Hue Lights discussion
Sun Jul 28, 2019 6:52 pm
nsheldon offline
Re: Failed to load
bbruck wrote:
I'm getting the following message every minute or so:
Hue Lights Error Failed to load sensors list from the Hue bridge at 192.168.1.43 after 4 seconds - check settings and retry.
When I reload the plugin, or reload the config, I see:
Jul 26, 2019 at 7:34:31 AM
Hue Lights Loaded 18 lights.
Hue Lights Loaded 10 groups.
Hue Lights Loaded 83 scenes.
Hue Lights Loaded 1 sensor.
But then after a few minutes I get the error again. To my knowledge, I have no Hue sensors. I simply have a number of lights.
Any ideas?
I've never seen the plugin not be able to load sensors but be able to load everything else. Do you have the version 1 round or the version 2 square Hue bridge? The old round one may not be able to handle how often the Hue Lights plugin asks it for a sensor status update. Have you installed the latest firmware version? The latest version was released July 22, 2019.
As for the 1 sensor, that's normal. All Hue bridges come with at least 1 built-in sensor to indicate whether it's day or night (based on time of day). You can't delete it. It's essentially like the Indigo built-in variable "isDaylight" which is read-only as well.
Mon Jul 29, 2019 8:31 am
bbruck offline
Re: Hue Lights discussion
Thanks for responding to both my requests. I do have the newer hub and the latest firmware. Don't worry about it though - it doesn't seem to affect anything.
Mon Jul 29, 2019 3:59 pm
nsheldon offline
Sorry I couldn't help more.
Some other things to consider as possible contributing factors to the intermittent sensor read failure:
  1. If you have virtual assistants (or any other home automation software) that interface with the Hue (like Alexa or Google, SmartThings, etc.), they may be making somewhat frequent update requests to the Hue bridge just like the Hue Lights plugin does and the bridge may be occasionally refusing to reply as a way to prevent denial-of-service attacks against itself. This is a built-in feature of the Hue bridge. If you only have 1 or maybe 2 things talking to the bridge frequently, it isn't an issue, but if you have a few things making frequent requests, the bridge may "throttle" back its responses. The Hue Lights plugin requests sensor updates every 1 second, which is pretty frequent, but important for fast motion sensing and switch button press sensing. Other apps or virtual assistants may be doing the same thing.
  2. If you're noticing other intermittent network or Indigo server issues, that may be related too, though I think this is rather unlikely since the problems are only happening with sensor update requests.
Tue Sep 17, 2019 12:21 am
nsheldon offline
Version 1.7.7 Posted
    * Added support for the Hue Outdoor Lucca light.
    * Added support for the Hue Smart Plug as a new On/Off device type.
Wed Sep 18, 2019 12:37 am
nsheldon offline
Version 1.7.8 Posted
  • Fixed a bug that would cause the Hue Smart Plug device states to never update.
Wed Sep 18, 2019 4:19 am
nsheldon offline
Version 1.7.9 Posted
  • Fixed a bug with Hue Group devices that prevented the Set Brightness with Ramp Rate action from working correctly.
Wed Sep 18, 2019 9:49 am
kkreitzer offline
Hi there!
I am having trouble adding a new bulb in Indigo. When I look at the debug logs, the plugin sees the bulb and is loading the details about it, but when I attempt to add it as a new device, it doesn't appear in the drop down to choose from. I did notice that the two bulbs I tried doing this with are new and their software version is newer than my other bulbs. All of my older bulbs are 1.46.13_r26312, but these two new ones have 1.53.3_r27175 installed. I am running the latest version of the Hue Lights plug in as well.
Any help is greatly appreciated!
Wed Sep 18, 2019 11:08 am
nsheldon offline
Could you paste in the debug log showing the details of the Hue bridge response? I need the bulb details as reported by the bridge.
Sat Sep 21, 2019 7:21 pm
kkreitzer offline
Hi! Sorry for the delay. Here is the debug log:
Sep 21, 2019, 9:19:25 PM
Hue Lights Debug logging enabled
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.10/api/rwV6yzO-mgR0E64 ... cH4/lights
Hue Lights Debug Got response {u'25': {u'swversion': u'1.53.3_r27175', u'name': u'Desk Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-18T15:35:17'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:94:b5:c7-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'26': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:31:49'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:94:a3:38-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'27': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:31:55'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:38:61:fa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'15': {u'swversion': u'1.46.13_r26312', u'name': u'TriPod Lamp 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:09:48'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:71:d9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'14': {u'swversion': u'1.46.13_r26312', u'name': u'TriPod Lamp 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-07T20:19:55'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:da:72:7e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'17': {u'swversion': u'1.46.13_r26312', u'name': u'Entry Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T03:46:12'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:dd:8b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'16': {u'swversion': u'5.127.1.26420', u'name': u'TV Lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-07T20:19:59'}, u'uniqueid': u'00:17:88:01:02:ad:b9:91-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 25, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'19': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:54'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:c9:10:f5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:50'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:03:70:09:cb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'22': {u'swversion': u'1.46.13_r26312', u'name': u'Side Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-11T18:36:23'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:de:3a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'28': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:32:00'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:38:03:70-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Kayne Bedside', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T19:25:33'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:e8:82:02-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Charlie Bedside', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T19:25:28'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:e8:77:a2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'20': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:57'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:dc:82:5b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'21': {u'swversion': u'5.127.1.26420', u'name': u'Kitchen Counter Lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-11T02:09:18'}, u'uniqueid': u'00:17:88:01:02:ad:6e:75-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 25, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Loaded lights list - {u'25': {u'swversion': u'1.53.3_r27175', u'name': u'Desk Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-18T15:35:17'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:94:b5:c7-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.4578, 0.41], u'reachable': False, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'26': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:31:49'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:94:a3:38-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'27': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:31:55'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:38:61:fa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'15': {u'swversion': u'1.46.13_r26312', u'name': u'TriPod Lamp 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:09:48'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:71:d9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'14': {u'swversion': u'1.46.13_r26312', u'name': u'TriPod Lamp 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-07T20:19:55'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:da:72:7e-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'17': {u'swversion': u'1.46.13_r26312', u'name': u'Entry Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T03:46:12'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:dd:8b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'16': {u'swversion': u'5.127.1.26420', u'name': u'TV Lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-07T20:19:59'}, u'uniqueid': u'00:17:88:01:02:ad:b9:91-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 25, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'19': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:54'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:c9:10:f5-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'18': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:50'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:03:70:09:cb-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'22': {u'swversion': u'1.46.13_r26312', u'name': u'Side Lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-11T18:36:23'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:d8:de:3a-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'28': {u'swversion': u'1.53.3_r27175', u'name': u'Dining Room 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-21T19:32:00'}, u'productid': u'Philips-LCA002-4-A19ECLv6', u'uniqueid': u'00:17:88:01:06:38:03:70-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 200, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'D59D13D9', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCA002'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Kayne Bedside', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T19:25:33'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:e8:82:02-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'6': {u'swversion': u'1.46.13_r26312', u'name': u'Charlie Bedside', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-07T19:25:28'}, u'productid': u'Philips-LCT014-2-A19ECLv4', u'uniqueid': u'00:17:88:01:02:e8:77:a2-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'2004C665', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'20': {u'swversion': u'1.46.13_r26312', u'name': u'Bathroom 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-08T00:59:57'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:dc:82:5b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'21': {u'swversion': u'5.127.1.26420', u'name': u'Kitchen Counter Lights', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-08-11T02:09:18'}, u'uniqueid': u'00:17:88:01:02:ad:6e:75-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 25, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'ct': 367, u'sat': 140}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 15 lights on the Hue bridge and 13 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.10/api/rwV6yzO-mgR0E64 ... cH4/groups
Hue Lights Debug Got response {u'1': {u'name': u'Living room', u'lights': [u'22', u'16'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Kitchen', u'lights': [u'26', u'27', u'28', u'21'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'2': {u'name': u'Bedroom', u'lights': [u'6', u'7'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'5': {u'name': u'All', u'lights': [u'22', u'16', u'6', u'7', u'26', u'27', u'28', u'21', u'18', u'19', u'20', u'17', u'25', u'14', u'15'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Downstairs'}, u'4': {u'name': u'Entry', u'lights': [u'17'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Bathroom', u'lights': [u'18', u'19', u'20'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'6': {u'name': u'TV Area', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'22': [0.91, -0.58, 0.0], u'16': [-0.02, 0.93, 0.0]}, u'lights': [u'16', u'22'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'8': {u'name': u'Den', u'lights': [u'25', u'14', u'15'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}}
Hue Lights Debug Loaded groups list - {u'1': {u'name': u'Living room', u'lights': [u'22', u'16'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'none', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'3': {u'name': u'Kitchen', u'lights': [u'26', u'27', u'28', u'21'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'2': {u'name': u'Bedroom', u'lights': [u'6', u'7'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bedroom'}, u'5': {u'name': u'All', u'lights': [u'22', u'16', u'6', u'7', u'26', u'27', u'28', u'21', u'18', u'19', u'20', u'17', u'25', u'14', u'15'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Zone', u'class': u'Downstairs'}, u'4': {u'name': u'Entry', u'lights': [u'17'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}, u'7': {u'name': u'Bathroom', u'lights': [u'18', u'19', u'20'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'6': {u'name': u'TV Area', u'stream': {u'proxymode': u'auto', u'active': False, u'proxynode': u'/bridge', u'owner': None}, u'locations': {u'22': [0.91, -0.58, 0.0], u'16': [-0.02, 0.93, 0.0]}, u'lights': [u'16', u'22'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Entertainment', u'class': u'TV'}, u'8': {u'name': u'Den', u'lights': [u'25', u'14', u'15'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'hue': 8418, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4573, 0.41], u'bri': 77, u'ct': 367, u'sat': 140}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Living room'}}
Sun Sep 22, 2019 4:38 am
nsheldon offline
Version 1.7.10 Posted
  • Fixed a bug with the Hue Smart Plug where current on/off state would not update.
  • Fixed a bug where using the Indigo's built-in Toggle On/Off action failed with dimmable Hue devices.
  • Added support for a new version of Hue color lamp.
@kkreitzer: This should fix the problem of your new lights not showing up in the list of lights to control.
Sun Sep 22, 2019 6:20 am
agame offline
I'm using a few hue bulbs behind z-wave switches, or on lamps with conventional switches (in addition to a number that are permanently powered, and hopefully maintaining the Zigbee network...). It enables me to provide occasional dimming, colour control, or 'party mode' with out loosing the usability of a conventional light switch.
But as soon as 240 volts is switched off to a hue bulb the indigo log fills with hue errors.
What would be the best way to suppress these messages without disabling the plugin?
Sun Sep 22, 2019 12:18 pm
nsheldon offline
Could you post an example of the errors you see? There’s currently no way to control the number of error messages, but maybe I can reduce duplicate message in a future version.
Sun Sep 22, 2019 4:10 pm
agame offline
:oops: I'm delighted (and embarrassed) that I can't replicate this! The plugin behaves perfectly!
I've been running two hubs and two instances of the plugin (now consolidated to one) and I think what I was seeing was actually ra comms problem to one of the hubs (an offline hub does fill the logs...but thats reasonable).
Sun Sep 22, 2019 4:35 pm
kkreitzer offline
Thank you @nsheldon!! I felt lost having to use the Hue app to turn off the new bulbs I got :shock:
Sun Sep 22, 2019 6:37 pm
nsheldon offline
@agame: I'm glad you found the problem and that the plugin is behaving as expected.
@kkreitzer: Great! That's good news that the plugin is working with your new bulbs now.
Page 71 of 103 1 ... 68, 69, 70, 71, 72, 73, 74 ... 103
