- Posted on
Sat Feb 06, 2021 8:13 pm
nsheldon
offline
Version 1.7.44 Posted- Added support for a new Hue color downlight (BR30)
- Added support for a new GLEDOPTO color/color temperature light.
- Posted on
Wed Mar 03, 2021 3:04 am
nsheldon
offline
Version 1.7.45 Posted- Added support for another Lidl Silvercrest On/Off Plug version.
- Added support for another Hue outdoor wall floodlight.
- Added support for another Hue Ambiance GU10 bulb.
- Fixed a bug that would cause an error when recalling a Hue scene if the scene creator had been deleted via the Hue web site.
- Posted on
Sun Mar 07, 2021 7:37 pm
nsheldon
offline
Version 1.7.46 Posted- Fixed a bug that would cause an error when recalling a Hue scene if the scene creator had been deleted via the Hue web site (2nd attempt).
- Fixed saving and recalling Presets to be compatible with Hue Group devices as both source and target for Preset data.
- Posted on
Wed Mar 24, 2021 12:48 am
nsheldon
offline
Version 1.7.47 Posted- Added support for the Hue Single color table light.
- Added support for a new Hue Dimmer Switch.
- Added support for the Osram Smart + LED GU5.3 reflector.
- Added support for 2m and 5m Hue Outdoor Lightstrips.
- Added support for the Hue Amarant Wall Washer light.
- Added support for the Hue white candle dimmable bulb.
- Posted on
Wed Apr 07, 2021 12:19 am
nsheldon
offline
Version 1.7.48 Posted- Added support for another GLEDOPTO color and color temperature light.
- Posted on
Mon Apr 19, 2021 12:25 am
nsheldon
offline
Version 1.7.49 Posted- Added support for a new TRADFRI dimmable bulb.
- Added support for an eWeLight full color/color temperature bulb.
- Added support for the Hue Wall Switch module.
- Added support for a new Hue ambiance downlight.
- Added option to disable ON and OFF ramp rates (transition times) in lighting device configuration dialogs to help improve compatibility with non-Hue lights.
- Fixed a bug that would cause the wrong color to be sent to a Hue Group when using the RGB picker in the Indigo UI.
- Posted on
Tue Apr 20, 2021 12:32 am
nsheldon
offline
Version 1.7.50 Posted- Fixed a bug that would cause a state key error to appear in the Indigo log with Hue Wall Switch Module devices.
- Posted on
Fri Apr 30, 2021 10:06 pm
nsheldon
offline
Version 1.7.51 Posted- Added support for the Hue Argenta color spot bulb.
- Added support for an innr A19 color/color temperature bulb.
- Posted on
Sun May 16, 2021 6:45 pm
nsheldon
offline
Version 1.7.52 Posted- Fixed a bug that would cause an error if a light strip only supported color temperature.
- Posted on
Mon May 24, 2021 12:00 pm
nsheldon
offline
Version 1.7.53 Posted- Added compatibility with another Hue Amarant light.
- Posted on
Sun May 30, 2021 3:07 am
nsheldon
offline
Version 1.7.54 Posted- Fixed another bug that would cause an error if a light strip only supported color temperature.
- Posted on
Mon Jun 14, 2021 12:50 am
nsheldon
offline
Version 1.7.55 Posted- Added support for another Hue Ambiance GU10 bulb model.
- Posted on
Sun Aug 01, 2021 3:23 am
nsheldon
offline
Version 1.7.56 Posted- Added support for another Hue Signe floor light model.
- Added support for an IKEA TRADFRI wall plug.
- Added support for an innr A19 dimmable bulb.
- Posted on
Mon Sep 13, 2021 1:57 am
nsheldon
offline
Version 1.7.57 Posted- Fixed a bug that would cause continuous Indigo error messages if a motion sensor was disabled on the Hue bridge.
- Added support for a new Hue ambiance candle bulb.
- Added support for a Hue Aurelle panel.
- Posted on
Sat Sep 25, 2021 3:04 pm
nsheldon
offline
Version 1.7.58 Posted- Added support for the Lightway/Megos E27 806 lumen bulb.
