- Posted on
Fri Aug 09, 2013 12:24 pm
nsheldon
offline
Version 1.0.2 Posted- Added: ability to recognize LED LightStrips and Wall Washers.
- Posted on
Fri Aug 09, 2013 2:52 pm
nsheldon
offline
Version 1.0.3 Posted- Fixed: a bug that caused the plugin to crash when using a LightStrip device.
- Posted on
Sun Aug 18, 2013 7:26 pm
nsheldon
offline
Version 1.1.0 Posted- Added support for the following Friends of Hue devices:
- LightStrips
- LivingColors Bloom
- Added experimental support for LivingWhites devices.
- Fixed a bug that wouldn't turn off the Hue bulb as quickly if using the standard device Turn Off command as opposed to setting the brightness to 0 method.
- Fixed a bug that would not properly update the "online" device state with newer Hue hub firmware versions that properly show the online condition of a Hue device.
- Updated the Set Red/Green/Blue function to better match Hue device capabilities.
- Added a Set xyY Chromaticity (Advanced) action that allows one to directly specify the x/y chromaticity and Y luminosity values for devices that can render color.
- Posted on
Tue Aug 20, 2013 3:32 pm
nsheldon
offline
Version 1.1.1 Posted- Added code to update device error states if a Hue device's online state changes to false, or there's some other kind of error.
- Fixed some UI labeling errors.
- Posted on
Tue Aug 27, 2013 5:34 pm
nsheldon
offline
Version 1.2.0 Posted- Added Hue device settings Presets option that can save a device's current settings to be recalled (applied) later to any other compatible Hue device.
- Fixed a bug that would cause Hue devices to not turn off if the requested brightness level was 0 when using the Set RGB, Set HSB, Set Color Temperature, or Set xyY actions.
- Posted on
Mon Sep 02, 2013 12:30 am
nsheldon
offline
Version 1.2.1 Posted- Fixed a bug that could cause the plugin to crash when using the Set Hue/Saturation/Brightness action from an external or embedded script then from an Indigo action.
- Added elipses to Plugins menu Preset items to conform to standard menu item naming convension when a dialog results from selecting
a menu item.
- Posted on
Wed Sep 04, 2013 3:25 pm
nsheldon
offline
Version 1.2.3 Posted- Fixed a bug that caused a "typeId 'setBrightness'" error when attempting to create a Set Brightness with Ramp Rate action.
- Posted on
Tue Sep 10, 2013 4:59 pm
nsheldon
offline
Version 1.2.4 Posted- Added optional Ramp Rate to the Save Preset and Recall Preset actions and menu items.
- Fixed (hopefully) a bug that caused an ASCII translation error when editing an action for a device with non-ASCII characters in the name.
- Posted on
Wed Nov 06, 2013 12:51 am
nsheldon
offline
Version 1.2.5 Posted- Added support for the Hue Downlight BR30 bulb.
- Posted on
Thu Dec 05, 2013 4:13 pm
nsheldon
offline
Version 1.2.6 Posted:- Added support for the Hue GU10 spot light.
- Increased number of Presets from 10 to 30.
- Posted on
Wed Dec 25, 2013 2:37 pm
nsheldon
offline
Version 1.2.7 Posted:- Added support for the Friends of Hue Disney StoryLight.
- Posted on
Sat Feb 08, 2014 12:59 am
nsheldon
offline
Version 1.2.8 Posted:- Added support for European version of Bloom (model ID LLC011).
- Posted on
Mon Mar 31, 2014 3:13 am
nsheldon
offline
Version 1.2.9 Posted:- Added support for the LivingColor Aura (model ID LLC014).
- Updated the model names seen in Indigo when adding or updating a Hue Lights device so the type of Hue device being used is more clear.
- Posted on
Mon Apr 28, 2014 11:07 pm
nsheldon
offline
Version 1.2.10 Posted:- Fixed a bug that would cause the plugin to crash if a command was sent to the hub while the hub (or the plugin) was in an unstable state that resulted in an invalid pairing status.
- Updated the error reporting process so that major connection failure errors were actually reported as errors in the log rather than standard log entries.
- Updated the error reporting process so frequently displayed errors during a network or hub outage are reduced from once every 4 seconds to about once every minute.
- Posted on
Tue Apr 29, 2014 11:13 am
nsheldon
offline
Version 1.2.11 Posted:- Fixed a bug that would cause device edit dialogs to incorrectly report that the hub was not paired after the hub had been unreachable then became reachable again.
