Hue Lights discussion
Wed Jan 27, 2021 7:39 pm
gregtee offline
Re: Hue Lights discussion
Thanks Nathan!
Sat Jan 30, 2021 6:04 pm
DU Lou offline
***Feature Request***
Ni Nathan,
I'm not sure if this is possible but I have a need to automate the restart of my Hue Sync device.
~Lou
Sun Jan 31, 2021 12:42 am
nsheldon offline
Hi Lou.
Thanks for the suggestion.
Unlike adding support for a new light or sensor, the Hue Sync uses a completely separate API. So while it may be possible to add support in a future version, it will require significant work. I can’t guarantee I’ll have that time available, but the plug-in source is also available on GitHub , so maybe another developer will donate some time to add support if I don’t get to it.
Sat Feb 06, 2021 8:13 pm
nsheldon offline
Version 1.7.44 Posted
  • Added support for a new Hue color downlight (BR30)
  • Added support for a new GLEDOPTO color/color temperature light.
Sun Feb 07, 2021 1:29 am
gregtee offline
Thanks Nathan for the added support of the new lights.
Question: How do I add them? I installed the plugin but I don't see the new lights listed. Is there anything else I need to do?
thanks
Greg
Sun Feb 07, 2021 1:50 am
gregtee offline
Nevermind, found it!
Thanks again
Sun Feb 14, 2021 2:19 am
MarcoGT offline
I bought a new LIDL Silvercrest On/Off Plug, Model TZ3000; I added to "supportDevices.py" and it works fine.
Maybe you can add it to your next planned release :wink:
Sun Feb 14, 2021 1:52 pm
Wizard Sleeve offline
I also use several of these and can't get them to appear in the list of lights available. Guessing they are not supported. Would love them to be.
Lee
shapa wrote:
Could you please add Outdoor Floodlight?
https://www2.meethue.com/en-gb/p/hue-wh ... /1743530P7
Ready to test ASAP :) Already purchased.
Any information to provide?
Model 1743530P7
Sun Feb 14, 2021 2:11 pm
nsheldon wrote:
Sure.
However, that model is the Philips model number, almost certainly not the actual "model ID" used by the Hue system to distinguish that type of light from another. Once you've paired that light with your Hue bridge, I'd need to know the exact model ID that shows up in the Hue app when viewing detailed light information. It'll probably be something like "LCF004" or something similar. Until I have that, I won't be able to properly add support.
Regards,
Nathan
2021-02-14 20.05.55.png (246.03 KiB) Viewed 2568 times
Mon Feb 15, 2021 3:00 am
nsheldon offline
Thanks for the report. I'll add that to the next plugin update.
Lee
Hi Lee. Thanks for the screenshot. I'll add support for that in the next plugin update.
Mon Feb 22, 2021 11:08 am
bbruck offline
Cannot find sensors
The plugin cannot find my sensors. This may have happened because I was cleaning out my scene creators at the Hue website and accidentally deleted my iPhone app. I have since re-authenticated with it and with Indigo. When I try and recall a scene I see the list of rooms and devices, but there are no scenes. I also have no Hue sensors that I'm aware of, but historically the plugin says two are being loaded. Unfortunately half my lights are Hue, so the WAF is plummeting since the lights are wonky!!!
Here's the log...
Bruck Hue log 2 2021-02-22.txt
(391.9 KiB) Downloaded 93 times
Bruck Hue log 2021-02-22.txt
(398.44 KiB) Downloaded 101 times
Mon Feb 22, 2021 12:29 pm
nsheldon offline
Hi Bruck.
Thanks for the report and the debug logs. I saw the error message in the log related to scene listing issues. I believe I've found the issue and will include a fix in the next Hue Lights plugin update.
Just so I'm sure I understand, the post says "cannot find sensors" but the body of the post says "I also have no Hue sensors..." Did you mean "cannot find scenes"?
As for the plugin listing more sensors than you have, that's expected. The Hue bridge creates a few virtual sensors out of the box that relate to day/night and location. The Hue Lights plugin counts all sensors listed by the Hue bridge (even ones it doesn't support) regardless of whether they're actual physical sensors or virtual ones. So it's normal to see a higher number of sensors detected than you actually have paired with the Hue bridge.
Tue Feb 23, 2021 3:02 am
bbruck offline
Hi Nathan - thanks. I DID mean I don't have any sensors, but the log reports two =- but you explained it - that the hub creates a couple virtual ones.
Wed Mar 03, 2021 3:04 am
nsheldon offline
Version 1.7.45 Posted
  • Added support for another Lidl Silvercrest On/Off Plug version.
  • Added support for another Hue outdoor wall floodlight.
  • Added support for another Hue Ambiance GU10 bulb.
  • Fixed a bug that would cause an error when recalling a Hue scene if the scene creator had been deleted via the Hue web site.
Thu Mar 04, 2021 5:23 am
bbruck offline
Nathan - I downloaded the zip file for 1.7.45 but when I double click on it, the file that opens is the version dated 12/9, which might be 1.7.44.
Page 84 of 103 1 ... 81, 82, 83, 84, 85, 86, 87 ... 103
