- Posted on
Fri Nov 01, 2019 1:52 am
nsheldon
offline
Version 1.7.14 Posted- Added support for the Hue LED filament ST19 Edison bulb and Hue LED filament G25 globe bulb.
- Posted on
Fri Nov 08, 2019 1:37 am
nsheldon
offline
Version 1.7.15 Posted- Added support for a new Hue Ambiance E26 bulb.
- Added support for a new Hue LED filament G93 globe bulb.
- Added support for the UK variant of the Hue Smart Plug.
- Posted on
Tue Nov 12, 2019 4:36 am
nsheldon
offline
Version 1.7.16 Posted- Added support for a new Hue LED spiral filament ST64 bulb.
- Added support for the on/off OSRAM Smart+ Plug.
- Fixed plugin log issue that caused plugin log files to grow very large.
- Fixed the Innr On/Off Plug-in module so it appears in the On/Off Devices. If you already have the module set up with Hue Lights in Indigo, you MUST edit the device in Indigo and redefine it, otherwise it won't work after updating to version 1.7.16.
- Posted on
Fri Nov 15, 2019 1:29 am
nsheldon
offline
Version 1.7.17 Posted- Added support for a new Philips A19 dimmable light.
- Posted on
Wed Nov 20, 2019 1:20 am
nsheldon
offline
Version 1.7.18 Posted- Added support for an IKEA dimmable 1000 lumen E27 color temperature bulb.
- Added support for an IKEA dimmable 600 lumen E14 color temperature bulb.
- Added support for an IKEA dimmable 600 lumen E27 color LED bulb.
- Posted on
Sun Dec 01, 2019 4:57 am
nsheldon
offline
Version 1.7.19 Posted- Added support for the Hue GU10 version 2 bulb.
- Added support for an IKEA dimmable 600 lumen E14 color bulb.
- Posted on
Thu Dec 05, 2019 4:30 am
nsheldon
offline
Version 1.7.20 Posted- Added support for a new Hue color B22 bulb.
- Added support for a new Hue white bulb.
- Posted on
Wed Dec 11, 2019 3:21 am
nsheldon
offline
Version 1.7.21 Posted- Added support for another Hue Smart Plug model variant.
- Added support for a Hue white dimmable BR30 light.
- Added support for an IKEA TRADFRI E12 and GU10 dimmable light.
- Posted on
Tue Dec 24, 2019 4:31 am
nsheldon
offline
Version 1.7.22 Posted- Added support for a new Hue white ambiance bulb (European model).
- Added support for another IKEA color temperature E26 bulb.
- Posted on
Thu Dec 26, 2019 8:19 pm
nsheldon
offline
Version 1.7.23 Posted- Fixed a bug that would cause the plugin to crash when validating device configurations whose Hue device had non-ASCII compatible Unicode characters in the device name on the Hue bridge.
- Posted on
Thu Jan 02, 2020 3:51 am
nsheldon
offline
Version 1.7.24 Posted- Added support for the Hue Smart Button.
- Added a separate "Stop Brightening and Dimming" action to the available device actions.
- Posted on
Fri Feb 07, 2020 12:55 am
nsheldon
offline
Version 1.7.25 Posted- Added support for the Osram PAR-16 SMART+ Spot GU10 Multicolor 350lm light.
- Added support for a Hue color wall light and Hue filament bulb.
- Posted on
Thu Mar 12, 2020 10:59 pm
nsheldon
offline
Version 1.7.26 Posted- Added support for the Müller-Licht (Aldi) ZBT color temperature light.
- Added support for GLEDOPTO color light strip drivers.
- Added support for Niko ZigBee switches.
- Added support for the TRADFRI 10 watt LED driver. Moved the already supported TRADFRI 30 watt LED driver into the Light Strips device model.
- Fixed a bug that would allow you to select a sensor or switch device as the target for a Hue Attribute Controller even though those devices can't be controlled.
- Fixed light device menus in various device configuration windows so Hue light devices are listed in alphabetical order.
- Fixed the group device menu in the Hue Group configuration window so the Hue Groups are listed in numerical group order rather than alphanumeric order.
- Posted on
Sun Mar 15, 2020 3:49 pm
nsheldon
offline
Version 1.7.27 Posted- Fixed a bug that would cause the plugin to crash when updating light strip devices that have no color capabilities.
- Posted on
Wed Apr 15, 2020 1:04 am
nsheldon
offline
Version 1.7.28 Posted- Added support for the Innr Flex Color 4 meter RGBW LED Strip.
- Fixed a bug that prevented control of color channels in some GLEDOPTO LED controllers.
- Fixed a bug that prevented the selection of Hue Groups in the Hue Attribute Controller device configuration window.
