'10': {u'name': u'Upstairs Hallway', u'lights': [u'2', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'bri': 1, u'ct': 344, u'sat': 119}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'1': {u'name': u'Couch Group', u'lights': [u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Studio', u'lights': [u'6', u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'lselect', u'colormode': u'ct', u'bri': 1, u'ct': 454}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Lounge Group', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'bri': 57, u'ct': 482, u'sat': 20}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Entrance', u'lights': [u'3', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'bri': 1, u'ct': 153, u'sat': 254}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Kitchen', u'lights': [u'8', u'13', u'14'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7676, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5016, 0.4151], u'bri': 254, u'ct': 447, u'sat': 199}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Loaded groups list - {u'10': {u'name': u'Upstairs Hallway', u'lights': [u'2', u'12'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 8615, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4439, 0.4065], u'bri': 1, u'ct': 344, u'sat': 119}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'1': {u'name': u'Couch Group', u'lights': [u'11'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Studio', u'lights': [u'6', u'7'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'lselect', u'colormode': u'ct', u'bri': 1, u'ct': 454}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'2': {u'name': u'Lounge Group', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7424, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.526, 0.4591], u'bri': 57, u'ct': 482, u'sat': 20}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Entrance', u'lights': [u'3', u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 0, u'colormode': u'hs', u'effect': u'none', u'alert': u'lselect', u'xy': [0.6915, 0.3083], u'bri': 1, u'ct': 153, u'sat': 254}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'Kitchen', u'lights': [u'8', u'13', u'14'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7676, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5016, 0.4151], u'bri': 254, u'ct': 447, u'sat': 199}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting parseOneHueGroupData.
Posted:
Mon Apr 29, 2019 11:59 am
by nsheldon
Hi there.
Thanks! I'm glad the plugin has been helpful.
I'll add support for the Innr RS-228T in the next patch release which should be out soon.
